Understanding Weight and Inertia: A Comparison of Mars and Earth
The discussion revolves around the concepts of weight and inertia, particularly comparing their implications on Mars and Earth. Participants explore how gravitational differences affect the force required to overcome inertia and produce acceleration, as well as the effects on jumping and running in different gravitational environments.
  • Some participants assert that weight is a measure of gravitational force and that a ball on Mars weighs less than on Earth, which affects the force needed to produce a given acceleration.
  • Others argue that while weight varies, the net force required to accelerate a mass remains the same across different planets, referencing Newton's 2nd law.
  • A participant questions the reasoning behind the claim that less force is needed to overcome inertia on Mars, suggesting a misunderstanding of inertia.
  • Some participants propose that the force required to lift a mass differs between planets, specifically for vertical lifts, due to varying gravitational forces.
  • There is a discussion about the implications of lower gravity on jumping and running, with some suggesting that an astronaut could jump higher on the Moon but may not run faster due to other factors like air resistance.
  • A participant introduces the idea of varying the direction of the jump and its effects on trajectory, prompting further exploration of gravitational effects on motion.
  • Some participants express frustration with others' reasoning and urge them to reconsider their understanding of the concepts discussed.
Participants do not reach consensus, as there are multiple competing views regarding the relationship between weight, inertia, and the forces required for acceleration on different planets. Disagreements persist about the implications of these concepts on jumping and running performance.
Limitations in the discussion include assumptions about the effects of gravity on motion without fully addressing the complexities of drag and other environmental factors. Some mathematical calculations and definitions are not fully resolved, leading to further confusion.
This discussion may be of interest to individuals exploring the physics of motion in varying gravitational fields, as well as those studying the differences between mass and weight in different planetary contexts.
rudransh verma
https://www.feynmanlectures.caltech.edu/I_09.html
“Weight and inertia are proportional, and on the earth’s surface are often taken to be numerically equal, which causes a certain confusion to the student. On Mars, weights would be different but the amount of force needed to overcome inertia would be the same.”
What does it mean?
The statement seems confusing!
If we try to throw a ball up on Mars then it would require less force than on Earth because the resisting force of gravity is less. Weight is less!
Weight is a measure of the gravitational force on an object. Sure, a ball on Mars would weigh less than on Earth.
But does that change the amount of force needed to produce a given acceleration? What does Newton's 2nd law say about that?
If a ball is at rest on Earth and one on mars, there will be less force needed to overcome inertia of rest on mars.
rudransh verma said:
If a ball is at rest on Earth and one on mars, there will be less force needed to overcome inertia of rest.
How on Earth (or Mars) do you come to such a nonsensical conclusion? Have you really THOUGHT about this. Do you have ANY sense, physically, of what inertia IS?
Oh really? How about calculating the force needed to give a 1 kg ball an acceleration of 1 m/s^2. Do it for both Mars and for Earth.
Specifically a horizontal acceleration... :wink:
That would perhaps eliminate some confusion, but the net force required will be the same regardless of direction. :wink:
No not horizontal but vertical. Horizontal will be same.
The force required to lift a 1kg mass on Earth is 9.8N but on Mars it’s only 3.7 N. So weight as well as the force required to break the state of inertia will vary from planet to planet specially for vertical lifts.
The net force required to accelerate a mass will be the same on any planet. Of course, the amount of force you have to provide to produce a given vertical acceleration will vary.
The (net) force required to accelerate a mass ("overcome inertia") is the same everywhere. That's Feynman's point.
Ok! But it’s quite fascinating that a person throwing a ball up can throw it even further on planets with less gravity like on mars. Astronauts can jump even higher on moon.
But what if he races against time. Will he beat his record on moon? Will he run faster or slower than on earth?
Continuing to spout the same nonsense will not make it true. You would be better off listening to what people are saying to you rather than ignoring it.
I will correct myself here.
This thread is turning into another dumpster fire.
@rudransh verma , it's very clear you are ttempting more advanced physics than you are ready for. You will make more progress by backing up and getting a solid foundation.
This would be quite an interesting question! I don't think there's any simple answer, because there's so many factors at play. The most obvious one is the drag-reduction because of the lack of atmosphere. The athlete also doesn't need to work as hard to overcome his weight (vertically), but since he/she spends longer in the air it's probably also harder to put a lot of power down (just look at the stride rate of professional sprinters!).
Let’s take atmosphere out of the question. Then I think if a person jumps on moon with some force making an angle of 45 with horizontal then he will surely go higher on moon but the horizontal distance covered will be same. In other words he cannot run faster on moon but surely he can run longer. What do you say?
Say, the astronaut can leave the ground at a speed ##v## in a direction of his choosing. (In other words, he can exert an impulse of fixed magnitude on the ground). How do the parameters of the resulting parabolic trajectory change as you vary the gravitational acceleration ##g##?
That's still wrong/a mess. How can he go higher if he doesn't also go further? And you should go reread the posts about net force.
@rudransh verma it is very annoying that you rarely seem to answer questions that people ask you, you just ignore us and keep posting nonsense. You would be better off trying to figure out why we ask what we ask rather than ignoring our questions.
So, I hope it's clear by now that the gravitational force on Mars is lower than on earth. Gravitational force, or mass times the acceleration of gravity, is what we call weight. Weight is a force.
Mass on the other hand is a measure for the amount of 'stuff' (let's keep it classical to not further confuse things). So, that's the difference between mass and weight. Mass is what resists acceleration. A more massive thing needs a higher force for the same acceleration. This is the same on Mars, the Moon, Earth or Jupiter for that matter.
Let's say you have a car and it can do 0 to 60 in 4 seconds in a vacuum on Earth (just to exclude aerodynamic drag, which just further confuses things). How would it perform on Mars? Exactly the same! (assuming enough grip of course). And on Jupiter? Again: the same!*)
The reason why you can jump higher on the moon is actually more complicated than you might think:
First, getting off the ground: the gravitational force (weight) keeping you on the surface is lower, this lower force is what you have to work against with your legs when jumping. But a lower force means you have higher 'excess force' on your body, since the sum of all forces on your body, so its weight and the force generated by your legs, is what is determining your acceleration. The higher net force means a higher acceleration and therefore a higher velocity the moment you leave the ground.
Then, returning to the ground: when you are airborne there is only one force acting on you: the gravitational force, or your weight. This is lower on the moon, but your mass is the same, therefore your acceleration back to the surface is lower on the moon, giving you more hang-time.*) you can throw in all kinds of other secondary order effects like the resistance of the tires due to its weight and all that, but let's keep it simple, we are talking about the fundamentals.
Once again you do not seem to have actually thought about the physical meaning of what you say. This seems to be a persistent problem that you have. For some reason you can't seem to connect concepts to the physical world. You should give this some thought.
  • Sad
I am not smart as you guys. That was foolish.:headbang: Instead of thinking in velocity I was thinking in terms of force but the force stops acting as soon as we lift of the ground.
ergospherical said:
How do the parameters of the resulting parabolic trajectory change as you vary the gravitational acceleration g?
You are right. I should be watching for the parabola. That will be bigger as we lower the value of g. But do we actually make parabolas when running? Is running actually repeated jumping?
It's not your intelligence, it's your approach/attitude (this has been pointed out to you before...). These concepts are successfully taught to schoolchildren.
When we're in the air, yes.
That may or may not be but it has nothing to do with anything. As @russ_watters just said, your intelligence is not the problem. The problems, as I see it, are that
(1) you don't seem to make any attempt to connect concepts to the physical world even to the application of trivial every-day actions.
(2) you ignore good advice when it is given
(3) you don't seem to believe that we know what we are talking about
(4) you don't answer direct questions that are put to you.
I can see why some advisors are frustrated, but making mistakes (and crucially learning from them) is one of, if not the most, important part of the learning process. I think there's some good evidence of that in this thread, e.g. #10, #15 and #22. And our job is to be that helping hand guiding you along the path. That said, I do agree you should try really hard to focus your enquiries.
Back to the point...
... you tell me! What does the velocity profile of the runner look like? Since gravity is vertical, their horizontal speed is unchanged whilst airborne in the absence of drag. The horizontal acceleration is confined to those times where there's a foot on the ground.
It’s horizontal velocity will be same. It looks like there will be no difference. But there is a drag on earth. So I think the person will move faster on moon.
You're talking in half-completed thoughts. What is it that determines how fast someone can run? Think/talk it through.
Friction and your strength!
Those are forces. What are they doing? What does your strength actually do? Does less friction (between what and what?) mean you can run faster? If so, why? Put more thought/effort into this.
They are giving you forward momentum. My strength helps me to push the ground even harder. Without friction we can’t run.
  • · Replies 29 ·
  • · Replies 21 ·
