Masses sliding on a smooth wedge
31 replies · 4K views
Karol
[/B]Mass m lies on a Weighing scale which is on Wagon M. the inclined surface is smooth, between m and M there is enough friction to prevent m from moving.
1) What does the weigh show?
2) What is the minimum coefficient of friction between m and M to prevent slipping?
3) What is M's acceleration parallel to the slope if there is no friction between m and M? can it be bigger than ##g\sin\alpha##?
4) What does the Weighing scale show in this case?
Mass-acceleration: F=ma
1) F=ma. ##a_{\alpha}## is parallel to the slope:
$$(M+m)g\sin\alpha=(M+m)a_{\alpha}~~\rightarrow~~a_\alpha=g\sin\alpha,~~a_y=a_\alpha\sin\alpha=g\sin^2\alpha$$
W is the weight, what the scale shows:
$$W=mg\sin\alpha$$
2)
$$a_x=a_\alpha\cos\alpha=g\sin\alpha\cos\alpha$$
$$f=ma_x:~mg\mu=mg\sin\alpha\cos\alpha~~\rightarrow~~\mu_{\rm min}=\sin\alpha\cos\alpha$$
3)
$$(M+m)g\sin\alpha=Ma_\alpha~~\rightarrow~~a_\alpha=\frac{M+m}{M}g\sin\alpha$$
Yes, it's bigger than ##g\sin\alpha##
4)
$$a_y=a_\alpha\sin\alpha=\frac{M+m}{M}g\sin^2\alpha$$
$$W=ma_y=\frac{m}{M}(M+m)g\sin^2\alpha$$
One way to check an answer is to consider limiting cases. Does your answer for (1) give you a reasonable result for ##\alpha## going to ##0## or ##\pi/2##?
##a_\alpha=g\sin\alpha## seems reasonable since when α→0 aα→0
The weight, as the scale shows:
$$mg-W=ma_y=mg\sin^2\alpha~~\rightarrow~~W=(1-\sin^2\alpha)mg$$
1)
$$mg-W=ma_y=mg\sin^2\alpha~~\rightarrow~~W=(1-\sin^2\alpha)mg=mg\cos^2\alpha$$
4)
$$mg-W=ma_y=m\frac{M+m}{M}g\sin^2\alpha~~\rightarrow~~W=\left[ 1-\frac{M+m}{M}g\sin^2\alpha \right]mg$$
Karol said:
1)
OK
4)
You have ##a_y=\frac{M+m}{M}g\sin^2\alpha##. Does this behave properly as ##\alpha \rightarrow \pi/2##?
You need to go back and rework parts (2), (3), and (4). Use separate FBD's for m and M.
The first equation is for M and the second for m. W is m's weight as M sees it, i.e. the force applied on M by m:
$$\left\{\begin{array}{l} (W+mg)\sin\alpha-W\mu\cos\alpha=Ma_\alpha \\ ma_\alpha\cos\alpha =W\mu \end{array}\right. ~~\rightarrow~~W=\frac{mMg\sin\alpha\cos\alpha}{(\mu\cos^2\alpha-\sin\alpha\cos\alpha)m+M\mu}$$
W becomes 0 when α=0, wrong. i expect it to be mg, am i right?
Why not try part 2). Once you get that, move on to parts 3 & 4.
Also, for 3 & 4, the equations of motion for m and M are coupled, so you may not be able to solve them independently.
Post #8 is for part (2), but the answer doesn't comply with the boundary condition ##\alpha=0##. i expect, for ##\alpha=0## that W=mg, but if i substitute ##\alpha=0## in my W, i get W=0
I don't really understand post #8. From part 1 you have ##W_1 = mgcos^2(\alpha)##
So:
a) What is the maximum frictional force between ##m## and ##M##?
b) What horizontal frictional force between ##m## and ##M## is needed to sustain the motion without slipping?
The maximum friction force between m and M is ##f=mg\mu\cos^2\alpha##. the horizontal friction force needed to sustain the motion is what i wrote in the OP:
$$f=ma_x,~~W\mu=ma_x,~~mg\mu\sin^2\alpha=mg\sin\alpha\cos\alpha~~\rightarrow~~\mu_{\rm min}=\frac{1}{\tan\alpha}$$
You've got the ##sin^2## and ##cos^2## mixed up. It's ##\mu \ge tan \alpha##.
Anyway, I think 3 & 4 are quite tricky. You can see by energy considerations that ##M## has more energy in case 3 after both masses have fallen a given vertical height, as ##m## has no horizontal velocity in case 3, unlike case 1. Or, to put it another way:
The larger ##m## becomes, the more force it exerts on ##M## and the greater the acceleration of ##M##. But, the greater the vertical acceleration, the less proportion of the normal weight of ##m## is felt by ##M##.
Can you see how to use this to set up some equations for ##a## and ##W_3##?
I made in post #1 for case 3:
$$mg-W_3=ma_y~~\rightarrow~~W=(g-a_y)m=\left[ 1-\frac{M+m}{M}\sin^2\alpha \right]mg$$
In post #8 you assume correctly that both blocks have the same component of acceleration, ##a_{\alpha}##, along the incline . Is this true for parts 3 and 4?
For these parts, in what direction must the two blocks have the same component of acceleration?
EDIT: Backing up to your first post, you wrote for part 3 that ##(M+m)g\sin\alpha=Ma_\alpha##. Can you explain how you got the left side?
##a_y## is the same for M and m. did you see my new, completed, post #14?
I don't see how you got the left side of the first equation.
Yes.
I see how you got this, but it's not right. You imagine that ##m## is pushing with its full, normal weight down on ##M##. But, because they are both accelerating downwards, it should be:
##(M + W_3)## instead of ##(M + m)##
3) The first is FBD for M and the second is for m:
$$\left\{ \begin{array}{l} [W+Mg]\sin\alpha=Ma_\alpha \\ mg-W=ma_y=ma_\alpha\sin\alpha \end{array}\right.~~\rightarrow~~a_\alpha=\frac{(M+m)\sin\alpha}{M+m\sin^2\alpha}$$
If you add "g" somewhere, you've got it!
$$\left\{ \begin{array}{l} [W+Mg]\sin\alpha=Ma_\alpha \\ mg-W=ma_y=ma_\alpha\sin\alpha \end{array}\right.~~\rightarrow~~a_\alpha=\frac{(M+m)\sin\alpha}{M+m\sin^2\alpha}g$$
Looks right. It's interesting to consider the limiting case where m >> M and α → 0.
EDIT: The behavior of ##a_\alpha## for ##\alpha##→ 0 is very different for M = 0 compared to M ≠ 0 with M << m. Graphing ##a_\alpha## vs ##\alpha## for various M/m values is useful. I think this has something to do with childhood memories of squeezing a slippery watermelon seed between thumb and forefinger to launch the seed across the room (not at anybody of course :oldeyes:).
TSny said:
The behavior of ##a_\alpha## for ##\alpha## → 0 is very different for M = 0 compared to M ≠ 0 with M << m. Graphing ##a_\alpha## vs ##\alpha## for various M/m values is useful
I will try and post here the graphs
all the graph's results must be multiplied by g, the gravity constant.
I don't understand why, for M=0, aα tends to infinity. it must be a mistake of mine in the graph.
Karol said:
https://www.physicsforums.com/attachments/106086 all the graph's results must be multiplied by g, the gravity constant.
##M \rightarrow 0## is equivalent to ##m >> M##
PeroK said:
##M\rightarrow 0## is equivalent to m>>M
Why the acceleration, parallel to the slope, as ##\alpha\rightarrow 0##, tends to infinity? no matter what the sizes of m and M are they must stay in place, ##a_\alpha\rightarrow 0##, since it is almost a flat table that they lie upon
In the case ##M \rightarrow 0##, ##m## is much larger and squeezes ##M## and shoots it out like the watermelon seed in post #22. The limit of this as ##\alpha \rightarrow 0## is 0 for any finite ##m## and ##M##.
Taking ##M = 0## and ##\alpha \rightarrow 0## breaks the maths, which can happen.
PeroK said:
Taking M=0 and α→0 breaks the maths, which can happen.
I don't understand much in mathematics but is here a problem? if M is very tiny, then, for M=0 there is a jump in the graph, from 0 to infinity. it's the first time i hear about it. as i have said, not that i heard about too much about mathematics
Look, ##M=0## is simply not valid in the first place. How can you calculate the acceleration of something with zero mass?
PeroK said:
M=0 is simply not valid in the first place. How can you calculate the acceleration of something with zero mass?
Thank you TSny and PeroK
