Mastering Physics: Rotational Motion Around Two Cylinders
The discussion revolves around a problem involving rotational motion of two cylinders connected by ropes, with specific parameters given for each cylinder's dimensions and mass. The goal is to determine the angular acceleration of the cylinders while considering the effects of hanging masses and the moment of inertia.
  • Participants discuss calculating the net torque and total moment of inertia for the system of cylinders. Questions arise about how to combine the inertias of both cylinders and the relationship between the acceleration of the hanging masses and the angular acceleration of the cylinders.
Participants are actively exploring the problem, with some suggesting methods for calculating the moment of inertia and torque. There is a recognition of the need to account for the inertia of the hanging masses, and multiple interpretations of the problem setup are being discussed.
There is an emphasis on the lack of explicit information regarding the total moment of inertia in the problem statement, leading to questions about how to approach the calculation. Participants are also considering the implications of different assumptions about the system.
lila.haj
The ropes in the figure are each wrapped around a cylinder, and the two cylinders are fastened together. The smaller cylinder has a diameter of 10 cm and a mass of 5.0 kg; the larger cylinder has a diameter of 20 cm and a mass of 20 kg. What is the angular acceleration of the cylinders? Assume that the cylinders turn on a frictionless axle. I know the answer is 3.5 rad/s2.
Figure: http://session.masteringphysics.com/problemAsset/1176936/5/P7-59.jpg
[itex]\alpha[/itex]=τ/I
τ=rF
I=1/2*M*R2
I tried calculating the net torque of the cylinders caused by the hanging masses. I then divided the net torque by the total inertia on the cylinders using the first equation listed above.
τ=rF
I=1/2*M*R2
What is the total moment of inertia of the combined cylinders?
They don't give it to you in the problem. Would I calculate the inertia on each disk and add those together to get the total inertia of the disk system?
Yes. That's how I would do it.
But once you find the inertia what would you do from there?
Well, earlier you mentioned calculating the net torque.
How is the acceleration of each mass related to the angular acceleration of the compound cylinder?
That overlooks the inertia of the two hanging masses. Safest is to assign a tension variable to each rope, an angular acceleration variable for the cylinders, and write out three free body equations.
I think it may be easier to post my work than trying to explain it. This is what I have done, and I am unsure where my error may be. Any help is greatly appreciated!
Easier, but very hard to read.
The acceleration is not the same for both blocks.
  • · Replies 22 ·
  • · Replies 19 ·
