Math Major with Low GPA Seeking Grad School Advice
The discussion revolves around the challenges faced by a math major with a low GPA (3.1 in math and approximately 2.8 overall) seeking advice on applying to graduate school. Participants explore various factors that may influence admissions decisions, including GPA, research experience, and letters of recommendation.
  • Some participants suggest that the overall GPA is critical for graduate school applications, with a common cutoff of 3.0, while others argue that major GPA may carry more weight.
  • There is discussion about the importance of research experience and strong letters of recommendation in compensating for a low GPA.
  • Some participants emphasize the need for a trend of improvement in grades, particularly in upper-division or graduate-level courses.
  • Concerns are raised about the difficulty of gaining admission with a GPA below 3.0, with some suggesting that it may be nearly impossible without exceptional qualifications.
  • A few participants share personal experiences, indicating that while a higher GPA is generally preferred, it is possible to gain admission with a GPA below 3.5 under certain circumstances.
  • There is a debate over the significance of course selection and whether it can offset a lower GPA, with differing opinions on its impact on admissions decisions.
  • One participant mentions that some institutions have strict policies against accepting students with an overall GPA below 3.0, regardless of other qualifications.
Participants express a range of opinions on the importance of GPA, research experience, and course selection in graduate admissions. There is no consensus on the relative weight of these factors, and the discussion remains unresolved regarding the best strategies for the original poster.
Limitations include the lack of specific details about the original poster's research experience, GRE scores, and the exact nature of the graduate programs they are considering. Additionally, the discussion reflects varying institutional policies regarding GPA thresholds for admissions.
hsong9
Hi,
I'm math major, and math GPA is 3.1(I got many Bs, one C+, and four As) but overall GPA is under 3.0.. may be 2.8??
Actually, I was CS major, but I changed it.
When I was CS major, I got low CS' GPA, so my overall GPA is too low.
Anyone think I can enter Grad. school?
I really want...
Actually, my school's engneering ranking is top5.
Is it able to reason why I got low GPA when I apply some grad. schools?
Thank you.
The math subject doesn't seem to be as important so I have no idea how you are going to distinguish yourself? Any papers/publications? You could possibly get into a school not in top 100 unless you have some unknown means of distinguish yourself academically.
is major gpa not important??
yeah but its still only 3.1 only 0.3 more than overall.
Have you done any research? Any publications? How good do you think your letters of recommendation will be? How good is your GRE? Do your grades show a trend of improvement and/or have you done particularly well in any upper-division or graduate level courses in the last years?
2.8 is pretty low, but the fact that you are at a top-5 school for undergrad will carry weight with many programs, and you might be able to make it if everything else is rock solid besides your GPA. You have a much better chance if it's only the first year or two that are dragging down your GPA. Research and letters of recommendation are key, as is doing well in upper-division and/or graduate courses in your jr and sr years.
I had a 3.3 GPA at a well-regarded undergrad and got into a basically everywhere I applied including several top-20 programs and a top-10 program, so when you hear people saying you absolutely need a 3.7 or whatever, that's not true. However this is the exception and not the rule, and with a 2.8 you're going to have to aim lower. Some programs have a 3.0 minimum, so look into that before you spend time and money applying.
In terms of applications, I would recommend to stay professional and focus on your strongpoints and how your interests fit with their program, rather than wasting precious space talking about why you did poorly. They will see the record and draw their conclusions, and you will not be able to change their minds by writing about it. Unless there were extreme circumstances like you had cancer or something, it will only make you look bad if you try to justify your low grades.
To put it simply: Getting into grad school is going to be very difficult, no matter what school you attend for undergrad. Here is some advice I gave in a thread about a month back to someone in a similar situation:
G01 said:
3.0 is the cutoff for almost all grad schools. When I say "3.0 is the cutoff" I mean that if your GPA is less than that, most schools won't even let you apply, let alone consider you for admission. This is because any grade in a graduate course below 3.0 is considered failing. If your GPA shows that your average grade is below 3.0, then that tells the admissions committee you would be failing if you performed at the same level in the graduate courses in their program.
If you are not a senior, my advice to you is to try as hard as you can to raise your GPA to above 3.0. Realistically, to be competitive, it should be 3.5 or above. This may be possibly if your a freshman or have several semesters left, depending on your actual GPA.
Anyway, my point is that you should realize that it will be very very tough to convince graduate schools to accept you with a GPA of 2.8, even more so if you don't have much research experience or other things to set you apart.
Whatever happens, I wish you the best of luck though.
It's going to be very hard to get into grad school with those grades.
do you have any time left to improve your grades?
Actually, I don't have time to improve my grades, so
I'm trying to find research opportunity..
I have seriously considered to go to grad. , but I really want..
Maybe you could stay a few semester and get your grades up?
hsong9 said:
but I really want..
No, I think you don't. If you really wanted to go to graduate school, you'd take whatever action necessary to make that happen.
As they say "discipline is the art of remembering what you want".
Were you applying for math grad school, or something else?thanks
thanks
Math and applied math phd programs. The top 10 one was applied math.
The thing with GPA is this. I think what everyone has agreed after years of discussion on how GPA works in graduate admissions is this:
1. Only your major GPA matters.
2. Only your upper year GPA matters if you have shown improvement.
3. Course selection is as important as your GPA.
Personally if I was ever asked to serve on an admission committee I have no idea why I would look at Calculus II grade if there was something like Analysis course, or even better, graduate real analysis course.
I think GPA should be used to determine whether you will pass quals. People around me seem to have this point of view but I am not sure. I know students who got into top 10 programs with sub 3.5 GPA.
Of course, this is because being able to do research and take graduate courses is more important. The only two ways to show that I am aware of is to 1. research or 2. take graduate courses.
If you haven't done that, I am afraid it becomes quite difficult to say you are different and have talent. Because then frankly the only thing they can rely on is your GPA.
I don't think course selection\grad courses are that important otherwise you might have more cases of people with 700+ PGRE 3.0-3.5GPA being admitted instead of more cases of 500-700PGRE 3.5+GPA being admitted.
I don't follow what you are saying.
I disagree. I have been on graduate admissions committees (in physics). An overall GPA of less than3.0 is NOT accepted at some institutions, including the institution where I was located. This was a requirement by the Graduate Admissions office... NOT the admission committees of various departments. If you wanted to try to accept a student with lower GPA, you would have to petition the graduate office, and others here (who have been on committees) have said that sometimes it must go to the provost for approval. While it's possible, therefore, an admissions committee often won't go there.
Our spreadsheet method computed applicant rank based on a formula incorporating GPA, major GPA, an undergraduate institution "rank" (based on in internal department ranking sometimes altered by the committee), PGRE score, qualitative and verbal GRE scores, and a committee reading (avg of three readings of letters of recommendation & transcripts & personal statement). The factors you state here -- upper-level performance, improvement & course selection -- only effect the committee reading score (mildly so, 5% or perhaps 10% with a generous reader), and while the committee score was weighted heavily, it still wouldn't completely counteract a bad GRE or bad GPA.
Note however, if an applicant had an MS in physics or engineering, THAT GPA and institution would go in the spreadsheet. My advice to you is therefore to perhaps shoot for a quality terminal MS degree at your home institution or an institution of similar rank... and show good performance there. It will also help the committee score in future Ph.D. applications because you'll gain more research experience.
I agree with the person who said that your major GPA is the most important. My overall GPA was pretty average (3.6), but I made A's in almost every physics and math course I took, and that really made an impression when applying to graduate school. I got mostly B's and C's in liberal arts courses.
If you can establish a track record of doing well in upper level math classes, your chances will be much better.
  • · Replies 26 ·
