MATLAB - floating point numbers
20 replies · 5K views
GreenPrint
Consider the following two equations:
x^2 + y^2 = 42
x + 3y + 2y^2 = 6
Define a symbolic equation for each, and solve it by using MATLAB's symbolic capability. Could you solve these equations by using matrices? Try this problem twice, once using only integers in your equation definitions and once using floating-point numbers (those with decimal points). how do your results vary? Check the workspace window to determine weather the results are still symbolic.
I think that I may be doing something wrong because when I wrote out my code and ran it I got the same exact results when I tried using integers and when I included decimal points. I was hoping someone could explain to me what I'm doing wrong because I guess I'm suppose to get different results.
Code:
>> disp('No you could not solve this problem usign matrices.')
one=sym('x^2+y^2-42');
two=sym('x+3*y+2*y^2-6');
[x,y]=solve(one,two)
one=sym('x^2.0+y^2.0-42.0');
two=sym('x+3.0*y+2.0*y^2.0-6.0');
x =
 -6.2161908711674029137999766546085
  6.4782037201238076694174751205659
  6.3321946913754454971273459117746
  -5.594207540331850252744844377732
y =
   1.8327495882457713513416277757555
 -0.18131894709064188368251606877471
  -1.3796051574695662000556283784362
  -3.2718254836855632676034833285446
x =
y =
Thanks in advance!
you can change the accuracy of symbolic data with digits() otherwise this is its default output.
Interesting. Are textbook hasn't covered the digits function yet. I'll go look up how to use it.
I'm confused as to how to use the digits function and incorporating it into this problem.
I'm not really familiar with the Symbolic Math Toolbox, but a quick search at the Mathworks' MATLAB documentation page brings up the following:
http://www.mathworks.com/help/toolbox/symbolic/f1-5556.html
If you don't already know, you can also access abridged documentation from the MATLAB command prompt by typing in help <function>. For instance:
>> help digits
It's my understand that digits(x) just changes how many digits are displayed in results to x. At least that's what function seems to do and what the help document says. I thought i was suppose to get different results when I did 5*x and 5.0*x or something. I'm pretty sure I don't need the digits function as this is the first time I have come across it. Hmm...
I was expecting something along the lines of
Code:
>> solve('5.0*x^2.0+6.0*x-7.0')
solve('5*x^2+6*x-7')
ans =
 0.72665
 -1.9266
ans =
   (2*11^(1/2))/5 - 3/5
 - (2*11^(1/2))/5 - 3/5
were the results actually varied
Odd, the lab computer here seems to produce the correct result:
Code:
x =
[ 33/4-1/4*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-1/4*6^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)-301*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+9*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2)-2*(-3/4+1/12*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+1/12*6^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)-301*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+9*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2))^2]
[ 33/4-1/4*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+1/4*6^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)-301*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+9*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2)-2*(-3/4+1/12*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-1/12*6^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)-301*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+9*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2))^2]
[   33/4+1/4*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-1/4*(-(-330*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+6*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)+1806*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+54*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2)-2*(-3/4-1/12*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+1/12*(-(-330*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+6*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)+1806*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+54*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2))^2]
[   33/4+1/4*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+1/4*(-(-330*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+6*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)+1806*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+54*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2)-2*(-3/4-1/12*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-1/12*(-(-330*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+6*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)+1806*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+54*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2))^2]
y =
[ -3/4+1/12*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+1/12*6^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)-301*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+9*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2)]
[ -3/4+1/12*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-1/12*6^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)-301*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+9*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2)]
[  -3/4-1/12*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+1/12*(-(-330*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+6*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)+1806*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+54*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2)]
[  -3/4-1/12*3^(1/2)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)-1/12*(-(-330*(2033+18*i*71413^(1/2))^(1/3)*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+6*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)*(2033+18*i*71413^(1/2))^(2/3)+1806*((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2)+54*3^(1/2)*(2033+18*i*71413^(1/2))^(1/3))/(2033+18*i*71413^(1/2))^(1/3)/((55*(2033+18*i*71413^(1/2))^(1/3)+2*(2033+18*i*71413^(1/2))^(2/3)+602)/(2033+18*i*71413^(1/2))^(1/3))^(1/2))^(1/2)]
EDIT: Also, have you tried using the x=syms('x') and y=syms('y') approach? I should add that we have an ancient copy of MATLAB here, R13 (v6.5)
I'm not sure what exactly you mean by incoperating x=syms('x') and y=syms('y') approach?
I thought syms was for creating symbolic representations of variables and you just did
syms x y
I'm not exactly sure what x=syms('x') and y=syms('y') even does
Code:
>> x=syms('x')
? Error using ==> syms
Too many output arguments.
I don't think I follow.
also I'm using MATLAB 7.12.0(R2011a)
Ah, syntax changed. If you read the link in my previous post, you'll see that the proper syntax is:
Code:
syms x y
one=x^2+y^2-42
two=x+3*y+2*y^2-6
[x,y]=solve(one, two)
Code:
>> syms x y
one=x^2+y^2-42
two=x+3*y+2*y^2-6
one =
x^2 + y^2 - 42
two =
2*y^2 + 3*y + x - 6
x =
 -6.2162
  6.4782
  6.3322
 -5.5942
y =
   1.8327
 -0.18132
  -1.3796
  -3.2718
It only went out to 5 digits from when I was experimenting with the digit function I did digit(5)
I don't know what you mean by CS, but I tried exiting and restarting MATLAB and the same results occurred.
Does anyone have any other solutions that might work?
hmm... I find it odd that it worked properly in a older version of MATLAB >_>
could someone please confirm with a newer version of MATLAB that there getting the same results?
Can someone with a newer version of MATLAB please run my code and let me know what results they get?
Using Mathematica, I see that the problem amounts to finding the intersections between a circle and a parabola. There are only 4 intersections, so I would expect 4 solutions.
See the attachment:
ya i was expecting to get an exact result though as the other person and not a rounded answer though
I'm still trying to get MATLAB to give me the exact results as the other person did but I can't seem to get MATLAB to do so...
I'm trying to get MATLAB to give me the exact results by trying to get around this in some other way... I have noticed one thing
x^2 + y^2 = 42
x + 3y + 2y^2 = 6
the second equation is linear
x + 3y + 2y^2 = 6
x=6-3y-2y^2
and i can substitute into the first equation
x^2 + y^2 = 42
x=6-3y-2y^2
(6-3y-2y^2)^2+y^2=42
but
Code:
solve('(-3*y + -2*y^2 + 6 )^2 + y^2 = 42','y')
ans =
no cigar... any suggestions would be greatly appreciated
