Matrix multiplication and the dot product
The forum discussion centers on proving that for an n x n matrix A where A(Transpose)A=I, the length of the vector Ax is equal to the length of the vector x, denoted as ||Ax||=||x||. Participants explored the properties of matrix multiplication and transposition, clarifying that the order of multiplication matters but associativity allows regrouping. Key insights included the use of the theorem regarding non-singular matrices and the properties of the transpose, ultimately leading to a correct proof of the statement.
  • Understanding of matrix multiplication and properties of matrices
  • Familiarity with vector norms and the notation ||x||
  • Knowledge of matrix transposition and its properties
  • Basic concepts of linear algebra, particularly non-singular matrices
  • Study the properties of matrix transposition in detail
  • Learn about non-singular matrices and their implications in linear algebra
  • Explore the concept of vector norms and their applications in various mathematical contexts
  • Investigate the differences between commutative and associative properties in matrix operations
Students and educators in linear algebra, mathematicians working with matrix theory, and anyone interested in understanding the geometric implications of matrix transformations on vector lengths.
EV33
Suppose that A is an n x n matrix such that A(Transpose)A=I. Let x be any vector in R^n. Show that llAxll=llxll; that is, multiplication of x by A produces a vector Ax having the same length as x.
Sqrt(x(transpose)x)=llxll
So I started setting up the equation wth an n x n matrix...
l a b l =A
l c d l
l a c l= A (transpose)
l b d l
A(transpose)A= I=
l a^(2) +c^(2) ab+cd l
l ba+dc b^(2)+d^(2)l
then I let the vector x=
l x1 l
l x2 l
then from there I was going to use the distance formula on Ax
but I wasn't sure if doing the dot product of Ax is the same thing as matrix multiplication of Ax, and my second problem is that I am not sure how to take the square root of a 2x2 matrix if they are the same thing.
If someone can answer those to questions for me I think I can finish the problem.
Thank you.
You don't have to work with any explicit matrices. If you are writing expressions like Ax then you should be thinking of x as a column vector. So ||x||=sqrt(transpose(x)x). So ||Ax||=sqrt(transpose(Ax)Ax). Can you express transpose(Ax) in terms of transpose(A) and transpose(x)?
I'm not too sure how to do that.
Would this argument work?
If A(transpose)A=I, then A=A(transpose)=I.
If A=I, then Ax=Ix=x
therefore llAxll=llIxll=llxl
No, because your first step is wrong. There are matrices other than I where A^TA=I.
Try looking up the properties of transpose, in particular, the transpose of a product.
ok I looked up all I know about transpose, and I also looked up all I know about I...
so here is what I know, but I ended up using other theorums to solve it.
Thrm 10: If A and B are m x n matrices and c is an n x p matrix, then:
1. (A+B)^T=A^T +B^T
2.(AC)^T=C^T * A^T
3. (A^T)^T=A
What I know about I...
.I is a matrix whose diagnal is all 1's and the rest are 0's.
.AI=A
.I is nonsingular (the only soultion is the trivial solution)
. (A^(-1)*A)^T=I
Here is my second attempt. I ended up using mainly other thrms then the ones above but I am pretty sure I have it this time. Thank you to eveyone who has helped me thus far, and anyone who spends the time to read my proof.
If I is non singular then A and A transpose must be nonsingular,because if either A or A transpose was singular then I would have to be singular and I happens to be nonsingular. The lemma states, "Let P,Q, and R be n x n matrices such that PQ=R. IF either P or Q is singular then so is R.
Then I also know that all non singular matrices can row reduce to I. If all non singular matrices can reduce to I, and A is non singular then I must be equal to A, by thrm 1.
thrm 1 states, " if one of the 3 row operations is applied to a system of linear equations, then the resulting system is equivalent to the original system.
So because any matrix time I is equal to that matrix and I is equal to A then...
A=I,
so Ax=Ix=x, therefore
llAxll=llxll
This is completely wrong. Just because a matrix is non-singular doesn't mean it equals I. It can be reduced to I, but the reduced matrix isn't equal to the original matrix.
An obvious counterexample to your logic: Take A=2I. It's obviously non-singular, but |Ax| = 2|x|. "Aha!" you say, "but A^TA \ne I!" Yes, that's true, but your proof doesn't rely on that assumption either, so according to your proof's logic, A=2I should preserve the length of vectors.
So look at property 2 of theorem 10 and use the hint Dick gave above.
oh wow that made things much easier but I am still a little confused.
so I have (Ax)^T=x^(T)*A^(T)
llxll=llAxll
sqrt(x^(T)*x)=sqrt((x^(T)*A^(T))(Ax))
x^(T)*x=(x^(T)*A^(T))(Ax)
My problem starts here now. I thought the order of multiplication mattered, and for me to get this to simplifiy I would have to break that order up I feel like because I would multiply the A^T by the A first rather than the B^T by the A^T. Does order matter here? And if it does, does it disable me from being able to do A^T by A first?
What you're thinking of is the fact that matrix multiplication is not commutative, that is, AB\ne BA generally, but it is associative, so (AB)C = A(BC).
You've got (x^(T)*A^(T))*(A*x). You are confusing commutativity with associativity. It's true you can't change the order of matrices but you can regroup them. I.e. (AB)(CD)=A(BC)D. That's just associativity. And it is true.
ahhhhhhhh got ya. Thank you so much for all the help everyone.
  • · Replies 24 ·
