Is the Trace of a Nilpotent Matrix Always Zero?
  • Context: Graduate
  • Thread starter Thread starter jostpuur
    Matrix
The discussion confirms that for a nilpotent matrix \( X \) where \( X^2 = 0 \), the trace \( \text{Tr}(X) \) is always zero. This conclusion is derived from the properties of nilpotent matrices, particularly their eigenvalues, which are all zero. The discussion references the Jordan normal form and the Cayley-Hamilton theorem as foundational concepts that support this result. The proof is straightforward when considering the characteristic polynomial of nilpotent matrices, which leads to both the trace and determinant being zero.
  • Understanding of nilpotent matrices and their properties
  • Familiarity with Jordan normal form
  • Knowledge of the Cayley-Hamilton theorem
  • Basic concepts of eigenvalues and eigenvectors
  • Study the properties of nilpotent matrices in depth
  • Learn about Jordan normal form and its applications
  • Explore the Cayley-Hamilton theorem and its implications in linear algebra
  • Investigate the relationship between eigenvalues and the trace of matrices
Mathematicians, students of linear algebra, and anyone interested in matrix theory and its applications in various fields.
jostpuur
If X\in\textrm{End}(\mathbb{R}^n) is some arbitrary nxn-matrix, is it true that
<br /> X^2 = 0\quad\implies\quad \textrm{Tr}(X)=0?<br />
Sounds plausible. Doesn't it follow immediately from putting X into a normal form, or from computing its generalized eigenvalues?
hmhm.. yes. If X is upper triangular, then
<br /> \sum_{k=1}^n X_{ik} X_{kj} = 0\quad\forall i,j<br />
implies
<br /> 0=\sum_{k=1}^n X_{ik} X_{ki} = X_{ii}^2\quad\forall i<br />
It doesn't have to be upper triangular.
My hunch is that you could take advantage of higher powers of X being zero to say that
X^n = 0, n \geq 2 \Rightarrow
e^X = I + X
and then if you could argue that
\det (I + X) = 1
then
\det (e^X) = 1
but
\det (e^X) = e^{(\textup{tr} X)}
which would imply that
e^{(\textup{tr} X)} = 1 \Rightarrow \textup{tr} X = 0
but I'm missing the crucial step, so I guess it's no good. It's an interesting problem and I'll follow this thread to see if anyone posts the solution.
This got settled already. We don't need to assume that X is upper triangular in the beginning, because there is a theorem that says that for any matrix there is a coordinate transformation that transforms the matrix into the Jordan normal form, http://en.wikipedia.org/wiki/Jordan_normal_form (edit: hmhm... although it could be that the transform involves complex numbers...). The Jordan normal form is a special case of upper triangular matrices, so if the claim is true for them, its all done.
Actually the proof (the one I know) of the formula \textrm{det}(e^X) = e^{\textrm{Tr}(X)} uses the fact that we can choose a basis so that X is upper triangular. I'm not fully sure what you were doing, but I believe that if you could make your idea work, it would probably still be using the same underlying facts.
If X^2 is zero then either X is zero, or X^2 is the minimal poly of X, and in particular divides its characteristic polynomial, which implies that the char poly has 0 constant term, but the constant term is +/- the trace of X. No need to invoke a choice of basis.
Okey, no need for change of basis if you know lot of linear algebra! I think I'll skip the proof of Cayley-Hamilton theorem for now, http://en.wikipedia.org/wiki/Cayley–Hamilton_theorem, because it looks too unpleasant.
wait a minute... why is the constant term of the characteristic polynomial plus or minus the trace?
For example \textrm{tr}(1_{2\times 2})=2, but
<br /> \textrm{det}(1_{2\times 2}-\lambda) = \lambda^2 - 2\lambda + 1<br />
Duh. Idiot. It is the coefficient of the second highest term that is the trace (or minus the trace). It is the determinant that is the constant coefficient. Sorry. Stick with the e-values all being zero, hence the sum being zero, and thus the trace is zero.
That was slick Matt. Any eigenvalue has to be zero (since any e-vector of X is an e-vector of X^2), so the characteristic polynomial is just \lambda^n and both the trace and the determinant must vanish.
  • · Replies 19 ·
  • · Replies 33 ·
11K
  • · Replies 52 ·
