Matter Alignment: Magnatism Effects on Salt Water Flow
47 replies · 5K views
Tinman
Could a field of a certain.type of magnatism effect a giving area of salt water as to.either align or dispurse the water to more freely flow among them or slide between them .like a horizon of water molecules
Drakkith said:
I'm sorry but I have no idea what you're asking.
ok let's say moving through water is like pushing through a deck of cards and that's why its so slown .. resistance is ther a way or possible way to turn the deck as to slide through the deck instead of aposing it
Oh, your wondering if you can use a magnetic field to reduce the viscosity of water?
essentaly yes and no more to create a pathway through the particles rather than lessen the density of a givin area perhaps even align them to have them all point one direction with a charged surfaced of opposition to be slipped through persay
Perhaps you should investigate laminar flow "skin" or the ejection of air bubbles at the prow of your craft. I'm not sure that either would deal with what you have in mind, but it might be a starting point.
No I'm.sorry the.flow.skin.would.probably.be standard as well.as the bubble reduction. I'm referring. To rendering.such a divice as to ..how do you say pave the way ahead of.you . So that the water you are entering is predisposed to let.you.through it more easily not.the.exterior of the craft being modified to receive /create less friction/resistance kind of. The way supersonic jets have there lillte sound bubble popper :D an under water door opener
Is there some malfunction with your " . " key? It seems to pop up randomly. o_O
Anyhow, now that you've explained it better... the only thing that I can think of that might possibly do what you want is an extremely high-intensity ultrasonic beam of some sort. I doubt that even that would be effective, though.
And a jet's "sound bubble popper" is sheer muscle in the form of tremendous engines.
... the sonic boom and what design approaches might reduce it. ... most designs engineers are testing are needle-nosed and < yes key is buggy ty. And no wouldn't high intensity beam just shove particles out of the way it the " space key its playing with the. ..
That's exactly what has to be done in order to accomplish what you want.
reducing waters vascosity would reduce resistance ? and would the rite magnetic field focused disrupt the atoms infront of it? enuf to even have an effect. like when i cliff jumped 125 feet i threw rocks in first to lessen resistance?
please exuse me building a house is as far as my science goes. i jusr had a few question about faster than sound speed under water wanted to understand the concept on a smaller level
There's two main concerns here that I know of. Breaking the attraction between the molecules (and on the object moving through the water) and then moving them out of the way. The latter can be minimized by shape, just like an aerodynamic car encounters less wind resistance than a semi-truck shaped like a brick. The former is... more difficult. Much more difficult.
I'm not sure this is possible. Water molecules aren't like playing cards. They aren't very big and in their liquid state they just move about randomly. It's more like trying to move through a million tiny, lopsided spheres. There's not really much you can do to align them all and I don't think you'd see any benefit even if you could. Aligning them would just place the + end of the molecules near the - end of another one, which strengthens their attraction.
Magnetic fields aren't the answer anyways. Water is an extremely weak diamagnetic material that barely responds to even strong magnetic fields.
sorry for that yes now that are water iss all + to minus can't we do a angular skined vessled add to that micro magnets to help.further flow throw the water sort of channel it away after slightly pulling at the allinged - 's would increase overall -'s to be pulled
No, the + and - are electrical charges, not magnet poles. Magnets wouldn't do anything.
yes +and -electical charges can't atoms aranged and charged to have rotating magetic fields each opposite to the next
cant some sort of information be tranferd.throufh.the.alligned electrical charges ? impact ?something??
Not in liquid water. The motions of the molecules are simply too chaotic.
There's no way to align them.
antiferromagnitism is what i refer to i think and the further manipulation of givin liquid
even if you could slow them down
Drakkith said:
Then you'd freeze them and you wouldn't have liquid water anymore, but ice.
and water isn't antiferromagnetic liquid?
No, it's diamagnetic as I said earlier. I'm not sure you can have an antiferromagnetic liquid since, by definition, antiferromagnetism involves molecules in an ordered arrangement which only occur in solids.
I great fully thank you for the discussion and you have gave more patients than probably was required have a wonderfully time Drakkith.
I don't know where you got your information from. That isn't the description from wiki's page on antiferromagnetism.
The magnetic moments in atom.and.molecules.ussaualy.related
To.electrons.spin and.in opposite pattern
Yeah. That was my.point I.guess on some minimal scale can salt water be effected with antiferromagnatism if so could it be effected further .
Sorry, dude, but if you insist upon trying to take a magnetic approach to it, you're doomed to failure. It's like trying to make a cow run faster by painting her horns green.
