Max Acceleration: Body Reaches on Ground
  • Context: High School
  • Thread starter Thread starter mprm86
    Acceleration Maximum
The discussion revolves around the maximum acceleration a body, specifically a car, can achieve on the ground using only its engine without external assistance. Participants explore the limits of acceleration in the context of friction, tire performance, and the influence of various forces.
  • Some participants suggest that the maximum acceleration a car can achieve is limited to gravitational acceleration (g) due to friction with the ground.
  • Others argue that with special tires or aerodynamic enhancements, cars can exceed this limit.
  • A participant mentions that dragsters can achieve accelerations greater than 1g due to specialized equipment, while street-legal tires may max out around 1g.
  • There is a discussion about the role of horsepower and traction in determining acceleration, with some emphasizing that acceleration is not solely dependent on friction.
  • One participant introduces the concept of maximum speed being limited by the speed of light according to special relativity, which is challenged by others who assert that this is unrelated to the original question about acceleration.
  • Concerns are raised about the clarity of the original question, with multiple requests for specificity regarding the conditions being discussed.
Participants express differing views on the limits of acceleration, with some supporting the idea that it is capped by gravitational acceleration while others provide counterexamples involving specialized vehicles. The discussion remains unresolved with multiple competing perspectives on the topic.
Participants highlight the importance of definitions regarding "external help" and the conditions under which acceleration is being measured, indicating potential ambiguities in the original question.
  • #31
Stingray said:
:confused: The third response is where it was clarified that the question specifically referred to cars.
Pervect was right; the guy's flame-baiting. Let's just ignore him.
  • #32
I don't even know what flame baiting is. The question although referring to a car, does not refer to a normal car, not only that, but he asks about limits. And, As I stated before, the only limits that a MECHANICAL engine would have, would be due to relativity. Normal cars reach more than one g right now. You should watch racing sometime. Well, Normal if you are speaking about a racecar, which I assume you are.
  • #33
So once you've made this engine out of neutronium so it won't explode at several million rpm... you're going to fuel it with antimatter to get that much mass reciprocating?
We've not only watched it; we've done it. And apparently Stingray is still doing it.
And if you really don't know what flame-baiting is, just look back over your last couple of posts for examples thereof. It's aguing (usually impolitely) just for the sake of pissing people off even when you know that you're wrong in hopes that a war will start.
  • #34
nemarf1, your posts appear overly argumentative. Ie, like Danger said, long before Einstein even comes into the picture, Newton will tear the engine apart. That makes Relativity far from relevant here. The other posters here were simply trying to constrain the thread to the limits of physical reality.
So that's enough of the bickering, guys...
  • #35
Russ, by your definition Relitivity would never play a part. If we ever hope to travel at speeds close to the speed of light we will have to use mechanical engines which will not tear themselves apart. Not only that but in space we will have to find a way to eliminate the heat emmitted by the friction inside the engine or our ship will simply melt.
No, Relativity is the only limit we have to talk about here, if we can use a fusion powered engine as proposed above, for this super racecar.
Conventional means that we use today without using rocket engines are wind limited to answer the original question based on a normal racecar without being confrontational.
However, I still say that Relativity is the only limiting factor if you are asking about a super racecar powered by something we don't fully understand yet.
  • · Replies 25 ·
  • · Replies 28 ·
