Max Angle of Mass on Incline Surface
The calculation for the angle of mass on an incline shows that tan(𝜃) equals 0.67, leading to an angle of approximately 33.82 degrees. The suggested answer of 42 degrees does not match this calculation, indicating a potential error. The discussion confirms that arcsin(0.67) equals 42 degrees, adding to the confusion. Participants agree that the suggested answer is likely a typo and recommend verifying with a teaching assistant or professor. The consensus is that the initial answer provided is incorrect.
a_r_part
A brick with a mass of 2.3 kg is at rest on a rough surface that is at a slope that makes an angle
𝜃 above the horizontal, as shown in the diagram. If the slope becomes any steeper, the brick will start to slide downward along the slope. The coefficient of static friction of the brick with the surface is 0.67. What value must 𝜃 be less than for the brick to remain at rest?
mu = tan(theta)
Hello,
I've worked through the free-body diagram to compute the answer:
tan(𝜃) = 0.67
𝜃 = arctan(0.67) = 33.822...
The answer is supposed to be approximately 42. Yet, tan(42) is not 0.67, is the suggested answer wrong?
Well, ##\arcsin(0.67) = 42## degrees. So, the answer looks wrong.
Agreed. It looks like the suggested answer of 42° is wrong. Can you attach an image of the problem statement diagram, just in case there is something else going on?
Sure, here is the diagram:
Thanks.
Okay, I think we agree the suggested answer is a typo. Can you check with your TA/Prof?
Sure, thanks.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
