Find Maximum Elevation of Test Rocket
  • Thread starter Thread starter jenc305
    Maximum
The test rocket problem involves two phases: during acceleration and after the motor shuts off. Initially, the rocket reaches a height of 160 meters with a velocity of 80 m/s after 4 seconds of acceleration at 20 m/s². Once the motor stops, the rocket continues to coast upward until it reaches a maximum elevation of approximately 487 meters, calculated using projectile motion equations. Additionally, a question about horizontal projectile motion highlights confusion regarding the increasing distance between two packages dropped from a plane, which occurs due to their constant horizontal velocity while falling under gravity. Understanding these concepts is crucial for solving both vertical and horizontal motion problems effectively.
jenc305
This problem seems simple but I'm just not getting the correct answer, please help thank you.
A test rocket is fired straigt up from rest with a net accerleration of 20m/s^2. After 4 seconds the motor turns off, but the rocket continues to coast upward. What maximum elevation does the rocket reach?
This is what I get
X_0=0, a=20m/s^2, t=4 s
1/2(20m/s^2)(4 s)^2=160m (the correct answer is 487m :cry: )
You need to think of it as 2 separate problems.
1. Rocket under the stated acceleration
2. Rocket after acceleration stops.
The final conditions of problem 1 (i.e. height and velocity) are the initial conditions for problem 2.
Problem 1
x=160m and v=80m/s
Problem 2
x_0=160m, v_0=80m/s, a=?
if it stopped accelerating, I would assume that the acceleration would be decreasing as the rocket coasted upward. Would this be correct?
So far, so good. You have the initial conditions for problem #2. Now, you need the equation of motion (in the vertical direction) for a projectile with initial conditions of distance and velocity. You must have been given such an equation or taught how to derive it using F=ma.
Thank you. This is what I got
160m-[0-(80m/s)^2/2(9.8m/s^2)]=486.5m
Also, I had another question about horizontal projectile motion.
Why does the distance of two packages steadily increase as they fall out of a plane going at constant speed.
I thought the distance would remain constant between the two packages as they fall when air friction is negligible. I can't make sense of it.
  • · Replies 53 ·
