Maximum error for the Lagrange interpolating polynomials
8 replies · 2K views
mathmari
MHB
Hey :o !
Could you help me at the following exercise?
$k, n \in \mathbb{N}$
$f(x)=cos(k \pi x), x \in [0,1]$
$x_i=ih, i=0,1,2,...,n, h=\frac{1}{n}$
Let $p \in \mathbb{P}_n$ the Lagrange interpolating polynomials of $f$ at the points $x_i$.
Calculate an upper bound of the maximum error $\varepsilon_p =max_{0 \leq x \leq 1}{|f(x)-p(x)|}$ as a function of $k$ and $n$, and find a relation that $k$ and $n$ should satisfy so that $\varepsilon_p \rightarrow 0$ while $k \rightarrow \infty$ and $ n \rightarrow \infty$.
I have found that an upper bound of the maximum error is $ \frac{(k \pi h)^{n+1}}{n+1}$.
How can I find the relation that $k$ and $n$ should satisfy so that $\varepsilon_p \rightarrow 0$ while $k \rightarrow \infty$ and $ n \rightarrow \infty$ ??
mathmari said:
Hey :o !
Oi! :)Hmm, how did you get that?
I get $$\frac{(k \pi)^{n+1} h^n}{n+1}$$. :o
First substitute $$h=\frac{1}{n}$$?
And then find the necessary condition for the limit to be zero?
$$|(x-0h)(x-h)(x-2h)...(x-nh)| \frac{(k \pi)^{n+1}}{(n+1)!} \leq (h-x)(h-x)(2h-x)...(nh-x)| \frac{(k \pi)^{n+1}}{(n+1)!} \leq n! h^{n+1}\frac{(k \pi)^{n+1}}{(n+1)!} =\frac{(k \pi h)^{n+1}}{n+1}$$
$$\frac{(k \pi h)^{n+1}}{n+1}=\frac{(k \pi )^{n+1}}{n^{n+1} n+1}$$
So that the limit is zero the condition is $ k \pi <1$, isn't it? But shouldn't $k \rightarrow \infty$ ?
Ah yes. That works! :o
Not quite.
Aren't you forgetting the $n^{n+1}$ in the denominator?
(And also a couple of parentheses? (Lipssealed))
Perhaps you can merge it in the power that you have in the numerator?
(Tmi)
I like Serena said:
Not quite.
So $$(\frac{k \pi}{n})^{n+1} \frac{1}{n+1}$$
While $ n \rightarrow \infty, \frac{1}{n+1} \rightarrow 0$.
But what about $(\frac{k \pi}{n})^{n+1}$ ? Since $n$ is a power, $\frac{k \pi}{n}$ should be smaller than $1$. But what can I do in this case where there is a $n$ in the denominator?
Well, you needed a relation between $k$ and $n$.
What about $\frac{k \pi}{n} < 1$, or say $k \pi < n$?
Does that look like a relation?
Does this relation stand for $k \rightarrow \infty$ and $n \rightarrow \infty$?
It's a condition.
If we set for instance $n = 2\pi k$ and let $k \to \infty$, obviously we also have that $n \to \infty$. Furthermore, $\varepsilon_p \to 0$.
However, if we set $n = k$ and let $k \to \infty,\ n \to \infty$, we do not necessarily get that $\varepsilon_p \to 0$.
I like Serena said:
It's a condition.
However, if we set $n = k$ and let $k \to \infty,\ n \to \infty$, we get that $\varepsilon_p \to \infty$.
A ok! Thank you! :o
