Maximum force exerted by floor?
  • Thread starter Thread starter kristibella
    Force Maximum
The maximum force exerted by the floor on a 220 g ball dropped from a height of 2.2 m and rebounding to 1.7 m is calculated using the impulse-momentum theorem. Initial and final velocities are determined as 6.57 m/s and 5.77 m/s, respectively. The average force is computed to be -35.2 N, leading to a maximum force of 70.4 N based on the triangular force graph. However, considering the direction of momentum, the corrected maximum force is 1085.92 N.
  • Understanding of kinematic equations, specifically v_i = √(2gh) and v_f = √(2gh).
  • Familiarity with the impulse-momentum theorem, particularly F = (m(v_f - v_i)) / Δt.
  • Knowledge of average and maximum force calculations in physics.
  • Ability to interpret force graphs, especially triangular shapes.
  • Study the impulse-momentum theorem in detail.
  • Learn about the significance of direction in momentum calculations.
  • Explore advanced kinematic equations for varying heights and masses.
  • Investigate different types of force graphs and their implications in physics.
Physics students, educators, and anyone interested in understanding the dynamics of collisions and forces in mechanics.
kristibella
1. A 220 g ball is dropped from a height of 2.2 m, bounces on a hard floor, and rebounds to a height of 1.7 m. The figure shows the impulse received from the floor.
What maximum force does the floor exert on the ball?
To find the velocity, I used vi=\sqrt{}2gh and vf=\sqrt{}2gh. To find the impulse, I used F= \stackrel{}{}m(vf-vi)t
Vi = 6.57 m/s (I used 2.2m for h)
Vf = 5.77 m/s (I used 1.7 m for h)
t= .005 s
F = \stackrel{(220)(5.77-6.57)}{.005} = -35,200
v_i = \sqrt{2gh}
and
v_f = \sqrt{2gh}.
F= \frac{m(vf-vi)}{\Delta t}
t= .005 s
Mind your units
F_{avg} = \frac {(.220)(5.77-6.57)}{.005} = -35.2N This is the Average Force.
Your Force Graph indicates that it is Triangular, hence the Maximum Force is twice the Average.
Fmax = 70.4 N
LowlyPion said:
Mind your units
Fmax = 70.4 N
I found this post while googling my problem just to see how others had attempted it, and I noticed another mistake here. You have to consider the direction of the momentum. One of the velocities should be negative, because they are going in opposite directions. Therefore we have 5.77 + 6.57 for Jx rather than 5.77 - 6.57. Fmax should actually be 1085.92 N here.
  • · Replies 31 ·
