Maximum power dissipation for resistors
21 replies · 13K views · last reply
jackferz
there are 3 resistors of, different values. 470o,22o and 100o. but each one is 500W
I want to connect them in series/parallel in order to dissipate the maximum power 500W.
I have connected 4,22o in series and 2, 100o in series, 1, 470 in parallel. but the dissipation is not maximum.
the supply is 415
i would like to know if its possible to get max power dissipation
the supply is 415
Welcome to the PF.
You only have one each of 22, 100 and 470 Ohm resistors? And you want to maximize the power dissipation with no single component exceeding 500W, or you want the total dissipation of the sum to equal 500W?
i have each resistor in a large quantity. here is the circuit
  • Multisim schematic of three parallel branches fed by a 415 Vrms, 50 Hz AC source V3, with four 22Ω resistors R11, R9, R10, R12 in series, two 100Ω resistors R24 and R20 in series, and a 470Ω resistor R25, with AC voltmeters U8, U14, U15 and U19 showing readings.
want to maximize with no single component exceeding 500W. each is rated for 500W
So what *exactly* are you trying to do? Do you want the total power dissipated to be 500W?
No, total power will be the sum of the all the dissipated power for each resitor
The maximum power dissipated will depend on how many resistors you have. If you have an unlimited number of resistors, you can dissipate infinite power.
Please post the *exact* text of the question.
ok sorry for the confusion
What i have in the attached circuit.
I will have maximum power for each as followed based on P=I^2*R:
22ohm: 489W (that would be multiplied by 4 since 4, 22ohm are used)
100ohm: 430W (that would be multiplied by 2)
470ohm: 366 (that would be single)
Now if the circuit is connected in such a way that each resistor is connected to dissipated at maximum rating 500W. the total would be the sum of all
As long as each is dissipating close to 500W. the sum of each would be the total
Did you get my question this time
lets make it simple. i don't care what's the total output power going to be when all the resistors are dissipating 500W each.
for the time i just want each to dissipate 500W (or close).
With the current circuit its way to less than 500w for resistors 100, 470
No, sorry.
jackferz said:
Lets make it simple. i don't care what's the total output power going to be when all the resistors are dissipating 500W each.
Try this -- what voltage do you need across each of those 3 resistor values to get to 500W? Does that help you start to figure out how you could combine them to always have close to that voltage across them?
using P=V^2/R,the voltages across each would be
22ohm: 104.9V
100ohm:223.6V
470ohm: 484V
any idea how to combine resistors to get these voltages across it
That's your task, right?
thats why i am here after not been able to figure out
I don't see of combinations since P=I^2*R= V^2/R
which would be the same as i was trying to achieve current.
22ohm: 104.9V
100ohm:223.6V
470ohm: 484V
Can you please show us the original problem statement, word for word? If it's in a language other than English, show us the original and then please give us a word-for-word translation.
The problem makes no sense to me as stated.
if i were to combine then in order to have required voltages across them, the I^2 current is either goin to burn the resistor or not provide sufficient power.
Problem: Construct a 3-ph resistor load bank provided the following resistors:
22ohm:500W (Quantity : 15)
470ohm:500W (Quantity:15)
100ohm: 500W (Quantity: 15)
Each power resistor should dissipate nearly 500W (full wattage) connected in series and/or parallel. The supply line is 415ac. The delta-wye combination can also be mixed in order to connect the resistors.
Whew. That's a very different problem from the one you've been trying to describe so far. This is a 3-phase voltage supply, and you have a finite number of the resistors. Check.
Okay, so what do the voltages look like in a 3-phase "415Vrms" system? What is a Delta-Wye Combination?
please see the attached print
I don't know if this information should have make difference in understanding the situation.
Since even with the 3phase balanced load the current flowing through the resistors are same. This is just delta configuration.
it does not seem to help anyway combining wye connection in that, since Phase voltage would be 240V
Do u understand the taks this time
  • Circuit schematic of a 3-phase 415V supply feeding a delta network of 22Ω resistors, with 100Ω and 470Ω resistors in parallel branches on the outer legs and a bottom group of resistors labelled 100Ω, 100Ω and 470Ω.
What is the phase-to-neutral voltage for a 415V 3 phase system? What is the phase-to-phase voltage? Are they the same or different?
As you know
in delta configuration
Phase voltage= Line voltage= So Phase-Phase is 415
If i were to connect it in Wye
Thenk phase to neutral votlage would be 240V
jackferz said:
As you know
So you have two different potentials that you can play with. Is there any reason why you can't use both forms of connection at the same time (with different groups of resistors, of course)?
yah you are right, its two different potential either 415 or 240.
But it does not seem to help.
I think the maximum power i can take out for each resistor is as follows (following my previous circuit)
for 22R: 498W
for 100: 430W
for 470: 350W
there is no way i could have combination of series parallel if i need to increase more wattage.
Isnt it
