Maximum Speed on a Banked Curve with Friction
19 replies · 4K views
Jacky Lee
A concrete highway curve of radius 70 m is banked at a 15° angle. What is the maximum speed with which a 1500 kg rubber tired car can take this curve without sliding? The static friction coefficient is 1.
Centripetal Force = ## (m v^2) / r ##
Maximum Friction Force = ## μN ##
## (m v^2) / r ## = centripetal force
Friction_max = 1 * normal force = ## 9.8 * 1500 * cos(15) = 14199.11 N ##
Plug back into equation:
## (1500 v^2) / 70 = 14199.11 ##
Which yields v = 25.7 m/s
However, the answer is 34.5 m/s. What am I doing wrong? I don't understand where I am going wrong in my steps.
on Phys.org
Are you sure that the normal force is the only force you have to worry about? No other forces? None at all?
I mean the frictional force
I figured that when the centripetal force exceeds the maximum frictional force, the car would skid. Solving for the maximum frictional force only requires the normal force, so I didn't include any other forces. Where would I have to use the friction force?
Look, I phrased that statement poorly. Reevaluate the forces acting on the car tire.
Everything else is correct, your steps, your concept of friction, all correct.
Forces on the tires: friction, normal, centripetal
Am I missing anything?
Yes. Yes, you are missing something very important. A force that is in every inclined plane problem you have ever seen...
Ignore the centripetal forces. Just think about a tire on an incline. What forces act on it?
OH, I'm missing gravity, aren't I?
I do believe you are.
Hmm, I still don't get the right answer. I tried adding the force of gravity in the direction of the incline to the frictional force (which would just double it), so I got:
## (m v^2) / r = 28398.22 ##
## (1500 v^2 / 70) = 28398.22 ##
## v = 36.4 ##
Don't just give me numbers. Keep it symbolic. What are the two factors that make up the 28398.22N?
The gravitational force directed down the incline would not be cosθmg
I made an error, it should be 18003.75N
Maximum Frictional Force: ## 9.8 * 1500 * cos(15) = 14199.11 ##
Force due to gravity: ## 9.8 * 1500 * sin(15) = 3804.64 ##
Added together: ## 14199.11 + 3804.64 = 18003.75 N ##
## (m v^2) / r = 18003.75 ##
## (1500 v^2 / 70) = 18003.75##
## v = 29.0 m/s ##
I would wait until you have the solution to start plugging numbers in. You made a sign error.
Should the friction force be negative?
Even if I changed the sign on any of the numbers, my answer would still be incorrect. If I change the sign on either forces, I would get a smaller number and therefore a smaller velocity as an answer.
You are right. Your solution above looks good. I think that you either made a calculation mistake, or that the answer you claim is correct, is not actually correct.
Hmm, okay. Thank you for all the help! :) I really appreciate it.
