Maximum temperature in three identical blocks starting at T₁, T₁, T₂
5 replies · 2K views · last reply
TheTank
Hope to get a little help here..
3 identical blocks with constant heatcapasity have temperatures T1, T1, T2, with T1>T2.
What is the highest possible temperature T we can achive in one of the blocks, when no heat/work exchange with the envoriment.
Answere [tex]T=2T_{1}+\frac{1}{2}T_{2}-\sqrt{2T_1 T_2 +\frac{1}{4}{T_2}^2}[/tex]
TdS=dU, dU=dQ=cdT
I end up with a 3. grade equation for T. Very sceptical..
TdS=dU, dU=dQ=cdT
I am not sure how one gets that answer.
Heat flow of [itex]\Delta Q[/itex] will flow from 2M to M where [itex]\Delta Q = 2MC(T_f - T_1) = -MC(T_f - T_2)[/itex].
So, it seems to me that the equilibrium temperature is:
[tex]T_f =(T_2 + 2T_1)/3[/tex]
AM
The odd thing here is that one of the blocks will get a higher end temperature. Maybe if we imagine two Carnot engines working between the cold and the hot blocks? So that we can say that change in entropy S is zero. I can't get the "correct" answere either.
Hope for more response. Thanks
Ok. Let's call them A, B and C (A and B being at T1). In order to increase the temperature of A you have to move heat from B. To do that you have to run a heat pump between B and A. The work to run the heat pump comes from running a heat engine between B and C. If the heat pump and heat engines are as efficient as possible, you will maximize the amount of heat delivered to A.
But I don't think the given answer can be correct. The limit would be where T1 is arbitrarily close to T2 and it would be T1. That equation gives a higher limit.
AM
