Maximum velocity by compressing spring
The discussion focuses on calculating the maximum velocity of an object launched by a compressed spring. The initial confusion arises from whether the scenario involves launching the object or slowing it down against the spring. It is clarified that when the spring is fully compressed, all the potential energy stored in the spring converts into kinetic energy of the object, leading to the formula v = √(k/m) * x for maximum velocity. The conversation emphasizes that this formula represents the maximum speed achievable under ideal conditions, with no energy losses. The conclusion affirms that the derived formula accurately reflects the maximum velocity when all potential energy is converted to kinetic energy.
badsniper019
I'm new to physics. I'm a programmer, so I'm having trouble finding this solution. when spring is compressed against wall until the body attached to it touches the wall, what's the maximum velocity obtained?
I thought it happens when the kinetic energy is high. Of the original kinetic energy of the body, some goes into potential energy in the spring and the remainder is left as kinetic energy of the now slowed object. So I did the remainder of energy is equal to force(-kx) over time, which means
\frac{1}{2}(mv^2-kX^2)=-kXt
x is the distance obtained, t is time
Welcome to PF;
This is homework?
You seem to have written you problem two ways - the title, and initial comments, appear to want to set an object moving by launching it from a compressed spring... but your working suggests you are slowing an object by running it against a spring.
In the first case, the energy stored in the compressed spring turns into kinetic energy in the object (under ideal conditions - in real life, some of it goes into kinetic energy in the spring - because a real spring has mass.)
In the second - it is the reverse, only you may have some kinetic energy left over (in which case the object slams into the wall as well.)
If the speed is such that the object comes to rest after compressing the spring a distance x, then all the initial kinetic energy gets stored in the spring (well - ideally - IRL there will be some losses) ... nothing left over.
sorry about that. I'm working on the first case. So my equation should be 1/2(mv^2)=-kxt?
Energy stored in a spring compressed by distance x is: ##P=\frac{1}{2}kx^2## ... you can look these things up :)
Ok, got it. 1/2(mv^2)=1/2(kx^2). which gives v=\sqrt{\frac{k}{m}}x. But how to find the maximum velocity. Derivative over velocity?
You have just worked out the speed if all the energy stored in the spring goes into the motion of the object. That's the biggest it can get.
So this is the formula for maximum velocity?
If you can think of a way to get more kinetic energy than the total PE stored in the spring, let me know.
