Did Installing ENDFVII Fix the MCNP5 Error in Routine IMCN?
The discussion revolves around resolving an MCNP5 error related to the IMCN routine, specifically a memory issue linked to source particles. Users suggest searching for the error message online and reviewing input files for trailing spaces and blank lines, which may cause problems. One participant notes that changing certain lines to comment format can help, while another mentions that ENDF VIII might be incompatible with older MCNP5 versions. The conversation highlights the importance of checking output files for detailed error messages and the potential need for specific library installations. Overall, the thread emphasizes troubleshooting techniques and compatibility considerations for MCNP5 users.
Limitzone
TL;DR
i am getting an error which reas as follows :
bad trouble in imcn in routine imcn source particle no error getting memorybly a control character,in coulumn 32
mcnp5
Have you tried to use google to search on the text of the error message?
mncp5 error: bad trouble in imcn in routine imcn source particle no error getting memorybly a control character,in coulumn 32
Sometimes other folks have had the same issue and you may find a solution.
We also have several threads at PF (shown below on the web page) where posters had similar problems with mncp5.
@Limitzone
Rename your output file to add .txt to the end, then attach it to a post.
okey thank you bro
While I'm not familiar with MNCP5, I looked through your file and noticed a few non-comment lines that had trailing spaces. There were a few lines with $ comments I think with trailing spaces too but I didn't think they would cause a problem.
See lines 85, 86 below which have an extra space at the end:
Code:
        40091.81c -1.10237E-01
        40092.81c -1.68499E-01
Could trailing spaces on your input cards cause the error you see?
I also saw a few blank lines, at lines 44, 59, 110, and 111. Should they instead be comment lines ie start with a "c"?
Lastly, should line #2 be a comment line eg c234567890123456789012 which I assume you added to locate column 32.
When I change line 2 to
Code:
c 345678901234567890123456789012
the only thing that stops me running it is that I don't have ENDF VIII installed. When I make the changes to get it to run with the library native to 5, ENDF VI, (I removed .81c from the end of materials, and tin entirely), it just runs fine and gives a keff of 1.28.
Your actual error is strange btw, if it's 100% char for char your error. It looks like two normal MCNP5 errors smashed into one another. Reading the output file may provide more detail. I did ask for that, not the input file btw :) My thoughts now are maybe ENDF VIII is so new it's breaking the old MCNP 5 code. I may try installing ENDF VIII, but it needs a lot of disc space. Long and painful past experience makes me not trust very new libraries with old code. What version of 5 are you using and in what OS? It is also possible it's a linefeed or carriage return code issue which might be OS dependent. I ran with 5.1.60, which was the last release of 5, in linux.
@jedishrfu Just an FYI, the first two blank lines, in this case at 44 and 59, tell MCNP when the cell section and surface section end. Some aspects are quite arcane.
.81c turns out to be ENDFVII, not VIII and I installed that. All the libraries can just be downloaded from here if anyone wants them.
With only the "c 3" change 5.1.60 is working so my main thought wasn't right.
