MCNP6 Reproduction of 40 MeV D - Li Target Experiment
  • Thread starter Thread starter zhaozq
The forum discussion centers on the reproduction of the neutron emission spectra from the Li(d,xn) reaction using MCNP6, as detailed in the study by M. Hagiwara et al. The experiment utilizes a 40 MeV deuteron beam with a current intensity of 1 μA, targeting a lithium cylinder with a diameter of 30 mm and a thickness of 21.4 mm. The user reports discrepancies exceeding 100 times between their calculated results and the expected outcomes, prompting inquiries into potential errors in their MCNP6 settings.
  • Familiarity with MCNP6 simulation software
  • Understanding of nuclear reaction mechanisms, specifically the Li(d,xn) reaction
  • Knowledge of neutron emission spectra analysis
  • Basic principles of particle beam interactions with matter
  • Review MCNP6 documentation for proper input settings and configurations
  • Investigate neutron emission spectra conversion methods to match experimental units
  • Analyze the impact of beam current variations on simulation results
  • Explore literature on similar experiments for comparative analysis and troubleshooting
This discussion is beneficial for nuclear physicists, researchers conducting experiments with MCNP6, and anyone involved in neutron emission studies or particle beam interactions.
zhaozq
TL;DR
MCNP6 Reproduction of 40 MeV D - Li Target Experiment ?
I reproduced the experiment published by M. Hagiwara et al. using MCNP6. This experiment measures the neutron emission spectra of the Li(d,xn) reaction when 40 MeV deuterons interact with thick and thin lithium targets.The lithium target in the experiment is a cylinder with a diameter of 30 mm, and the thickness of the thick target is 21.4 mm. The source used in the experiment is a 40 MeV deuteron beam with a beam current intensity of 1 μA.The experiment refers to this website: https://nds.iaea.org/exfor/servlet/X4sGetSubent?plus=1&sub=E1986.002 . However, the data I calculated always differs from the expected results by more than 100 times. What could be the reason for this? Have I made mistakes in some of the settings?
Code:
1   0    -1 #2   imp:n,D=1
2   1  -0.534  7 -8 -9   imp:n,D=1
4   0   1   imp:n,D=0
c
c
c
1    so   100
c
7    pz   0
8    pz   2.14
9    cz   1.5
c
c
c
MODE      n d
SDEF      ERG=40  PAR=31 POS=0 0 -40 EFF=1e-2
          WGT=6.242197253e+12
          AXS=0 0 1  rad=d1  ara=7.068583471
          VEC=0 0 1  DIR=1 cel=1
c
si1     0  1.5
SP1     -21 1
c
c --------------------------------------------------
m1      3006.32o  0.075
        3007.32o  0.925
        nlib=32c
c
f1:n     8
*c1      110 90 60 45 30 20 15 10 0
e1       1 39i 5 49i 55
c
C f2:n     8
C *c2      110 90 60 45 30 20 15 10 0
C e2       1 39i 5 49i 55
C
f11:n     8
f12:n     8
print     20  30  32  40 50  60  126  198
LOST     1e+1  1e+1
NPS      1e+7
Welcome to Physics Forums @zhaozq,
Please show us what the result of the program is, how you are converting that to the units in the paper and what values in the paper it is supposed to match.
The beam current looks to be lower than 1uA in the paper, but I'm not sure that solves the problem. The output of MCNP is independent of intensity and the conclusions of the paper should also be independent of intensity.
9K
