Mean and varince of Log(X) Where X~U[1,0]
  • Thread starter Thread starter rosh300
    Mean
2 replies · 3K views
rosh300
find the mean and varince of Log(X) Where X~U[1,0] (X is continuous Random variable)
[tex]\mathbb{E}(X) = \int_{-\infity}^{\infity}{x f_X(x)} dx[/tex]
[tex]\mathbb{E}(X^2) = \int_{-\infity}^{\infity}{x^2 f_X(x)} dx[/tex]
[tex]Var(X) = \mathbb{E}(X^2) - (\mathbb{E}(X))^2[/tex]
[tex]\mathbb{E}[log(x)] = \int_0^1{xlog(x)} = \frac{-1}{4}[/tex]
[tex]\mathbb{E}[log(x)^2] = \int_0^1{x^2log(x)} = \frac{-1}{9}[/tex]
[tex]Var(X) = \mathbb{E}[log(x)^2] - \mathbb{E}[log(x)]^2 = \frac{-25}{144}[/tex]
but i know variance can't be negative
you're right, variance can't be negative
not too sure what you've done, but i think you've assumed [itex]f_{log(X)}(log(X)=x) = log(x)[/itex] which doesn't make any sense... in fact over the given domain log(X) is negative, which doesn't make sense for a pdf, and isn't normalised
So first, define the random variable Y, related to X by
Y = log(X)
you then need to find the probability distrubution g(y).dy. It can be related to the original f(x), by
g(y).dy = f(x).dx
where the dy & dx are related
once you have that
[tex]E[log(X)] = E[Y] = \int{g(y)}dy[/tex]
and so on, note the lmits of the pdf of y, g(y) wll be realte to the orginal x values, but not necessarily the same
i think i get it now
let:[tex]f(x) = 1 \mbox{(the pdf for U[0,1]), }g(y) = e^y = x \Rightarrow \frac{dx}{dy} = e^y, f(g(y)) = 1[/tex]
this gives you [tex]f_x(x) = \int_0^1{1 dx} = \int_{log(0)}^{log(1)}{e^y dy} = \int^0_{-\infty}e^y dy[/tex]
get the pdf fo y from that and use the def/formula for mean and varaince.
it seems so simple thanks
