Mean effective pressure in a diesel engine
2 replies · 4K views · last reply
Monsterboy
Air enters a diesel engine with a density of 1.0 kg/m3. The compression ratio is 21 .At steady state ,the air intake is 30 x10-3 Kg/s and the net work output is 15 kW .The mean effective pressure (in kPa) is ...
Pm= W.D/ Vs
C = V1/V2
V1 =Vs +Vc
V2=Vc
##\eta## = 1- ##\frac{1}{r^(\gamma-1)} \frac{ \rho^\gamma-1}{(\rho-1)\gamma}##
Pm -mean effective pressure
W.D -work done
Vs -stroke volume
Vc-clearance volume
##\gamma## -ratio of specific heats.
##\rho## -density (rho)
##\eta## -efficiency (eta)
Mass flow rate -m.
C- compression ratio
[/B]
Since density is 1 kg/m3 ,the efficiency becomes 100% according to the formula.
because there is a (rho-1) term in the denominator of the second term.
If the above is correct then W.D =Heat supplied = 15kW
So m. /density = Volume flow rate = Vs ?
if r= 21 ,then Vs =20Vc
So volume flow rate = 30x10-3 = Vs ?
So mean effective pressure =15000W/(30x10-3)
= 500 kPa
Is the above calcualtion correct ?
but the answer given to me is 525 kPa
I just want to know whether my calculation is right because i am not getting the answer i was given.
Oops! rho is not density , it is cut-off ratio.
