Meaning of the s-domain absolute value function
The discussion focuses on understanding the s-domain absolute value function derived from the Laplace transform of a time-domain function. It highlights the distinction between the real and imaginary parts of complex frequencies in the s-domain compared to the t-domain, suggesting that the real part in the s-domain represents exponential decay while the imaginary part represents sinusoidal frequency. The conversation also clarifies that the Laplace transform provides insight into the behavior of time-domain functions across different frequencies, contrasting it with the Fourier transform, which is seen as a specific case of the Laplace transform. Additionally, the importance of pole-zero plots in determining system stability and the regions of convergence is emphasized, with a focus on understanding these concepts intuitively rather than through memorization. Overall, the participants express a desire to deepen their comprehension of the s-domain's significance in analyzing linear time-invariant systems.
leright
I am trying to understand the meaning of the s-domain absolute function derived from taking the laplace transform of a t-domain function. I know for sure that the real part of the complex frequency in the time domain is the sinusoidal frequency and the imaginary part of the complex frequency in the time domain is the exponential decay frequency. I was able to prove this to myself.
Now, in the s-domain, it seems like the opposite occurs. It looks to me like the real part is now the exponential decay and the imaginary part is now the sinusoidal frequency. IS my interpretation correct? I was hoping things would be simple and complex frequency could be interpreted in the same in both the t-domain and the s-domain...I guess I was wrong.
Also, it seems like the laplace transform shows the character of the time domain function at different frequencies, or at least this is how I am interpreting the meaning of F(s). I was under the impression that the Fourier transform did this. But now, it makes more sense that the laplace transform does this. The Fourier transform is the integral of all of the different frequencies in the laplace transform function, and this explains why the Fourier transform is the inverse of the laplace transform.
Sorry I am slow with this...I am just learning this stuff as we speak...
Laplace and Fourier transforms are ways of looking at a problem in the 'frequency domain'. Fourier transform domain is a subset of Laplace transform domain. (I don't know if that's the right way of saying this :rolleyes: ).
See - http://en.wikipedia.org/wiki/Laplace_Transform#Formal_definition
If s = \sigma\,+\,i\omega then setting \sigma = 0 gives the domain Fourier transform, s = i\omega.
The Fourier transform is NOT the inverse of the laplace transform. Both are in the frequency domain. There is an Inverse Lapace Transform and an Inverse Fourier Transform, which takes the problem back into time-domain.
ok, that is actually what I was thinking...
so to my other question...It looks to me like in the s-domain the real part is now the exponential decay and the imaginary part is now the sinusoidal frequency. Is my interpretation correct? I was hoping things would be simple and complex frequency could be interpreted in the same way in both the t-domain and the s-domain...I guess I was wrong.
I am still not clear as to what the s-domain represents.
It also seems that, as you said, the Fourier transform is the laplace transform with s = iw.
Just answer this...what does the s-domain transform of a time function describe? If I transform a time function to the s-domain and plug in a complex frequency and take the modulus, what is the meaning of the resulting number?
Better yet, what is the meaning of the resulting complex number??
I want to better understand the s-domain's meaning so that interpreting pole-zero plots is less of a game of applying memorized steps, and more of a game of intuituition and understanding.
Let me know when you figure this out!
The pole-zero plot, as advertized, tells you the locations of poles (where the gain goes to infinity) and zeros (where the gain goes to zero) of some transfer function in the s-domain. If the real signal is causal, the region of convergence (ie, the portion of the complex plane where the Laplace Transform exists, or does not blow up) is the right half-plane bounded by the line Re(s)=c, where the real signal is given by f(t) = A*exp(ct)*u(t), where u(t) is the Heaviside-step function (the transform of the above signal is simply 1/(s-c), and has a pole at s=c). If there are multiple poles, the region of convergence is the intersection of each of the individual regions of convergence. [I'm guessing you've covered most of this in your classes and am only skimming through it. Feel free to make me walk the walk step by step, though I don't promise I can - I've never learned this stuff formally.]
Now, the only thing that I've learned to take away from this is a question of determining stability - are there frequencies where the system is unstable? To answer this, what I do is see if the y-axis (or the imaginary axis, or the frequency axis) in the s-plane in included in the region of convergence. If it is, I have a stable system. And that's as much as I have a feel for - but there's folks here, like RBJ or Berkeman (I imagine) who probably eat and breathe this stuff daily.
Edit: You might have better luck if this were moved to either EE or to Calc & Analysis.
Well, I learned a little in circuit analysis, but I've only had one lecture in my controls class, so I am very new to this stuff too. :-p
You will use poles and zeros to design controllers later in your controls course. Techniques like pole placement, etc, help you design filters and controllers that are stable and meet certain specifications such as percent overshoot, settling time, etc.
When you have a transfer function, G(s), for example - you have ZEROS/POLES (that is, zeros over poles). The roots of the denominator are your poles and the roots of the numerator are the zeros.
Some important things to remember: Pole must ALWAYS be on the left hand side of the complex plane. If you have right side poles/zeros, you're system will be unstable. There are a lot of methods to fix this.
You generally design and place your controllers poles based on specifications. You will generally be given specs in the time domain such as settling time and percent overshoot - or specs in the frequency domain such as bandwidth requirements and disturbance rejection.
Complex poles/zeros are fine, and very common as they are related to your specs, but always make sure they are on the left side of the complex plane.
I hope this clears up some basic ideas.
it's about the best way to say it. the way i like to say it is that the bilateral Laplace Transform (bottom limit of integral is -\infty) is a generalization of the Fourier Transform or that the F.T. is a "degenerate case" of the bilateral L.T. (Fourier was such a degenerate :rolleyes: ) where the real part of s is zero.
it's a transform, similar to how the logarithm works on (positive) numbers. the logarithm transforms a multiplication problem into one of addition and transforms a exponential power problem into one of multiplication. the L.T. transforms a linear differential equation problem into an algebraic problem of solving a polynomial equation.
if you want to understand more deeply the sort of pedagogical train of thought, assuming you know your sines and cosines well, start with Fourier Series (particularly the representation with complex exponentials) and then, for a fixed and truncated function (that gets periodically extended so you can use F.S. on it) then let the period (which goes from -T/2 to +T/2) go out to infinity. your F.S. becomes a F.T. then try to (easily) compute the F.T. for the (heaviside) unit step function: you'll see you can't get the integral to converge until you add a little \sigma to the j \omega. generalizing that is the L.T.
that's essentially how i understand it on the fundamental level.
okay, if you have a linear, time-invariant system (the LTI condition is required, if you want to do L.T. to it), purely from the fact that it is linear and time-invariant (forget about Laplace for the time being) the output y(t) of such a system can be computed, in general, from the input x(t) and the system's "impulse response" h(t) from:
y(t) = h(t) * x(t) \equiv \int_{-\infty}^{+\infty} x(u) h(t-u) du = \int_{-\infty}^{+\infty} h(u) x(t-u) du
and when you L.T. both sides, you get:
Y(s) = H(s) X(s)
and, in the "degenerate case" of the F.T. it's
Y(j \omega) = H(j \omega) X(j \omega)
now, if you were to drive the input of this LTI system with a sinusoid in the form of a complex exponential
x(t) = e^{j \omega t}
then, using the convolution integral above, you will see that the output is:
y(t) = h(t) * e^{j \omega t} = H(j \omega) e^{j \omega t}
or
y(t) = |H(j \omega)| e^{j \arg(H(j \omega))} e^{j \omega t}
or
y(t) = |H(j \omega)| e^{j (\omega t + \phi)}
where \phi \equiv \arg(H(j \omega)).
so |H(j \omega)| is the "gain" of this system (how much it will boost the input sinusoid) and \phi \equiv \arg(H(j \omega)) is the phase shift (how much it will shift the phase of the input sinusoid).
now here are where the poles and zeros come in. if your LTI system is one where the output y(t) can be defined as differential equation that is the sum of various derivatives of the output and the input x(t) (including the 0th derivative of x(t)):
y(t) = b_0 x(t) + b_1 x'(t) + b_2 x''(t) + ... + b_M x^{(M)}(t) - a_1 y'(t) - a_2 y''(t) - ... - a_N y^{(N)}(t)
where M \le N. that differential equation can be Laplace Transformed into
Y(s)= b_0 X(s) + b_1 s X(s) + b_2 s^2 X(s) + ... + b_M s^M X(s) - a_1 s Y(s) - a_2 s^2 Y(s) - ... - a_N s^N Y(s)
and solved:
Y(s)= \frac{b_0 + b_1 s + b_2 s^2 + ... + b_M s^M }{1 + a_1 s + a_2 s^2 ... + a_N s^N} X(s) = H(s) X(s)
and factored:
H(s) = \frac{Y(s)}{X(s)} = \frac{b_0 + b_1 s + b_2 s^2 ... + b_M s^M}{1 + a_1 s + a_2 s^2 ... + a_N s^N} = \frac{b_M}{a_N} \ \frac{(s-z_1)(s-z_2)...(s-z_M)}{(s-p_1)(s-p_2)...(s-p_N)}
now the gain:
|H(j \omega)| = \frac{|b_M|}{|a_N|} \ \frac{|j \omega-z_1|\ |j \omega-z_2| \ ... |j \omega-z_M|}{|j \omega-p_1|\ |j \omega-p_2|\ ...|j \omega-p_N|}
now, here is what's happening: to determine the "frequency response" of your system (how much gain there is for any general frequency \omega), you are measuring the distance that the point s = j \omega on the imaginary axis is from each zero z_m (and multiplying those distances together) and dividing by the distances that the same point s = j \omega is from all of the poles p_n (dividing by the product of all of those distances). there is also a constant gain factor \frac{|b_M|}{|a_N|} that i don't want to think about.
so, as your frequency starts out at zero and you increase it, your j \omega point starts out at the origin s = 0 and moves up on the imaginary axis. as s = j \omega gets close to any zero z_m, the gain of your system will decrease (because that distance is decreasing and you are multiplying by it). as s = j \omega gets close to any pole p_n, the gain of your system will increase (because that distance is decreasing and you are dividing by it).that is one salient meaning of how we think of poles and zeros.
if you express the transfer function in terms of partial fraction expansion,
H(s) = \frac{\frac{b_M}{a_N} (s-z_1)(s-z_2)...(s-z_M)}{(s-p_1)(s-p_2)...(s-p_N)} = \frac{A_1}{s-p_1} + \frac{A_2}{s-p_2} + ... + \frac{A_N}{s-p_N}
then the impulse response of the system is:
h(t) = \left[A_1 e^{p_1 t} + A_2 e^{p_2 t} +... +A_N e^{p_N t} \right] u(t)
(where u(t) is the unit step function) and you can then figure out that if any of the poles, p_n, move into the right half plane, that is:
\mbox{Re}\{p_n\} \ge 0
you will get an exponentially increasing term in the impulse response
A_n e^{p_n t} = A_n e^{\mbox{Re}\{p_n\} t} e^{j\mbox{Im}\{p_n\} t}
which blows up and your system is unstable.
that's the other salient meaning of poles.
Man, thanks a lot rbj. Everything you said before and after this part of your post I knew, but this last insight you provided helped a lot. Thanks.
edit: looks like our edits "crossed in the mail". so it was the influence of poles and zeros on frequency response you were wondering about. (this is not often well taught in an undergrad linear systems course.) you can also come up with a corresponding tidbit regarding phase. the angle of the same vectors that connect your zeros (and poles) to j \omega also add (and subtract) to get your phase response \phi( \omega ). same song-and-dance.
leright said:
Man, thanks a lot rbj. Everything you said before this part of your post I knew, but this last insight you provided helped a lot. Thanks.
yer welcome. there were two "insights" that you quoted that are different. one is that as j \omega gets close to a pole, you get a resonance at that frequency. the other has to do why systems go unstable as the poles move into the right half-plane. don't know which you mean. but it doesn't matter.
BTW, as you get into discrete-time systems ("digital filters") all of this is applicable but you replace convolution integral with convolution summation, s with z, Laplace Transform with Z Transform, and the j \omega axis with the unit circle e^{j \omega}. but all of that other stuff (distances to poles and zeros, partial fraction expansion, etc.) is done just the same and you get the same or corresponding results.
It seems the biggest problem I had in seeing the connections was the chronology in which the Fourier transform and the laplace transform were introduced in my curriculum.
I was introduced to the laplace transform first in circuit analysis (well, really, first in DE) because it helps in solving the complicated differential equations that arise in DC circuit analysis. It wasn't until quite a while later that I was introduced to Fourier series and transforms. Then, all of a sudden, out of nowhere it seems, they tell you that the Fourier transform is like a slice of the s-domain without explaining how the Fourier transform connects to the big picture in the s-domain world or how the Fourier transform relates to the laplace transform. The tools are not introduced in a logical order so that the connections between the tools is clear.
It seems to me that the Fourier series should be introduced first, and then the Fourier transform, which is just a Fourier series, but instead of line spectra frequencies it has continuous spectral frequencies, and the "fourier coefficients" in the Fourier transform is really a continuous function of omega describing the amplitude of the sines and cosines at all of the frequencies. The Fourier series and transform should be presented in trig form first, and then the complex form should be derived.
Once this is done, then the laplace transform should be presented as a means of avoiding the singularities that arise.
And, my original statement holds about the role reversal of the real part of complex frequency and the imaginary part when going from the time domain to the s-domain. It seems that in the time domain, the real part of freq is the sinusoidal frequency of the waveform and the imaginary part of the freq is the decay frequency of the waveform. I can prove this. And, by observation, the opposite is the case in the s-domain. Is this observation true? Can someone explain this phenomenon?
I found this to be a very informative read.
Maxwell, what is the problem with having a zero in the left half plane? I can understand why it's a problem to have a pole in the left half, because then you have an increasing exponential attached to a sinusoid of a certain frequency, where that frequency has very large character (amplitude) in the spectrum, but what's wrong with a zero over there?
You WANT your zeros in the left half plane. Sorry for not making that clear. If you have right hand zeros, you need to use something called the Diophantine equation to fix that.
oh, also, is a digital control systems class the same as a digital signal processing class?
Nope. Digital controls are usually appended onto each controls class. For example, in my Classical Controls class we covered Digital Control systems as the last unit. At the end of my Modern Controls class, we applied all the methods we learned to Digital Control. The reason for this is because in Digital Controls we basically use the same exact methods except for one major difference -- we use something called a Z-transform. There are other small differences, but those are covered as well.
You will most likely see digital control systems at the end of the class you are currently taking.
Digital Signal Processing is a different, although closely related, field. There are a lot of DSP classes, but in an intro class you'd see things like transversal and recursive filters, signal detection in different scenarios, and different types of signal/noise analysis.
yeah, he said we will do some digital control systems at the end. Hmmm...I don't think my school offers a digital signal processing course. Would this be a good directed study to do for someone interested in controls?
It definitely would. An intro DSP class would cover a lot of filter design, and that's important for a control systems engineer to know. There is cross-over between the two fields. Intro DSP classes would be a good topic for anyone to study -- not just for someone who wants to go into more advanced fields of DSP.
Are you sure that's the right name? Far as I know, a Diophantine equation is any equation where you limit yourself to integer solutions. Can't see how that helps.
Yes, I'm sure that's the name. It's an important design technique for when you have right side zeros. There might be other names for it, but my professor called it the “Diophantine technique.”
In this technique, you create a model TF that meets your specifications, and then you apply the Diophantine equation to design the controller.
The form I learned was: Dp(s)D*c(s) + Np-(s)Nc(s) = Dm(s)A0(s)
Where Dp(s) is the denominator of the TF of the controlled plant, D*c(s) is an unknown polynomial that when you multiply it by the "good" zeros of the controller will create the denominator for the feedback controller and the pre-filter, Np-(s) are the "bad" zeros of the control plant, Nc(s) is an unknown polynomial that will be the numerator for the feedback controller, Dm(s) is the denominator of the desired TF (your "model" controller), and A0(s) is an arbitrary polynomial that has left plane roots.
Here is a summary from a paper I found that explains the approach better than I can:
"“One of the features of modern control theory is the growing presence of algebra. Polynomial modules were found useful in describing the dynamics and structure of linear systems. In contrast to other approaches, in particular to those based on state space and trajectory behavior, these results revived the interest in fractional representations of transfer functions. In this approach, the transfer function of a system is regarded as an element of the field of fractions associated with an appropriate ring, depending on the system’s property to be studied. The property then corresponds to a divisibility condition in the ring. As a result, the mathematical synthesis of a control system having a desired property leads to the solution of a linear Diophantine equation over that ring."
  • · Replies 31 ·
11K
  • · Replies 17 ·
  • · Replies 18 ·
9K
