Measuring distance of rotating object
  • Thread starter Thread starter Chynkinese
    Measuring Rotating
The discussion revolves around measuring the distance from a stationary point to a moving object that is rotating uniformly in a circle at an angle to the horizontal plane. The participants explore various methods and considerations for achieving accurate measurements, particularly in the context of a rotating system with potential elongation of the string used to connect the object.
  • Experimental/applied
  • One participant describes a method using a ruler with a pointer to measure the distance, noting potential inaccuracies of +/- 1cm to 2cm.
  • Another participant questions whether the distance is measured from the axis of rotation or an arbitrary point and asks about the required data refresh rate.
  • A participant clarifies that the measurement is from the axis of rotation and mentions the use of a motor from a power drill for steady rotation.
  • One participant suggests that if measuring from the axis, the distance to the object could simply be the length of the string, but another points out that the string elongates during rotation, complicating the measurement.
  • One idea proposed involves projecting the shadow of the moving object onto a white background to measure the distance to the pivot.
  • Another participant mentions that a hand calculation based on rotating velocity and mass could yield results comparable to physical measurements, suggesting a method to find elongation through stress and strain calculations.
  • Concerns are raised about the difficulty of determining Young's Modulus for the strings being used, which is necessary for stress-strain calculations.
  • A later reply proposes an experimental approach to determine Young's Modulus by hanging a weight from the string and measuring deflection.
Participants express a range of ideas and methods for measuring the distance, with no consensus on a single approach. There are competing views on the accuracy of different measurement techniques and the implications of string elongation.
Participants note limitations related to the accuracy of measurements, the need for specific equipment, and the challenges in determining material properties like Young's Modulus for the strings used.
Chynkinese
Please ignore the periods in the diagram as it won't allow me to properly draw it otherwise.
I have an object, attached to a string, rotating uniformly in a circle but at an angle to the horizontal plane. It is going at 80RPM (so relatively slow). How would one go about measuring the length from stationary point o to moving object a? the length can range anywhere from 40cm to 70cm and the accuracy for the measurement should IDEALLY +/- 0.5cm (doesn't mean it has to since real life is never ideal).
ie......o
...a
Nothing can be attached to "a" unless it is extremely light (such as reflective tape for a laser or something).
I have a very simple idea but the accuracy is easily +/- 1cm to 2cm or so. It's a simply ruler with a pointer attached and I slide it as close as possible. And I do the same for the vertical (either that or I measure the angle, whichever is more accurate). It goes something like this:
ie...___Ruler___o
...V./
...a
I thought about using a laser somehow but I can't seem to find any equipment suitable for this.
Is the distance your measuring from the axis of rotation or arbitrary? How quickly do you need the data (refresh rate)?
Is the rotation steady?
What type of equipment do you have at your disposal?
I'm measuring from the axis of rotation (axis goes vertically through point "o").
Rotation is assumed to be steady; it is done by the motor taken from power drill and fed by a lab DC power supply which is kept at a constant amperage and voltage.
I have access to me equipment that is usually available in a well equipped lab. As well, I am free to order any other necessary parts. Granted, I'm not ordering thousands of dollars worth just to test a theory.
Well, if you're measuring from the axis of rotation, then isn't the distance to the object simply the distance of the string that you used to connect it?
The problem is the string elongates during rotation and we need to know by how much.
Can you project the shadow of the moving object onto a white background. Mark the location and measure the distance to the piviot with a ruler. The light would need to be in the plane of the rotating object.
If the rotation is steady, then a hand calculation would probably get you just as close as any measurement. Take your rotating velocity and mass and find the tension that is generated in the string. Find the stress->strain and then elongation.
That's an idea...I could give that a try but I don't know how accurate it'd be.
I thought about that. But the stress->strain requires Youngs Modulus does it not? I don't think it'd be possible to find the modulus for the strings I'll be using. :S
Then do an experiment. Hang a weight from the string and measure the deflection. Boom, Young's modulus (or at least a very good number for you to use).
  • · Replies 52 ·
  • · Replies 40 ·
9K
  • · Replies 26 ·
  • · Replies 20 ·
