Measuring distance, speed and clock
114 replies · 12K views
Stephanus said:
Finally...:oldeyes:As long as the clock moves along with the observer, right?I want to ask something here.
Okay,... Blue and green move at the same velocity.
1. Can we say that blue and green are at the same frame of reference?
2. G2 will see Blue as B2, and B1 will see Green as G1, is this true?
3. If number 1 is true, can Blue use Green time as proper time?
Thanks.
It is not strictly true to say that something is 'in' a frame of reference. The whole world covered by the coordinates is 'in every frame'.
Green and blue are comoving, They have zero relative velocity, ##\gamma=1## and so their clocks and rulers are the same..
From your diagram we can say that if green sends a beam of light to from G1 to blue, it arrives at event B1. If blue sends a beam from B2 it arrives at event G2.
This scenario tells you more. You can see a symmetry between green and blue because the are comoving. From any frame the times on the clocks of green and blue at all the events will be the same, 0 for B2 and G1, and 6 for B1 and G2. All proper times are invariant.
Dear PF Forum,
Thanks for any helps for me so far.
But I still have questions, that I need confirmation.
If we have two observer (B) Blue and (G) Green.
- They are at rest,
- Clocks are synchronized (is this related to our discussion? I don't think so, but I'll write anyway)
- Then at a preagreement time, G moves toward B at 0.6c ##\gamma = 1.25##
What is the correct way to draw the ST diagram?
or
Because "they" said that for the moving object the length is contracted, but then again I remember
harrylin said:
A little elaboration: suppose that at CERN in Geneva a particle is accelerated to 0.99999c in the direction of Lyon. Does that contract the distance between Geneva and Lyon?
or
I purposedly add the wider green world line (see red circle), because "they" said that for a moving object, there is simultaneity of event. So the "distance between Geneva and Lyon is not contracted", but Green does have already moved several distance when Blue receive event G, see the wider green line.
And in Picture 4, I tried to draw light rays, but there is something that doesn't make sense.
I drew light cones for events on Green world line, namely
G-3, G-2, G-1, G0, G+1, G+2, G+3. Each one representing each second for Green. And each event on green world line corespond to Blue world line
G-3 -> B-3
G-2 -> B-2
G-1 -> B-1
G -> B
G+1 -> B+1
G+2 -> B+2
G+3 -> B+3,
But if Green moves, it seems that even if G-1, takes place before G+1, but B+1 takes place before B-1. Where did I go wrong?
Please see the zoomed picture 4b.
I could have quoted Sherlock Holmes dictum, "If you leave all the impossible, the remains however improbable is the correct answer", then I'll choose Pic 1. But then again, where is the length contraction in Pic 1?
Thanks for any help
Stephanus said:
So, I want to ask something here,
-"The faster a system travels, the slower its internal processes go."
-"Proper time is also called clock time, or process time, and it is a measure of the amount of physical process that a system undergoes"
But for the system itself, its one second is still one second right? All we know for 1 second is the tick of the second hand that moves 60 at our desk, altough as I have often heard in this forum, we are traveling near the speed of light according to LHC.
Do I get it right?
Yes you got it right. :smile:
Note however that you have put only part of a phrase in bold, the phrase is wrong for SR:
in classical physics we can define: Coordinate time = Proper time for all natural systems.
Stephanus said:
Dear PF Forum,
- They are at rest,
Yes, that is the correct diagram.
After that I cannot understand what you are doing. It is alarming that you still think the objects are moving in the time direction. Have you tried the 'Animate' feature ?Length cotraction is the projection of the x'-axis in the x-axis. I'll try to do a diagram.
[Edit]
My diagrams are wrong. I cannot show length contraction on the diagram right now.
Thanks
I do animate feature before, but not for this. Now I have. But I can't still make it sense. But your previous answer has explained enough for me. Now I know the correct diagram.
It's okay. Take your time
Stephanus said:
ThanksI do animate feature before, but not for this. Now I have. But I can't still make it sense. But your previous answer has explained enough for me. Now I know the correct diagram.
The diagram you sent me does not agree with your scenario. Pic 1 of post#62 is correct, if green is one object.
The x-axis is like a long straight street. One can only move up the street or down the street. The time axis shows the clock-times for the clocks in the street.
You seem to be making it complicated when it is simple.
You are also jumping around again. Length contraction is taken care of by the LT. Leave it until you understand ... something.
Thanks Mentz, for your clarification.
Actually these are my diagrams. Those are without light rays.
ST-01 is for Pic 1, and ST-02 is for Pic 2.
There is something very wrong. When I load those diagrams they look fine. But when I boost with 'match speed' - it boosts with v instead of -v !
Also when I try to animate it is as if the worldlines do not exist - the animation is empty.
If I plot a similar diagram - it works fine. Please try loading this and try 'animate'. I'd like to know what happens. In the meantime don't believe anything the plotter is doing.
"Don't believe anything the plotter is doing??"" Oh, I'm so sorry Mentz114. It's not a bug.
I edited the text file!
This software is very good, but what troubles me is the resolution. So, I worked out the coordinate in Microsoft Excel and I edit the text file, and I load the text in the plotter.
For x coordinate it is 300 + x*20
For t coordinate it is 300 - t*20
Then I get the picture, then I save it to bitmap.
It's completely my fault. I'm afraid it's the resolution.
Again, my bad quoting habit. Next time, I'll try not to mislead the meaning of a paragraph. Thanks harrylin.
Yes, I worked out that you hacked the file. You swapped the start and end points - but the software always rearranges them when you create the wl. The program got the velocity reversed because the endpoints were swapped after creation.
Please don't hack the saved files. You can delete a worldline if you right-click on it.
I hoped the animation would help you to see that each horizontal line is a time-slice, and the objects on slanted lines will change position in each slice.
not "hack", please. But "editing". And I think there's a bug in deleting an event. Suppose we have 5 events,
ev1, ev2, ev3, ev4 and ev5. If we delete for example ev4 then ev1 is deleted, not ev4, and if delete ev4 for the second time, ev2 is deleted. That's why I deleted the text manually.
I haven't observed transformation just watched. I just use it to draw wl and light ray and event. It's a very good software, it helps me very much. Thanks.
[EDIT] For now, but later, I think I have to study at least acceleration wl
- They are at rest,
- Then at a preagreement time, G moves toward B at 0.6c γ=1.25\gamma = 1.25
Picture 2 is obviously wrong. In it the green line is discontinuous. That means that green disappears from one location and reappears at another location. You are saying that turning on a rocket engine causes not only acceleration, but also teleportation.
Teleportation :oldlaugh:, Now that's funnier than
Thanks DaleSpam, Mentz114 has already answered me. #64
pervect said:
However, you can work out this formula for yourself following Bondi's apporach, simply from knowing that "k" exists. Suppose observer A is approaching observer b. At some time 1 second before they meet, A sends out a signal which B receives at a time k seconds (k<1) before they meet. B retransmits the signal, which is received by A, at a time k^2 seconds before they meet.
Example - if k=1/4, then A sends a signal 1 second before meeting, B receives this signal 1/4 = .25 seconds before they meet, and retransmits it. A receives the return signal 1/16 of a second before they meet.
From this exchange of signals, plus the knowledge that the speed of light is constant in his frame, A can compute the velocity relative to B as follows:[..]
I don't quite sure, but I think "A receives the return signal 1/16 of a second before they meet" is wrong.
I tried to work it out:
https://www.physicsforums.com/attachments/85844
Okay,...
The picture is not in scale to avoid measuring the distance to find the answer.
F1: "Suppose observer A is approaching observer b. At some time 1 second before they meet, A sends out a signal which B receives at a time k seconds (k<1) before they meet. "
At E0 A emits a signal to B 1 second before they meet. So L1 distance is VA * 1 sec
F2: "Example - if k=1/4, then A sends a signal 1 second before meeting, B receives this signal 1/4 = .25 seconds before they meet..."
So, B is receiving the signal at ##1 sec - 0.25 sec = 0.75 sec## after A sends the signal.
So L1 distance is 0.75 ls.
Combining F1 and F2, so Va is 0.75c, because it takes 1 sec for A to travel to B0.75c
So I want to work out, what is E1 distance from E0.
Supposed: E1 is A position when the light reaches B, see F2. So it takes 0.75 sec for A which travels at 0.75 c to reach E1.
So E1 is 0.5625 or ##\frac{9}{16} ls or \frac{63}{112}##
F3: "B receives this signal 1/4 = .25 seconds before they meet, and retransmits it. A receives the return signal 1/16 of a second before they meet."
So, when A is at E1, B retransmit the signal.
Supposed A meets the signal at E2. To answer that we have to calculate L3 and L4
We know that ##L2+L3+L4 = 0.75 ls = \frac{12}{16} or \frac{84}{112}##
##L2 = \frac{63}{112}##
So ##L3+L4 = \frac{21}{112}##
A travels at 0.75c and light travels at c.
So combining both,
##t = d/(v+c)##
##t = \frac{21}{112} / 1.75 = \frac{3}{28}##
I think A will not receive the signal 1/16 before they met, but at ##\frac{3}{16}-\frac{3}{28} = \frac{9}{112}## seconds.
Or perhaps my calculations are wrong?
Or my understanding is wrong?
Oh, no. The attachment failed. Ok, I ask again my question.
This is my picture. Again, not to scale because at first we (I) didn't know what their positions, so we have to calculate every point. This picture just makes us easier to do the calculation.
Okay,...
"Example - if k=1/4, then ..."
F1: ##k = 0.25##
F2: "At some time 1 second before they meet, A sends out a signal" A sends the signal at ##E0##, ##L1 = V_A * 1 sec= V_A##, for simplicity the second ##V_A## is not a velocity, but a distance.
F3: "B receives this signal 1/4 = .25 seconds before they meet", supposed B received the signal when A is at ##E1##, so ##L3+L4 = \frac{1}{4}V_A##
F4: "B receives the signal and retransmits it. A receives the return signal 1/16 of a second before they meet." Supposed A received the signal when A is at ##E2##
F3: B receives the signal at ##0.25 seconds## before they meet, or ##1-0.25 = 0.75seconds## after A sends the signal.
So length ##L1 = 0.75c##
So ##V_A = 0.75c##
F3: ##L3+L4 = \frac{1}{4}V_A = \frac{3}{16}##light seconds
So A travels at 0.75c and c travels at -c. The will meet at E2
Again, not to scale.
##L3+L4 = \frac{3}{16}##
The time it takes for A to reach E2 (or C reaches E2) is
##\frac{L3+L4}{V_A-C} = \frac{3}{16}/1.75 = \frac{3}{28} seconds##
The time for A from E2 to reach E3 is ##\frac{7}{28}-\frac{3}{28} = \frac{1}{7}## seconds.
Did I do it right?
Do I understand the problem correctly?
Stephanus said:
Okay, today I learned that
are actually the same. And we can use the same formula to calculate them.
##k=\sqrt{\frac{1-\beta}{1+\beta}}## or ##k=\sqrt{\frac{1+\beta}{1-\beta}}##
I don't understand the diagrams.
This is a clip I made some time ago that might help to understand the Doppler effect. The moving object emits light pulses at a regular frequency and the two stationary observers detect the frequency to be different. The script is attached and you should get the same result if you do an 'animate' of this.
Wow, thanks Mentz114. I have had this file a month ago. At least the movie not the text file. You sent me. Of course I didn't get the text file, just the representation graph and the video. How can STPlotter make the video out of it?
Btw, what I mean about my picture is this.
I kept imagining that B sends a signal for every, say, 10 seconds. And if B moves toward A, A will receive the signal less then 10 seconds.
And the good advisors/mentors/members kept saying about sending light and blue shifted and red shifted.
What I didn't realize was, both were the same.
Sending signals for every 10 seconds is the same as, for example, sending a green light.
But in green light case, you'll send signal for every 540 pico seconds.
https://en.wikipedia.org/wiki/Color#Spectral_colors
That's what keeps holding me understanding their answers.
But thanks anyway for your responses. I'll read the previous post' again.
I forgot that I'd sent this earlier. The frames can be saved and a video making program used to join them into a clip.
Yes and no. The receiver detects the time gap between signals. The transmission time is not important. And a detector moving away sees the gap as more than 10 secs.
Blue shifted means the frequency is increased and the wavelength is decreased. Red shifted means the reverse.
Yes. The colour we perceive depends on the frequency of the light wave hence 'red' and 'blue' shifted.
It is similar for gaps between pulses. That is how ground-based radar can detect the speed of a vehicle.
I hope it is clearer.
Just like in Franhover lines? (or Frauhover, I forget the exact name)
Thanks for the respond Mentz114.
Perhaps you can understand my confusion.
At first I tought that:
1: B burst a signal every 10 seconds.
While all the answers sugest that
2: B sends colored light, for example Green. Or B sends signal very but not at 540 pico seconds as I mistakenly wrote above. 540THz is the frequency, so B actually sends signals every ##\frac{1}{540E12} = 0.0018 pico seconds##
Conclusion:
1: B burst a signal every 10 seconds (any color)
2: B burst an EM wave signal every 0.0018 pico seconds (Green light)
Conclusion: The logic is the same.
And if B moves toward A, the signal is blue shifted. Perhaps the frequency can rise to 500 THz at the orange range?. Forgive the pun.
Suppose B sends a radio signal, like WWV, that has a 10 Mhz frequency, but is also amplitude modulated at 1khz. Then we can say that both the carrier frequency and the modulation frequency are red/blue shifted by the same amount due to doppler effects. This follows from the fact that at the transmitter, the ratio of the modulating frequency to the carrier frequency is 10,000:1, and the fact that this ratio is expected to be constant even if the carrier is red or blue shifted.
It doesn't really matter what the details of the modulation are. We can generalie from the above example with a sinusoidal carrier and a sinusoidal modulation signal to "bursty" modulation once every 10 seconds (.1 hz). The point is that the carrier signal and the modulating signal will both be red/blue shifted by the same amount, this is necessary for logical consistency.
[add]
It might be easier to explain this way. Suppose we send out "bursts" each of which contain 1000 carrier pulses. Then everyone will agree that there are 1000 pulses in a burst, even if they don't agree about the carrier frequency due to the doppler effect.
Finally, pervect...
Yes, I understand.
Yes
pervect said:
It doesn't really matter what the details of the modulation are. [..]The point is that the carrier signal and the modulating signal will both be red/blue shifted by the same amount, this is necessary for logical consistency.
Yes
pervect said:
[..]Suppose we send out "bursts" each of which contain 1000 carrier pulses. Then everyone will agree that there are 1000 pulses in a burst, even if they don't agree about the carrier frequency due to the doppler effect.
Yes
But, pervect, can I ask you about your previous post? About sending a signal where k = 1/4. I think there's something not match there. Or the mistake is mine. It is in https://www.physicsforums.com/threads/measuring-distance-speed-and-clock.821115/page-4#post-5167834
Stephanus said:
Finally, pervect...
Yes, I understand.YesYesYes
Yes, there's a problem, which I'd describe as you not taking into account the fact that simultaneity is relative and the effects of time dilation. A's watch and B's watch keep different time. This means that A's watch and B's watch read different times, we have to be careful not to conflate them.
The sequence of events from A's point of view goes like this:
A sends a signal at -1 second (1 second before impact) according to A's clock. A receives a return signal at -.0625 (-1/16 a second) according to A's watch. The returned signal from B is conveniently timestamped with B's time reading. B's clock reads -.25 seconds. But A knows not to confuse the reading on B's clocks with his own readings.
A considers himself at rest in his own frame, with B moving towards him. A knows that the time it takes for the signal to reach B is equal to the time that the signal takes to return from B. Interpreting his radar results, A concludes that the round-trip time for the light/radar signal was (-1/16 - (-1)) seconds, i.e. the round trip time was 15/16 seconds, which implies that the one-way trip time was 15/32 of a second.
A computes the time in A's frame that B received the signal as the start time (-1 second) plus the one-way travel time (15/32 of a second), for a result of -17/32 seconds, i.e. -.53125 seconds
This is obviously different from the time B assigned to the same event. If A is familiar with special relativity, he expects this - he expects B's clock to be running slow, and it is - just as much slower as predicted, reading only -.25 seconds rather than -.53125 seconds.
It may help to draw a space-time diagram of this.
Now, for the velocity. A meets B at 0 seconds, and A knows that at the time B received the signal (-.53125 seconds), that B's distance was c multipled by the one-way travel time, i.e 15/32 seconds * c, c being the speed of light. Recall that the speed of light in A's frame must be constant an equal to c in A's frame on both the outgoing and ingoing trip.
So A computes B's velocity as the distance, (15/32) light seconds dived by the time it takes for A to reach B, (17/32) seconds, thus B's velocity was 15/17 of the speed of light.
It might be easier to work out a closely related problem where all the times are integers - or to use algebraic variables. Using the former approach (integers), we can imagine A sending a signal at 16 seconds before impact (by A's watch), and receving the echo at 1 second before impact (by A's watch).
Thanks pervect for your answer.
pervect said:
A receives a return signal at -.0625 (-1/16 a second) according to A's watch. The returned signal from B is conveniently timestamped with B's time reading. B's clock reads -.25 seconds (add: according to B's watch).
Ahh, that makes a big different. Okay, I'll start again.
It takes 1 second for A to travel L1 distance. Supposed A speed is V, then ##L1 = V##, A receives the return signal at 1/16 seconds, ##L4 = \frac{1}{16}V## Light travels at ##V+\frac{1}{16}V = \frac{17}{16}V distance##
A travels at ##\frac{15}{16}V## distance. So A speed is ##V = \frac{15}{17}c## Okay,... Conform your calculation
pervect said:
[..]thus B's velocity was 15/17 of the speed of light.
Motion is relative, right. It's A who's at rest and B travels.
##\gamma = \frac{1}{\sqrt{1-V^2}} = \frac{1}{\sqrt{1-\frac{15^2}{17^2}}} = \frac{1}{\frac{8}{17}} = \frac{17}{8} = 2.125##
The signal will reach B according to A clock at ##\frac{2}{17} seconds## before impact. Because B travels at ##\frac{15}{17}c##, so, B clock according to B is
##\frac{2}{17}*\frac{17}{8} = \frac{2}{8}## Gosh, the number match!
But I still can grasp it intuitively. I'll study it again. Thanks pervect.
Now, go back to Post #17
Here is a diagram of the above ( nearly). Between A (blue) and B(green) we have ##\gamma=2.13##. The grid scale is (As coords) 1sec = 20 grid units.
The light is sent 1 sec before they meet ( interval AR ) and the light returns at t=0.63 s before they meet ( interval RD).
The time on Bs clock when the light arrives can be read off as about 4.85/20 secs assuming synchronization at t=0 (A time).
This seems to agree close enough with Pervects (and your) numbers.
What?? You beat me by one hour
What do you mean ?
[edit]
I get it. Sorry.
Your diagram gives the same results but with a bit more error because it is less than half the scale of mine.
Well done. You now have the relevant times calculated by two methods. I prefer the diagram way.
Mentz114 said:
What do you mean ?
[edit]
I get it. Sorry.
Well, if you know me. I calculate the speed ##\frac{15}{17}##
The easiest way to do it is to put some point at 15 at the x-Axis and 17 at the t-axis. Calculate all those by spread sheet. I have the formula now, for world line, light and event. Open load project at STPlotter, see if I made a "bug". What is holding me, is the coordinate for light differs than world line. X in light is T in world line and vice versa. Depends on the speed 1 or -1. So does the coordinate for event is t,x not x,t as in wordline. That's why I didn't calculate it from 20 units as you do. This is my data:
Code:
[B]
Name  X          T        X          T
W0    0.0000 -3000.0000   0.0000  3000.0000; A world line
W1 1500.0000     0.0000   0.0000  1700.0000; B world line
E1    0.0000     0.0000
E2 1500.0000     0.0000
E3  796.8750   796.8750
E4    0.0000  1593.7500
E5    0.0000  1700.0000
L0    0.0000     0.0000 796.8750  796.8750
L1  796.8750   796.8750   0.0000 1593.7500[/B]
Scale it down by 200, convert it to screen coordinates.
Code:
Name    X             T                 X           T
W0    300.000000    600.000000        300.000000    0.000000
W1    450.000000    300.000000        300.000000  130.000000
E1    300.000000    300.000000
E2    300.000000    450.000000
E3    220.312500    379.687500
E4    140.625000    300.000000
E5    130.000000    300.000000
L0    300.000000    300.000000        379.687500    220.312500
L1    220.312500    379.687500        300.000000    140.625000
Add the necessary code for STPlotter and save it to ST-01.txt. Actually I like the combination of both. Calculate the numbers on spread sheet, convert it to world line, light or event code and save it to text file and load it to STPlotter.
That is interesting but it shouldn't be necessary. I can use the mouse interface to draw any worldlines in a few seconds.
