Measuring photon polarization and finding observable operator
The discussion revolves around measuring photon polarization using an apparatus with specific properties related to the output for different polarized photon angles. The subject area includes quantum mechanics and linear algebra, particularly focusing on eigenvalues, eigenstates, and operator matrices.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to identify eigenvalues and eigenstates based on the apparatus's behavior with polarized photons. Some participants question the definitions of eigenstates and projection operators, while others explore how to incorporate additional properties into the operator matrix.
Participants are actively engaging with the concepts, providing clarifications on eigenstates and discussing the implications of linear combinations. There is a focus on understanding how to construct the operator matrix from the eigenbasis, with some guidance offered regarding the relationship between the eigenstates and the matrix representation.
There is some uncertainty regarding the treatment of the third property of the apparatus and how it relates to the operator matrix. Participants are navigating the complexities of quantum state representation and the implications of linear combinations in this context.
doublemint
An apparatus has these properties when measuring a polarized photon:
-whenever a linearly polarized photon at angle \vartheta enters apparatus, it displays "2"
-whenever a linearly polarized photon at angle \frac{pi}{2}+\vartheta enters apparatus, it displays "3"
-for all other polarizations other than above, it displays 2 or 3 with random probabilities.
1. Find the eigenvalues and eigenstates.
2.Find the matrices of of operator A in its eigenbasis and |H> |v> basis.
So for part 1, I believe the eigenvalues are 2 and 3. Then the eigenstates are |\vartheta><\vartheta| and |\frac{pi}{2}+\vartheta><\frac{pi}{2}+\vartheta|.
However, I am not sure how to find the eigenvalues and eigenstates for the third property of the apparatus. I probably has to do with the same eigenvalues but the states I am not sure of.
As for part 2, I do not understand it.
So any help would be appreciated!
Thank You
DoubleMint
those aren't the eigenstates what you wrote down those are projection operators. The eigenstates are simply
\left| \theta \right\rangle , \left| \theta +\frac{\pi}{2} \right\rangle
whilst the third property is simply linear combinations of the two states
\Psi = \alpha \left| \theta \right\rangle + \alpha&#039; \left| \theta +\frac{\pi}{2} \right\rangle
where
\left|\alpha \right| ^2 + \left|\alpha&#039; \right| ^2 = 1
the matrix of an operator is given by
A_{ij} = \sum_{i,j=1}^{number of sates} \left\langle \psi_i \right| \hat{A} \left| \psi_j \right\rangle
Thanks for the reply sgd37. Now, how do i incorporate the third property into the matrix operator?
you only need the eigenbasis to define the matrix operator. Is that what you meant
No, I mean how do you find the values associated with the linear combination of the third property in the operator matrix. I can find the values for projection operators of \vartheta and \frac{pi}{2}\vartheta which should be 2 and 3 respectively.
There are no values in the matrix associated with the linear combinations. And there is no way of predetermining the states
For the two states you can determine the operator matrix
A= \begin{pmatrix}<br /> <br /> 2&amp;0\\<br /> 0&amp;3 \end{pmatrix}
for which the eigenvectors are
\left| \theta \right\rangle = \begin{pmatrix} 1\\ 0 \end{pmatrix} , \left| \theta +\frac{\pi}{2} \right\rangle = \begin{pmatrix} 0\\ 1 \end{pmatrix}
the linear combinations just determine a general vector in R^2
I never knew that...interesting. Thanks a lot sgd37!
