Mechanical leverage to increase length?
5 replies · 4K views · last reply
manp
Hi
Im trying to increase the length of a movement of a rope so when one rope is pulled the other rope movement is increased x 2 (it is attached across). So far i have tried gears whice has somewhat worked but it increases the force as well. Is there any other way to achieve this amplification with the same force?
manp said:
Hi
Sorry, no, that would violate conservation of energy.
The energy expended will be proportional to the distance moved, multiplied by the force applied.
Conservation of energy requires that the force * distance product remain equal for the input and output.
Twice the force over half the distance is a possible solution using a mechanical system.
Thanks for the replies...i thought there'd be np solutions. Is there any other way except gears, levers? With minimal friction, energy loss?
Baluncore said:
A bicycle chain over a movable sprocket, or an endless chain, differential pulley.
http://en.wikipedia.org/wiki/Differential_pulley
Fluid coupled hydraulic cylinders, with different cross section cylinders to set the ratio.
Thanks for the ideas, I've tried all of them
but there's too much friction and energy loss I am creating.
