How Do You Calculate the Radial Force on a Hinged Stick?
  • Thread starter Thread starter justagirl
    Mechanics
The radial force exerted on a hinged stick is calculated using the formula F = Mg/2*(5 cos θ - 3 cos θ₀), where θ is the angle of the stick with respect to the vertical after release and θ₀ is the initial angle. The discussion highlights the importance of using the correct coordinate system, specifically that all sine functions should be replaced with cosine functions when dealing with angles from the vertical. Additionally, the moment of inertia for the stick must be included in energy calculations to accurately determine forces. The tangential force is derived as F_tangential = mg sin θ, clarifying discrepancies in previous calculations.
  • Understanding of basic mechanics and forces
  • Familiarity with the concepts of torque and moment of inertia
  • Knowledge of energy conservation principles in physics
  • Ability to work with trigonometric functions in the context of angular motion
  • Study the derivation of the moment of inertia for different shapes, particularly rods
  • Learn about angular motion equations and their applications in mechanics
  • Explore the relationship between radial and tangential forces in rotating systems
  • Investigate the use of energy conservation in dynamic systems involving hinges and pivots
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rotating bodies and forces acting on hinged systems.
justagirl
Mechanics...PLEASE HELP VERY SOON!
Can someone please help me with this problem? I've been working on it for hours - anything would help thanks!
A system consists of a uniform stick of length L and mass M hinged at one end. The hinge is released from rest at an angle theta_0 with respect to the vertical. Show that the radial force exerted on the stick F = Mg/2*(5 cos theta - 3 cos (theta_0), where theta is the angle of the stick with resect to the vertical after it is released.
I tried to solve the problem using conservation of energy.
I said potential energy is equal to the height that the center of mass has fallen, so I got:
[(L/2)(sin_theta - sin theta_0)]Mg = 1/2Iw^2 = (1/2)(1/3)MR^2*w^2
((L/2)sin_theta - sin theta_0)g = (1/6)R^2w^2
[3L (sin_theta - sin theta_0)g] / R^2 = w^2
v = wr, v^2 = w^2 * r^2
v^2 = [3L (sin_theta - sin theta_0)g]
F = Mv^2 / R, which is not what they had.
HELP!
Here's a couple of points that might help:
First, your coordinate system is not quite right. The problem is posed in terms of the angle with respect to the vertical so all your sines should be cosines.
Second, you're not dealing with a point mass so you will need the moment of inertia for the stick in your energy calculation.
Finally, the radial force on the stick consists of two parts. One is the component of the gravitational force along the stick and the other is the reaction force of the hinge which is the negative of the centripetal force.
Putting it altogether I get:
F_r = mg\cos \theta - \frac {mv_{\theta}^{2}}{L/2}
You should find
\frac {mv_{\theta}^{2}}{L/2} = \frac {3mg}{2} \left(\cos \theta_0 - \cos \theta \right)
and the correct result follows.
thanks
Everything did come together. Thank you for your help!
Suppose now that I want to calculate the tangential force.
I set torque = I(alpha) = F(R)
F = I(alpha) / R = (1/3)ML^2*(a/R) / R
F = (1/3)ML^2*((g sin_theta)/(L/2)) / (L/2)
I got that F_tangential = 4/3Mgsin_theta, but they got that the answer
is 1/4 Mg sin_theta.
What did I do wrong? Thanks!
The tangential force should be mg \sin \theta. It's not clear what they did to get the 1/4.
  • · Replies 21 ·
  • · Replies 21 ·
