Mechanism for vertical movement while rotating horizontally
1 reply · 5K views · last reply
Arun John
Hi I am trying to make a CAD model of something like the scoop sampler shown below.
http://www.rolls-royce.com/~/media/...tomers/nuclear/scoop-sampling-tcm92-50918.pdf
This is for a university coursework that requires design of bespoke machines. I am trying to design a machine that can literally scoop out a 1 mm thick sample from any aerospace component. My intention is to use a motor to rotate the shaft which is connected to the cutter (with abrasive particles to cut through metal).
Pencil sketch of a scoop sampler design: a cylindrical cutter with abrasive particles on its edge, labelled 1mm, on a shaft connecting to a motor housing labelled motor.
See this would initiate the cutting and only cut at the controlled depth (based on the dimension of the cutter) but how can I possibly make the cutter to eventually go up? (lets say after 35 - 40mm length I want the cutter to make a vertical movement so that it scoops out). To clarify I want the final metal scoop to be roughly 40mm long, 20mm wide and max thickness of 1mm. So once it reaches around 35mm how can I make it go up vertically while the shaft and cutter is rotating in the horizontal axis?
Finally what if I don't have a flat surface. Imagine if I have a concave surface. I have some ideas but I can't seem to get through these initial problems.
