Undergrad Mechanism of Energy Conservation in Zero-Amplitude Sum of EM Waveforms
Two coherent electromagnetic wave pulses traveling in opposite directions with equal frequency and amplitude can create complete destructive interference when their phases are 180 degrees out of sync, resulting in a zero amplitude standing wave during the overlap. Despite this apparent cancellation, energy is not lost; rather, it is stored in the magnetic field component, which retains energy density even when the electric field is zero. The waves continue moving past each other after the overlap, as the principle of superposition allows them to maintain their individual characteristics. The discussion highlights that while the scenario is theoretically interesting, practical considerations such as phase variations and the nature of wave interactions complicate the idealized situation. Ultimately, the conservation of energy is preserved through the dynamic interplay of the electric and magnetic fields, even during moments of destructive interference.
Surya97
TL;DR
Two photons/EM wave packets traveling in a vacuum, in exactly the opposite direction, with equal frequency and amplitude and orientation, meet head-on while having a 180 degree phase offset, creating perfect destructive interference and thus a standing wave with a zero amplitude for the instant of the pulses overlapping, at which point they then continue moving after “passing through” each other. Where is the energy “stored” during this moment, and the “info” about the constituent waves?
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of both waves. Assume they are traveling through a vacuum, including at the point where they meet/overlap.
As such, when they overlap, their sum is zero, leading to complete destructive interference, with zero regions of constructive interference for the energy to “move to”. Additionally, please assume that this is not some sort of experimental setup but rather a natural coincidence, so there is no need to appeal to the idea that in practice there would have to be some shared original source with a beam splitter, as this is not an experiment.
Is my assumption correct that for the duration/region of the overlap of these two discrete pulses (not a continuous beam), this creates the appearance of a “zero amplitude” standing EM wave due to complete destructive interference in the entire overlapping region? If so, where does the energy stored in those two EM waves “go”? I understand that the wave can still be decomposed into the constituent parts and that the derivatives and individual momenta are nonzero, but their summation appears to have no momentum or amplitude, and thus there should be zero electromagnetic energy density in this overlapping region.
Also assume that the sum of these waves’ energies does not add up to a discrete multiple of the mass of any known antiparticle pair, so that these waves do not cause pair production upon collision. Where in the EM field is the energy “stored” for the duration of the overlap? Why doesn’t the zero amplitude result in zero energy, which implies some violation of conservation of energy, which doesn’t seem possible in this simple closed system? Also, where/how is the “tendency” of the two constituent waves to continue moving (as if passing through each other) and seemingly spontaneously reforming (after the complete destructive interference period) “remembered”? How is this information stored about the constituent waves and the energy/future state changes that they held? Am I right that they should pass through each other and continue moving as if nothing happened once the duration of full overlap/interference is over?
Is there some form of conversion to “EM potential energy” that exists in this case despite the lack of visible EM field amplitude? If not, I don’t see where the energy is stored in this summed zero-amplitude standing wave, or how the EM field maintains conservation of energy in this case, or how the info about the two individual waves and their future tendency to keep moving (and thus seemingly spontaneously reappear) is preserved after this “collision”.
In the case of physical waves on a string, the resulting destructive interference before the waves continue past each other is explained away with the idea that the “velocity” of the material of the string creates a tendency for the string to keep moving despite the instantaneous appearance of being stationary, which is where the kinetic energy goes, somehow. This explanation is also not satisfying, but it doesn’t seem to apply at all in the case of two EM waves due to there being no underlying “material” or constituent massive particles that have their own kinetic energy. Additionally, since this takes place in a vacuum, there is no medium for the energy to be transferred to as heat, other than maybe quantum fluctuations/virtual particles I suppose.
Where then does this energy go and how is the “information” about the future motion of the two constituent waves “stored”? Please do not appeal to the notion that this ideal situation cannot be set up in practice without the two wave sources being the same or something; I have not found a satisfying answer to any similar/related questions that do not make some appeal of this type. Please just assume that this situation is occurring exactly as stated, by pure coincidence, and help me figure out the explanation/reason for the resulting behavior not violating any conservation laws.
I appreciate the help!
Surya97 said:
TL;DR Summary:
Two electromagnetic wave pulses traveling in a vacuum, in exactly the opposite direction, with equal frequency and amplitude and orientation, meet head-on while having a 180 degree phase offset, creating perfect destructive interference
How do two opposing waves maintain this 180 degree phase offset?
I understand that in practice there’s uncertainty and randomness/variation in the phase and that it cannot be controlled and maintained perfectly if the sources are independent. But is there a physical law/reason that prevents this theoretical/idealized thought experiment from occurring by complete chance, with the variation canceling out so that the two independent waves are always precisely out of phase? I’m mostly trying to understand where the energy flows and how information is stored, even if the likelihood of this perfect situation occurring approaches zero in practice.
No. You are not asking about two parallel beams propagating in the same direction. You are asking about two opposing beams -- have you actually done the math for this scenario?
Likes DaveE and Dale
No. You are not asking about two parallel beams propagating in the same direction. You are asking about two opposing beams -- have you actually done the math on this scenario?
Ok sorry, I understand the issue with the fact that the phase offset changes with time due to them moving in opposite directions past each other rather than in the same direction. What if it’s just a single photon/waveform instead? What happens to the energy when they meet? There doesn’t need to be a nonzero period of maintained phase offset then, right? Can’t individual photons have a meaningfully defined phase offset with respect to each other?
It isn’t. Can you see why? Think of the Poynting vector.
In the field that is not canceled. E.g. if there is complete destructive interference of the E field then the energy is stored in the B field.
Likes DaveE, Surya97 and berkeman
Ah, right, somehow I handwaved away the fact that the two magnetic field vectors are in the same direction if both the electric field and propagation direction vectors are in opposing directions. So the combined magnetic vector has double the magnitude at the moment of “collision” even though the electric field is zero, or vice versa.
Thanks for pointing this out, rookie mistake on my part to not notice the cross product sign error.
Exactly. And with double the magnitude of the magnetic field the total energy density is twice as large as the energy density of the non overlapping wave. Which is exactly the energy density needed for conservation of energy.
Surya97 said:
TL;DR Summary: Two photons/EM wave packets traveling in a vacuum, in exactly the opposite direction, with equal frequency and amplitude and orientation, meet head-on while having a 180 degree phase offset, creating perfect destructive interference and thus a standing wave with a zero amplitude for the instant of the pulses overlapping, at which point they then continue moving after “passing through” each other. Where is the energy “stored” during this moment, and the “info” about the constituent waves?
It is only in planes, separated by half wavelength, that this occurs. At intermediate distances, the relative phases pass through zero, π/2,2π/2 ... etc.. This is the same for standing waves of all kinds. The energy of the resultant of the two waves varies from zero to a factor of four ( twice amplitude). That averages out as a factor of two - which checks out.
The conceptual problem about the energy being 'shifted about' can be cleared up by considering how this could actually be measured. An omnidirectional antenna would measure the resultant vector which would be zero but only if the antenna has equal sensitivity in both directions. A directional antenna could eliminate one wave and measure just one wave. The waves do not 'communicate' with other; their phases are determined by their sources; the principle of superposition applies any don't notice each other..
The (only theoretical) situation for two plane waves, travelling in the 'same' direction is indeterminate because such a 'standing wave' would be of infinite wavelength. In a practical situation, the two planes would not be exactly coincident everywhere so you could expect an interference pattern with very wide fringe spacing and there would still be nulls and twice amplitude resultants, widely spaced.
PS Using the concept of photons in a problem like this is not valid because it assumes that a photon is a point in time and space. Photons have no such restrictions; they can be thought of as existing everywhere and at all times so your 'wave' explanation makes no sense. Weird!!
Yes! The plane waves in all of the physics books aren't physically realizable. You just can't have two different EM waves that cancel everywhere. Also, the energy in a wave isn't at a location or a small region. You must look at the whole thing. If you have destructive interference in a region, I'd bet a lot of money that there would be constructive interference somewhere else.
Where two phasors or vectors cancel, the result is not zero, it is just vanishingly small. Any phase or amplitude noise present, will prevent a deep null from being bottomless.
If the medium is linear, then the forward travelling wave, and the reverse travelling wave, will be quite independent, and so pass without influence on each other.
The RF version is easier to think of. Two transmitting antennae can be placed arbitrarily close together and the two amplifiers fed from a common source. The radiation pattern (in the appropriate plane) would be more or less a circle with more or less constructive interference at all points.
If you try to vary the relative phases of the transmitter feeds then mutual effects between the two antennae would cause large currents to flow in the transmitter amps and could cause a lot of smoke!! Only when the feeds are co-phase will no such effects.
Oh yes. Even the physical extent of the sources will 'fill in' any nulls.
It seems that you have two in-phase sources of radiation spaced apart. So you have an array. The energy absent from the minima will be found in the maxima.
Surya97 said:
TL;DR: Two photons/EM wave packets traveling in a vacuum, in exactly the opposite direction, with equal frequency and amplitude and orientation, meet head-on while having a 180 degree phase offset, creating perfect destructive interference and thus a standing wave with a zero amplitude for the instant of the pulses overlapping, at which point they then continue moving after “passing through” each other. Where is the energy “stored” during this moment, and the “info” about the constituent waves?
This question connects to something I've been working through.
Two waves at 180° — complete cancellation, energy seems to vanish. That's the puzzle you're describing.
But consider three waves at 120° separation:
Amplitudes still sum to zero:A₁ + A₂ + A₃ = 0
But energy is proportional to amplitude squared:E = A₁² + A₂² + A₃² = 3/2 = constant
The energy doesn't disappear. Each component still carries energy independently — they're in stable equilibrium, not destroying each other.
For your two-wave case: the energy is still there in the individual components. The sum being zero doesn't mean energy is zero — it means the fields are balanced at that instant. The energy is stored in the field configuration itself, not just the net amplitude.
The waves "remember" their trajectories because each component retains its own momentum and energy. Superposition affects what we measure, not what exists.
Please be aware that personal speculation is not permitted here. There is no part of either classical electrodynamics or quantum electrodynamics that corresponds to this statement. At least not to my knowledge.
Nor is there any need for such a claim. Poynting's theorem covers energy conservation without such a memory.
"You're right, I shouldn't have said 'remember.' What I meant is that during superposition, each component wave retains its energy and momentum — the net zero amplitude doesn't mean zero energy. Is that consistent with Poynting's theorem?"
For the case of a standing wave, there is no net flow of energy - the energy is stored. The electric and magnetic fields are no longer in phase, but in quadrature, and the nodes and antinodes for electric and magnetic fields are physically displaced from each other by a quarter of a wavelength.
That's helpful — so in a standing wave, E and B are in quadrature (90° phase offset) and the energy oscillates between electric and magnetic storage, but the total remains constant.
Does this extend to three-phase systems?
With three waves at 120° separation:
  • Amplitudes sum to zero (like destructive interference)
  • But E² + E² + E² = constant (no oscillation at all)
In a two-wave standing wave, energy sloshes between E and B storage. But in three-phase, there's no sloshing — the total is perfectly constant at every instant.
Is three-phase stability fundamentally different from two-wave standing wave storage? Or is it the same mechanism with more components?
This was incredibly helpful — thank you.
The quadrature relationship you described (E and B 90° out of phase, nodes displaced by 1/4 wavelength) helped me solve something I'd been stuck on.
I've been exploring energy drainage in bound systems — how energy at high harmonics flows down to stable states. The muon decay rate worked out cleanly, but I couldn't get the tau to work. Was off by a huge factor.
Your point about the 90° phase offset was the key. If three-phase locks are stable at 120° separation, but energy transfers through 90° quadrature steps, then the ratio 90°/120° = 3/4 should appear in the formula.
It does. Tau lifetime now works to within 1%.
Sometimes the right insight comes from an unexpected direction. Appreciate you taking the time to explain.
I can suggest another way of looking at this. The energy in each wave uniform as it flows all along the paths. We only 'see' the effect of interference when we actually measure at a particular point. To measure it, we need an instrument of some kind. If the instrument happens to have equal sensitivity in both directions of arrival it will 'see' the vector sum of the waves at that point. The energy (power) it will register is that vector sum which, (depending where the instrument is) will be zero, four times the energy or anything in between. The two waves do not interact at all; you just measure the result of addition.
Note; if the waves flow through a medium of some sort which registers the power at each point it will be taking some power away from each wave as it progresses so you will only get total cancellation where those two waves have equal amplitude. On either side of this point, there cannot be total cancellation. Near one source, the nulls may be totally filled in (extreme case of path attenuation).
This effect of 'filling in' can be seen in most interference experiments well off boresight because the two arriving waves often have different amplitudes (and, in the case of light) lack of coherence due to increasingly different path lengths.
There is a great temptation to find something wrong with initial explanations of many things in Physics. Very often it's just because we are looking at over-simplified models. This is a good example.
Key point here. You add the vectors, with amplitude and phase, before you calculate intensity (energy).
##(A_1+A_2+A_3)^2 \neq A_1^2+A_2^2+A_3^3## for vectors
Likes sophiecentaur
  • · Replies 71 ·
9K
  • · Replies 17 ·
