Merge sort with array of structs
  • Thread starter Thread starter Firestrider
    Array Sort
6 replies · 8K views
Firestrider
I need to be able to copy full structs in a temporary array based on a value in that struct (an integer), but I'm not sure exactly how to go about it. I have commented where I need to copy over structs.
Also in the other code block, what is the problem here? It doesn't seem to reconize the string.
N/A
Code:
void Merge(struct student_birthday birthdays[], int start, int middle, int end)
   int* temp, i, length, count1, count2, mc;
   length = end - start + 1;
   temp = calloc(length, sizeof(struct student_birthday));
   count1 = start;
   count2 = middle;
   mc = 0;
   while ((count1 < middle) && (count2 <= end))
      if (birthdays[count1].ymd < birthdays[count2].ymd)
         temp[mc] = birthdays[count1].ymd; // structs not values!
         count1++;
         mc++;
      else
         temp[mc] = birthdays[count2].ymd; // structs not values!
         count2++;
         mc++;
   if (count1 < middle)
      for (i = mc; i < length; i++)
         temp[i] = birthdays[count1].ymd; // structs not values!
         count1++;
   else if (count2 <= end)
         temp[i] = birthdays[count2].ymd; // structs not values!
         count2++;
   for (i = start; i <= end; i++)
      birthdays[i].ymd = temp[i - start]; // structs not values!
   free(temp);
Code:
int MonthToInt(char month[9]);
   char month[9];
int main(void)
   m_int = MonthToInt(birthdays[j].month);
    int m_int = 0;
    if (month == "JANUARY") m_int = 1;
    else if (month == "FEBRUARY") m_int = 2;
    else if (month == "MARCH") m_int = 3;
    else if (month == "APRIL") m_int = 4;
    else if (month == "MAY") m_int = 5;
    else if (month == "JUNE") m_int = 6;
    else if (month == "JULY") m_int = 7;
    else if (month == "AUGUST") m_int = 8;
    else if (month == "SEPTEMBER") m_int = 9;
    else if (month == "OCTOBER") m_int = 10;
    else if (month == "NOVEMBER") m_int = 11;
    else if (month == "DECEMBER") m_int = 12;
    return m_int;
It seems I have to use the strcmp function for the second code block.
Does anyone know why this statement will not work:
Code:
struct student_birthday* temp;
int i, length, count1, count2, mc;
temp[mc]->first_name = birthdays[count1].first_name;
It says "invalid type argument of `->' ". I just want to copy each individual piece of the struct one by one, or if possible the whole struct...
Any help is appreciated!
That's because temp[mc] isn't a pointer. You wanted `.'.
Firestrider: For your first code block, would this work? temp[mc] = birthdays[count1];
Hi, and thanks for your help.
When I do this:
Code:
temp[mc].first_name = birthdays[count1].first_name;
I get the error "incompatible types in assignment"
This is the function:
Code:
That works when I change temp to a pointer to a struct, but I get weird values when accessing pieces of the struct. It probably has something do with how memory is allocated.
Does anyone know why I get that error from my previous post? I'm running into this a lot and I'm not sure why I get it.
Firestrider said:
Code:
If first_name is supposed to be an array of char, then remember that you can't copy C-style arrays by assignment.
But... I don't see any member called "first_name" in struct student_birthday.
