Meri go round: Angular momentum
kalupahana
A meri go round is rotating it vertical axis through center with a diameter 4.5m. It's moment of inertia is 1750 kg m2 and angular velocity is 0.70 rad/s. 4 men with mass 65 kg instantly enter the the edge of the meri go round. Calculate the angular velocity of meri go round after that instant.
Conservation of angular momentum
I1ω1 = I2ω2
I = ma2
I1 = 1750 kg m2
ω1 = 0.70 rad/s
The mass of meri go round
1750 = ma2
1750 = m(4.5/2)2
(1750 x 4)/ (4.5)2 = m
The mass of meri go round after 4 men get in
m = (1750 x 4)/ (4.5)2 + 65 x 4
m = [7000 + (260 x (4.5)2]/(4.5)2
m = 12265/(4.5)2
Then
I2 = 12265 kg m2
Applying conservation of angular momentum
1750 x 0.70 = 12265 ω2
ω2 = 1.099 rad/sBut the answer is given as 0.004 rad/s.
Please help me to reach to this answer
The mistake you've made is 'I=ma^2' which is only valid for a point particle.
The ride could be any complex shape you can't say anything about.
So moment of inertia after 4 men go on is: 1750 + 4*(65)*((4.5/2)^2)
the men are assumed to be point masses at a distance a/2 so their moments of inertia is m(a/2)^2 each.
This can be just added to the moment of inertia of the ride, as the axis of rotation stays same throughout the problem.
