Graduate Meson Compostions: Difference Between π0 and η
The π0 meson has a composition of (uu_bar - dd_bar)/√2, while the η meson is composed of (uu_bar + dd_bar)/√2, with the differing signs resulting from their respective linear combinations in flavor space. The π0 is part of an isospin triplet, making it symmetric under the exchange of up and down quarks, whereas the η meson is an isospin singlet, leading to its antisymmetric nature. This distinction arises from the underlying SU(2) symmetry of the quark model, where the combinations of quark-antiquark pairs yield different meson states. Additionally, the discussion touches on the SU(3) symmetry, which includes strange quarks and further complicates the meson compositions. Understanding these differences is crucial for grasping the properties and behaviors of mesons in particle physics.
Shen712
The composition of the π0 is (uu_bar - dd_bar/√2; while the composition of the η meson is (uu_bar + dd_bar)/√2. Why is there a - sign in π0 while is there a + sign in η? How are the signs determined?
By the way, can I type Latex symbols on this site? I tried to type the anti up quark by typing \overline{u}, but it did not show what I wanted. How should I type it?
Yes, LaTeX is supported here. See our tutorial here -- https://www.physicsforums.com/help/latexhelp/.
Because ##\pi## and ##\eta## are different linear combinations of states in flavour space.
Can you explain more clearly? How are the linear compositions different? And how does one lead to a - sign while the other lead to a + sign?
They are in different flavour states. It is that simple. If you have two vectors x and y, x+y is a different linear combination than x-y. In this case, one (##\pi_0##) is part of an isospin triplet and the other (##\eta##) is an isospin singlet.
In the flavor symmetric model, aka the down and up quarks are in an SU(2) doublet (aka 2-dimensional representation), which is a good approximate symmetry as long as the quarks are massless m_u , m_d \approx 0, when you go to build mesons by combining the doublet with the anti-doublet you have:
\textbf{2} \otimes \bar{\textbf{2}} = \textbf{3} \oplus \textbf{1}
The (iso)triplet you get contains the pions (well with some combinations for the charged pions*): \pi^{\pm} , \pi^0 since it's built from the combination : \bar{q} \sigma^i q with sigma the pauli matrices, while the (iso)singlet is the \eta meson and it's constructed from the identity matrix (not pauli-matrices): \bar{q} \textbf{1} q. The isotriplet is symmetric under the exchange u\leftrightarrow d while the isosinglet is antisymmetric (similar to spin-1/2 from quantum mechanincs).
This is a simplified explanation (yet it works for your case). The actual (physical) \eta states are produced as a mixture of states. These states are predicted by flavor SU(3) symmetry (adding strange quarks in, since they are also quite light), they are in an iso-octet and iso-singlet: \textbf{3} \otimes \bar{\textbf{3}} = \textbf{8} \oplus \textbf{1}. Because the u,d,s quarks are not exactly massless, the SU(3) symmetry is not exact and mixings happen.
*In fact I wrote the charged pions immediately, but the quark composition you get out of this procedure is for \textbf{3}:
\phi^1 = \frac{1}{\sqrt{2}} (u\bar{d} + \bar{u} d) ,~~\phi^2= \frac{i}{\sqrt{2}} (u\bar{d} - \bar{u}d) ,~~\phi^3= \frac{1}{\sqrt{2}} (u\bar{u} - d \bar{d} )
The charged pions come from combining \phi^{1,2} ... in a similar manner as you built the ladder operators in spin-1/2 case... \pi^\pm = \frac{1}{\sqrt{2}} ( \phi^1 \mp i \phi^2)
Where is the s \bar{s} component of your \eta? Scalar mesons (i.e., the J^{P} = 0^{-} representation of the Lorentz group) contain 2 \eta-particles: the T = S = 0 member of the SU(3) octet, usually denoted by \eta_{8} and having the quarks content \eta_{8} = \frac{1}{\sqrt{6}} (u \bar{u} + d \bar{d} - 2 s \bar{s}) , and there is the SU(3) singlet (invariant) state \eta_{1} = \frac{1}{\sqrt{3}} \sum_{i = u,d,s} q^{i} \ \bar{q}_{i} = \frac{1}{\sqrt{3}} (u \bar{u} + d \bar{d} + s \bar{s}) \ . The exact quark content follows from the SU(3) decomposition 3 \otimes \bar{3} = 8 \oplus 1, which you can represent as follow q^{i} \bar{q}_{j} = \left( q^{i} \bar{q}_{j} - \frac{1}{3} \delta^{i}_{j} \sum_{k = u,d,s} q^{k} \bar{q}_{k}\right) + \frac{1}{3} \delta^{i}_{j} \sum_{k} q^{k}\bar{q}_{k} \ . The first term on the right hand side is the 3 \times 3 traceless hermitian mesons matrix \{8\}^{i}_{j} = q^{i} \bar{q}_{j} - \frac{1}{3} \delta^{i}_{j} \sum_{k = u,d,s} q^{k} \bar{q}_{k} \ . For the 0^{-} (i.e., scalar) mesons, the off-diagonal matrix elements are easily recognised, for example \{8\}^{2}_{3} = d \bar{s} = K^{0} \ , \{8\}^{3}_{1} = s \bar{u} = K^{-} and the two charged pions \{8\}^{1}_{2} = u \bar{d} = \pi^{+} \ , \{8\}^{2}_{1} = d \bar{u} = \pi^{-}. Now, before considering the diagonal elements of the SU(3) meson matrix \{8\}^{i}_{j}, and in order to settle the sign issue for \pi^{0}, let us repeat the same thing for the iso-spin group SU(2). That is decomposing the tensor product 2 \otimes 2 = 3 \oplus 1 by subtracting the SU(2)-invariant trace. So, in terms of quarks q^{m} \bar{q}_{n} = \left( q^{m} \bar{q}_{n} - \frac{1}{2} \delta^{m}_{n} \sum_{l = u,d} q^{l}\bar{q}_{l} \right) + \frac{1}{2} \delta^{m}_{n} \sum_{l = u,d} q^{l} \bar{q}_{l} \ . From this we identify the triplet (i.e., iso-spin one) pion states which are contained in the matrix \{3\}^{m}_{n}:\pi^{+} = |1 , +1\rangle = \{3\}^{1}_{2} = u \bar{d} \ ,\pi^{0} = |1 , 0 \rangle = \sqrt{2} \{3\}^{1}_{1} = \frac{1}{\sqrt{2}} (u \bar{u} - d \bar{d}) \ ,\pi^{-} = |1 , -1 \rangle = \{3\}^{2}_{1} = d \bar{u} \ . Now, you know the exact form of \pi^{0} state, go back to consider the diagonal elements of the SU(3) matrix \{8\}^{i}_{j}: \{8\}^{1}_{1} = u \bar{u} - \frac{1}{3} \sum_{j = u,d,s} q^{j}\bar{q}_{j} = \frac{1}{\sqrt{2}} \pi^{0} + \frac{1}{6} \left( u \bar{u} + d \bar{d} - 2 s \bar{s} \right) \ , \{8\}^{2}_{2} = - \frac{1}{\sqrt{2}} \pi^{0} + \frac{1}{6} \left( u \bar{u} + d \bar{d} - 2 s \bar{s} \right) \ ,\{8\}^{3}_{3} = - \frac{2}{6} \left( u \bar{u} + d \bar{d} - 2 s \bar{s}\right) \ . This led to the identification of \eta_{8} with the state \eta_{8} = \frac{1}{\sqrt{6}} \left( u \bar{u} + d \bar{d} - 2 s \bar{s}\right) \ .
