Methanoic Acid's dissociation constant
The dissociation constant (K) for methanoic acid (HCOOH) at 25°C is calculated to be 1.652 x 10-5, with a corresponding pKa of 4.78. This calculation is based on a 0.04 M solution of methanoic acid with a pH of 2.59. Additionally, for a 0.0500 M sodium hydroxide (NaOH) solution, the pH is determined to be 12.699, taking into account the ionic product of water at 298K, which is 1.0 x 10-14 mol2dm-6.
  • Understanding of acid-base equilibrium and dissociation constants
  • Knowledge of pH calculations and the pH scale
  • Familiarity with the ionic product of water (Kw) at 298K
  • Basic skills in algebra for solving equilibrium expressions
  • Study the calculation of acid dissociation constants using the Henderson-Hasselbalch equation
  • Learn about the effects of concentration on pH in strong vs. weak acids
  • Explore the concept of ionic strength and its impact on pH measurements
  • Investigate the relationship between pKa and the strength of acids
Chemistry students, laboratory technicians, and anyone involved in acid-base chemistry or pH calculations will benefit from this discussion.
josephcollins
I need some help with these, anyone point me in the right direction please?
The pH of 0.04moldm-3 methanoic acid, HCOOH, is 2.59 at 25 celsius. Calculate the acid dissociation constant at this temperature
Given that the ionic product of water is 1.0 times 10^-14 mol2dm-6 at 298K, calculate to 3 significant figures the pH at this temperature of a 0.0500M solution of sodium hydroxide.
Chemistry news on Phys.org
Calculation of acid dissociation constant
Hello,
0,04 M of formic acid has pH 2,59, as you gave us.
HCOOH (0,4-x) ---> H+ (x) + HCOO- (x)
We should carefully think of this problem first by considering the additional x in (0,4-x); and by omitting the x also. Note that we know x, 10-2,59. It means that the dissociation is about one hundredth; if it would be around 10%, then we should consider it. It won't be any problem if we omit the x in (0,4-x), I hope we've settled this.
Now the equilibrium constant gives us the dissociation constant (sorry for not even hearing Latex before :smile:):
K=(10-2,59*2)/0,4=1,652*10-5. The pKa will be found as 4,78.
About second question, you gave us 0,0500 M of NaOH and want pH as x.xxx. So, the contribution of water may be important. Again, if it is beyond 10%, it can be omitted.
NaOH (5,000*10-2) --> Na+ (5,000*10-2) + OH- (5,000*10-2) as it is fully ionized.
H2O --> H+ (1,000*10-7) + OH- (1,000*10-7), ionic product allows me to write these. As you see that they are well beyond 5,000*10-2, it can be omitted, since there is a five hundred thousand-fold difference.
The overall pH is (with enough precision) found to be 12,699. If you want to add water's hydroxide to it, you'd find the same, as 3 significant figures are not affected with this very small addition.
Regards, chem_tr
