How are Equations for Different Series Generated?
The discussion focuses on how to derive polynomial equations for specific number sequences. For the sequence 1, 2, 5, 12, 25, the third differences are constant, leading to a cubic polynomial expressed as T_n = a(n-1)(n-2)(n-3) + b(n-1)(n-2) + c(n-1) + d. In contrast, the sequence 1, 3, 7, 13, 21 has constant second differences, resulting in a quadratic polynomial T_n = an^2 + bn + c. The coefficients a, b, c, and d are determined by substituting known terms of the sequence into the polynomial equations. This method allows for systematic solving of the polynomial coefficients to generate the nth term of the sequence.
AdityaDev
Given series:1,2,5,12,25...
How did they get :##T_n=a(n-1)(n-2)(n-3)+b(n-1)(n-2)+c(n-1)+d##
And for series like 3,7,13,21,...
they have given ##T_n=an^2+bn+c##
How do you get these equations?
Mathematics news on Phys.org
Based on the image, this should be 1, 3, 7, 13, 21, ...
If the first consecutive differences happened to all be the same constant, the solution would have been a linear (first-degree) polynomial. If the second differences turned out to be a constant (as in the sequence 1, 3, 7, 13, 21, ...), the solution would be a quadratic (second-degree) polynomial, which you could write as Tn = a(n - 1)(n - 2) + b(n - 1) + c.
In your problem, which involves the sequence 1, 2, 5, 12, 25, 46, ... the third differences are all 2, so the solution will be a cubic (third-degree) polynomial, which they write as ##T_n = a(n - 1)(n - 2)(n - 3) + b(n - 1)(n - 2) + c(n - 1) + d##
What they do after this is to solve for the coefficients a, b, c, and d, noting that T1 = 1, T2 = 2, T3 = 5, and T4 = 12. IOW, Tn is just the nth term in the sequence.
As an aside, 1, 3, 7, 13, 21, ... is a sequence of numbers, not a series. In a series, all the numbers are added together to produce a sum.
I'm pretty rusty on this stuff, as it has been many years since I did anything with difference equations. Nevertheless, I was able to get the coefficients a, b, c, and d, and was able to get the correct value for T5, so I think I'm on the right track.
Why is it T_n=a(n-1)(n-2).. why not ##T_n=a(n-4)(n-8)+b(n-25)+c##
If you ignore the way they've expressed it for the moment, you can still agree that it's a cubic, correct? It could just as easily be expanded and turned into the general cubic form
T_n=An^3+Bn^2+Cn+D
where A,B,C,D are likely going to be different constants to a,b,c,d but equate to the same cubic.
Now, why was that particular form chosen?
Well, picking n=1 gives us T_1=a(1-1)(1-2)(1-3)+b(1-1)(1-2)+c(1-1)+d. Now, notice that any (n-1) factor gives us 0, hence we end up with T_1=a*0+b*0+c*0+d=d so with this form, we can easily find d, as opposed to having the general cubic with coefficients A,B,C,D that I had shown above. In that case, T_1=A+B+C+D and we're hardly any closer to finding the solution.
So, we have T_1=d=1 and we've already knocked one of the coefficients out of the way. T_2 turns out to give us a constant as well by following a similar idea.
T_2=a(2-1)(2-2)(2-3)+b(2-1)(2-2)+c(2-1)+d
and again, notice that (n-2) factors would equal zero, hence we end up with T_2=a*0+b*0+c+d=c+d. But we already found d=1, so T_2=c+1=2 hence c=1. For n=3, you'll end up with just b,c,d and can solve for b easily since you know c,d.
Likes AdityaDev
AdityaDev said:
Thank you @Mentallic
You're welcome, and good luck with your studies!
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 16 ·
  • · Replies 17 ·
