No problem, happy to help! Keep up the good work in your studies.
The discussion revolves around calculating the electric potential in the region above a grounded conducting surface with two point charges using the method of images. The user presents their calculations for the potential contributions from both the real and image charges, expressing concern over the complexity of the final expression. Other participants emphasize that the complexity is expected due to the four contributing charges and that the mirror image method is necessary to satisfy boundary conditions. They also note that while textbook problems often yield simpler results, the detailed answer provided is appropriate for the problem at hand. The conversation concludes with appreciation for the guidance offered, highlighting the learning experience for the user.
blizzardof96
The z = 0 plane is a grounded conducting surface. A point charge q is at (0,0,a), and charge 4q at (0,-2a,a).
Calculate the potential in the region z > 0.
V=∑kq/r
[/B]
Use the method of images.
V1 = kq/r+ + kq/r-
V1=kq(1/sqrt(x^2 +y^2 + (z-a)^2) - 1/sqrt(x^2 +y^2 + (z+a)^2)
V2=4kq/r+ + 4kq/r-
V2 = 4kq(1/sqrt(x^2 + (y+2a)^2 + (z-a)^2) - 1/sqrt(x^2+(y+2a)^2 + (z+a)^2))
Vtotal=ΣV=V1+V2
Vtotal=4kq(1/sqrt(x^2 + (y+2a)^2 + (z-a)^2) - 1/sqrt(x^2+(y+2a)^2 + (z+a)^2)) + kq(1/sqrt(x^2 +y^2 + (z-a)^2) - 1/sqrt(x^2 +y^2 + (z+a)^2)
Is this the correct answer?
PF isn't for stamp-approving homework. The answer to your question can be obtained from your teacher: hand it in.
Or is there another reason you ask: have doubt at some point ? Tell us.
I have doubts as the value for Vtotal seems unnecessarily complex and there is nothing in the final expression that can simplify. The solution appears much different from the usual form we see in an electric potential problem.
I see. Lots of textbook exercises have compact and elegant answers, I agree. Somewhat unrealistic, I must warn you.
In this case you have four terms from the four contributing charges (two real, two image). The mirror image method ensures the physical boundary conditions are met ( V=0 at z=0 and ##\vec E \perp (z=0)## ) and that's about all there is to be said.
At large distances ( ##|\vec r| >> a## ) your configuration should give a dipole field, but here you are clearly expected to give the full detailed answer you worked out.
Likes blizzardof96
Thank you. As a third year undergrad with less physics knowledge than yourself I appreciate it.
  • · Replies 19 ·
