redtree
- 335
- 15
I am having trouble finding the equation for the metric for the Lambdavacuum solution to the EFE in radial coordinates. Any suggestions?
The discussion centers on the metric for the Lambdavacuum solution to the Einstein Field Equations (EFE) in radial coordinates. The Minkowski metric is identified as the vacuum field solution without a cosmological constant, while the Schwarzschild metric describes the vacuum field solution around a spherical mass. The de Sitter metric is also discussed, particularly in relation to the cosmological constant, with the final metric expressed as a function of both the Schwarzschild radius and the cosmological constant. The participants provide links to relevant lecture notes and resources for further understanding.
PREREQUISITESStudents and researchers in theoretical physics, particularly those focused on general relativity, cosmology, and the mathematical formulation of gravitational theories.
Also look at Carroll's lecture notes from eq. 8.7 onward and you will see the metric and how it relates to Einstein's field equations, including the cosmological constant.redtree said:I am having trouble finding the equation for the metric for the Lambdavacuum solution to the EFE in radial coordinates. Any suggestions?
redtree said:I am still not sure how to write metric of the Lambdavacuum solution
Sure, this is what I quoted for ##m=0## (i.e., ##r_{\text{S}}=0##).PeterDonis said:It's the de Sitter metric; see here:
https://en.wikipedia.org/wiki/De_Sitter_space
If by "radial coordinates" you mean coordinates with a radial coordinate ##r## defined the way it is in Schwarzschild coordinates (such that the area of a 2-sphere at radial coordinate ##r## is ##4 \pi r^2##), those are the "static coordinates" described at that link.
