GRstudent
- 143
- 1
So my matrix representation of the Stress-Energy Tensor is right after all?
GRstudent said:So my matrix representation of the Stress-Energy Tensor is right after all?
Muphrid said "differentials", not "partial derivatives". He meant that you need to define "energy per unit volume" in the limit of very small volumes, not that you should use the rate of change of energy with respect to volume. They're different things.
Also, you have ρ in some components instead of E/V, but aren't those two supposed to be the same thing?
Finally, however, you haven't derived any of this from first principles, so it's certainly not a "definition" of what the stress-energy tensor is. At best, what you've written could be a sort of indication of what the tensor components might mean, physically, but even that is strained because the meaning of tensor components is frame-dependent. The actual physical observables are contractions of the tensor with suitable vectors; for example, as pervect pointed out, pa=Tabub, is a 4-vector describing the energy density and momentum density seen by an observer with 4-velocity ub. *If* it happens that the observer is at rest in the particular coordinates you are using, i.e., if ub=(1,0,0,0), *then* it will turn out that pa=(T00,T10,T20,T30), so T_00 will give the energy density seen by this particular observer, and (T_10, T_20, T_30) will give the momentum density seen by this particular observer. But an observer with a different 4-velocity will see *different* energy and momentum densities, involving other components of the SET.
GRstudent said:Well, that's something trivial here.
GRstudent said:What important is that we can calculate the energy and momentum of, say, a particle moving through a space.
Yes, but what you are writing down for the various SET components *assumes* that the thing we are trying to calculate the energy and momentum of has a particular state of motion relative to us. If the state of motion is different, the SET components will *not* have the meanings you are writing down; T_00 will *not* be the energy density we measure, (T_10, T_20, T_30) will *not* be the momentum density we measure, etc. What you are writing down assumes that T_00 *is* the energy density, etc., etc. So what you are writing down is not generally true; it's only true under a particular set of circumstances.
GRstudent said:In my matrix, I assume that two observes are looking at each other--they are moving at the same speed.
GRstudent said:And I wanted to make sure that I have given the right formulas for each component--that's all.
GRstudent said:So if we are talking about a particle which is moving with velocity [itex]v[/itex] with respect to us, then we should multiply each component by [itex]v[/itex]?
how you are going to measure all the quantities appearing in your formulas for the special case where the observer and the substance being observed are at rest with respect to each other, which is what you say your formulas apply to.
GRstudent said:I would ask you the same question. How?
You're the one that wrote down the formulas, so it's up to you to explain what they mean and how to measure the quantities in them. I didn't write them down, so I don't know what you meant by them.
I use a combination of different sources of information.GRstudent, what book are you using to learn relativity?? You are using a book, right??
A lot of mine are zeroGRstudent said:^
so what difference did you find between those components and my components?
Riemann is a rank 4 tensor and Ricci is a rank 2 tensor. I never felt that there was any confusion, so I am not sure what you are asking.GRstudent said:Also how would you intuitively distinguish Riemann from Ricci tensor?
GRstudent, I am not trying to correct your components; I am just suggesting an alternative approach for learning what a SET is. If you have already learned enough with your approach and feel comfortable with the SET and don't want to try my suggestion then that is fine by me.
I just don't see how there is any room for intuitive confusion between them, they are tensors of different ranks. They are as different as scalars and vectors, or vectors and matrices. Can you describe better what it is about them that confuses you?GRstudent said:I wasn't asking about "mathematical" difference between those tensors. I was asking about "intuitive" difference between them.
Why don't we start here then. Do you know what parallel transport is and how parallel transport around a closed loop doesn't bring a vector back to itself in curved spaces?GRstudent said:I have a slightly shady view of what Riemann tensor really is
If not, then I would recommend watching this lecture:
http://www.youtube.com/watch?v=Pm5RO...feature=relmfu
GRstudent said:Ok, let's take [itex]T^{32}[/itex]. It is the flow of the z-component of momentum in y direction.
GRstudent said:So I have [itex]\dfrac{d(mv_{z})}{A^y d t}[/itex]. Also, the flow of some quantity is given by [itex]\dfrac{\Delta Q}{A \Delta t}[/itex], where Q is the quantity, A is an area through which the Q flows and t is a time interval.
OK, that is a good starting point. If you get stuck somewhere in the lecture, please let me know and we can go from there.
Do you feel like you have a good understanding of what parallel transport is and how parallel transport along closed loops gets you back to the same vector in flat space but not in curved space?
OK, good. That is the basis of defining the Riemann curvature tensor. Susskind will give a much better and more detailed explanation in the 7th lecture, but basically, the Riemann curvature tensor describes how much and what direction a vector deviates when it is parallel transported around an infinitesimal loop in a particular orientation. You need a total of four indices to describe that completely.GRstudent said:I understand why in parallel transport around the closed loop the vector in curved space don't come back to its initial form.
