Why is the entropy calculated differently in the microcanonical ensemble?
The discussion focuses on the calculation of entropy in the microcanonical ensemble, specifically the relationship between the phase volume function, Γ(E,N,V), and the entropy formula S(E,N,V) = ln Γ(E,N,V). It establishes that for large N, the definitions of entropy S_ω = k_B ln(ω(E)) and S_Γ = k_B ln(Γ(E)) are equivalent up to logarithmic terms. The conversation emphasizes that the approximation ω(E) ≈ Γ(E) holds true when considering energy changes in high-dimensional spaces, where most volume is concentrated at the surface.
  • Understanding of microcanonical ensemble principles
  • Familiarity with phase space and phase volume concepts
  • Knowledge of statistical mechanics terminology
  • Basic grasp of entropy calculations in thermodynamics
  • Study the derivation of entropy in the microcanonical ensemble using Statistical Physics by Manfred Sigrist
  • Explore the implications of high-dimensional geometry on statistical mechanics
  • Learn about the relationship between phase volume and entropy in different ensembles
  • Investigate the role of large N in statistical approximations and their physical interpretations
Students and researchers in physics, particularly those specializing in statistical mechanics and thermodynamics, as well as anyone interested in the mathematical foundations of entropy in microcanonical ensembles.
LagrangeEuler
Ideal gas which consist of ##N## identical particles which moving free inside volume ##V## where all collisions between particles and walls of container are absolute elastic. Calculate phase volume ##\Gamma##, entropy ##S##, temperature ##T## and pressure of gas.
Hamiltonian
[tex]H=\sum^{3N}_{i=1}\frac{p_i^2}{2m}[/tex]
[tex]\Gamma(E,N,V)=\int_{H(p,q) \leq E}\frac{dpdq}{h^{3N}N!}[/tex]
I have a problem to understand why this problem is microcanonical ensemble problem? And why entropy is calculated as
S(E,N,V)=\ln \Gamma(E,N,V)
When in microcanonical ensemble we spoke about energies between ##E## and ##E+\Delta E##.
##\Gamma(E,N,V)## is defined as the phase volume which contains all points in ##\Gamma## space with energy lower than or equal to ##E##. Regarding a microcanonical ensemble in the energy range ##[E,E + \delta E]##, the corresponding volume is given by ##\omega(E,N,V)=\Gamma(E+\delta E,N,V)-\Gamma(E,N,V)##.
For the entropy, one has then ##S(E,N,V)=k_Bln(\omega(E,N,V))##.
For very large ##N##, one finds that the following definitions for the entropy are identical up to terms of order ##lnN## and constants:
##S_{\omega}=k_Bln(\omega(E))## and ##S_{\Gamma}=k_Bln(\Gamma(E))##
Have a look, for example, at chapter 2.2 of Statistical Physics by Manfred Sigrist: https://www.e-booksdirectory.com/details.php?ebook=6060
Yes undestand what you want to say. But is not than the case that entropy
S=k_Bln(\omega(E))=k_Bln(\Gamma(E+\delta E))
Because in large number of dimension almost all volume of sphere is concentrated around the surface.
$$\omega(E,N,V)=\Gamma(E+\delta E,N,V)-\Gamma(E,N,V) =\frac {\partial \Gamma(E,N,V)} {\partial E} \delta E$$
Yes I understand what is ##\omega##. My question is why
S=k_Bln(\omega(E))=k_Bln(\Gamma(E+\delta E))?
You already have the answer.
If I understand the notation correctly, then for large ##N##: ##\omega(E) \approx \Gamma(E)##
I am confused there. Because if I have that n large number of dimension almost all volume of sphere is concentrated around the surface. That means to my mind that if energy changes from ##E-\Delta E## to ##E## that I can use approximation that we are talking about.
Sorry, I'm not understanding your problem.
You overcomplicate the issue:
S=k_Bln(\omega(E))\approx k_Bln(\Gamma(E))
holds for a microcanonical ensemble with energies between ##E## and ##E+\delta E## in case of very large ##N##. Have a look at equations (2.43) and (2.44) in chapter 2.2 of Statistical Physics by Manfred Sigrist.
  • · Replies 37 ·
