Micromass' big counterexample challenge
62 replies · 11K views · last reply
ProfuselyQuarky said:
Yeah, exactly! I can only get this: ##\lim_{x\to0} x\sin \frac {1}{x}## With the code:
Code:
Add \displaymath before the limit.
Code:
As you can see in my previous post, adding the \displaystyle tag makes some LaTeX expressions nicer.
:cry::cry: Well, *sniff* here you go . . .
f(x) = \left\{
\begin{array}{ll}
2x\sin \frac {1}{x} - \cos \frac {1}{x} & \quad x \neq 0 \\
0 & \quad x = 0
\end{array}
\right.
It's a basic sine curve with ##\lim_{x\to0} f'(x)##. This holds true for real numbers but the function diverges. Thus, we have a derivative of a differentiable function that is discontinuous.
Okay, now you all can tell me what's wrong with it :sorry:
Looks good to me, let's see what micromass thinks. There is a little inconsequential typo, as you wrote ##f(x)## instead of ##f'(x)##.
micromass said:
Every derivative of a differentiable function is continuous.
##y=\frac{x}{x}## is differentiable, and
it's derivative, using the quotient rule, is ##\frac{0}{x^2}##, which is undefined at x=0 and thus not continuous.
##\displaystyle \lim_{x\to0} x\sin \frac {1}{x}## works but ##\displaymath \lim_{x\to0} x\sin \frac {1}{x}## doesn't. Thanks @Samy_A!
Samy_A said:
Looks good to me, let's see what micromass thinks. There is a little inconsequential typo, as you wrote f(x)f(x) instead of f′(x)f'(x).
Yeah, sorry :redface:
(for #5)
All you need to do is find a derivative of a differentiable function that is discontinuous.
At first I had in mind ##f(x)=|x|##, but ##|x|## is not differentiable at the point 0 and actually, this only occurs in isolated points apparently. So, here's a piecewise function:
f(x) = \left\{
\begin{array}{ll}
x^2\sin(\frac {1}{x}) & \quad x \neq 0 \\
0 & \quad x = 0
\end{array}
\right.
For this, ##f'(x)=2x\sin \frac {1}{x} - \cos \frac {1}{x}## whenever ##x\neq0##.
I find the derivative by solving for the limit. ##1\geq|\sin x|## per ##x##, thus the simplified limit is ##\lim_{x\to0} x\sin \frac {1}{x}## or, simply, 0. This, in turn, gives us:
f(x) = \left\{
\begin{array}{ll}
0 & \quad x = 0
\end{array}
\right.
That is correct!
Undefined at ##0## doesn't mean discontinuous at ##0##
stevendaryl said:
I think I know how to solve #3.
Suppose we let [itex]f^2(x) = \sum_{n=0}^{\infty} e^{-\lambda_n (x-n)^2}[/itex], where [itex]\lambda_n[/itex] is a sequence of constants. (So [itex]f(x)[/itex] is the square-root of the sum). Then it would certainly not be the case that [itex]lim_{x \rightarrow +\infty} f(x) = 0[/itex]. But the integral might still be finite:
[itex]\int dx f^2(x) = \sum_{n=0}^{\infty} \int dx e^{-\lambda_n (x-n)^2} = \sum_{n=0}^{\infty} \sqrt{\frac{\pi}{\lambda_n}}[/itex]
This sum converges, provided that [itex]\lambda_n[/itex] grows sufficiently rapidly. For example, [itex]\lambda_n = 2^n[/itex].
So my answer is: [itex]f(x) = \sqrt{ \sum_{n=0}^{\infty} e^{-2^n (x-n)^2}}[/itex]
You'd have to prove that [itex]f(x)[/itex] is well-defined and differentiable, but I think it's true.
Cool idea, but I can't really accept this solution until some gaps are filled:
  • Prove ##f(x)## is well-defined
  • Prove ##f(x)## is differentiable.
  • Show why ##\lim_{x\rightarrow +\infty} f(x) =0##
  • Show that the interchange of series and integral is justified.
limx→0f(x)≠f(0) If f(x)=##\frac{0}{x^2}##.
I know that @ProfuselyQuarky solved it before me, just want to know why I'm wrong.
Because ##0## is not in the domain of your function. It's true that ##f## is continuous at ##0## iff ##\lim_{x\rightarrow 0}f(x) = f(0)##, but that is only when ##0## is actually in the domain of your function.
Ah ok.
Oh, bother! The idea is to have a function that is basically a bunch of "spikes" that always have height 1, but whose widths decrease. Gaussians have that property, but working with them is a little bit of a pain. But here's another choice:
First define [itex]g(x)[/itex] as follows:
[itex]g(x) = 0[/itex] if [itex]x < -\frac{1}{2}[/itex]
[itex]g(x) = 1 + cos(2\pi x)[/itex] if [itex]-\frac{1}{2} < x < +\frac{1}{2}[/itex]
[itex]g(x) = 0[/itex] if [itex]x > \frac{1}{2}[/itex]
Then [itex]g(x)[/itex] is continuous and once-differentiable.
Then [itex]\int_{-\infty}^{+\infty} g(\lambda x) dx = \frac{1}{\lambda} \int_{-\frac{1}{2}}^{+\frac{1}{2}} (1+cos(2\pi x)) dx = \frac{1}{\lambda}[/itex]
Let [itex]\lambda_n[/itex] be any sequence of real numbers greater than 1 such that [itex]\sum_n \frac{1}{\lambda_n} < \infty[/itex]
Define [itex]g_n(x) = g(\lambda_n (x-n))[/itex]. Then for any [itex]n \neq m[/itex], either [itex]g_n(x) = 0[/itex] or [itex]g_m(x) = 0[/itex] or both. Furthermore, [itex]g_n(n+\frac{1}{2}) = g_{n+1}(n+\frac{1}{2}) = 0[/itex].
Let [itex]N[x][/itex] = the smallest [itex]n[/itex] such that [itex]n+\frac{1}{2} > x[/itex]
So now define [itex]q(x) = g_{N[x]}(x)[/itex], where [itex]n[/itex] is the smallest number such that [itex]n+\frac{1}{2} > x[/itex]. Then [itex]q(x)[/itex] is continuous: For [itex]x[/itex] in the range [itex]n-\frac{1}{2} < x < n+\frac{1}{2}[/itex], [itex]q(x) = g_n(x)[/itex], which is continuous. At [itex]x=n+\frac{1}{2}[/itex], we have:
[itex]q(x-\epsilon) = g_n(x-\epsilon) = 0[/itex]
[itex]q(x+\epsilon) = g_{n+1}(x+\epsilon) = 0[/itex]
[itex]q(x)[/itex] is also once-differentiable, since [itex]g_n(x)[/itex] is, and the derivatives are zero at the boundary.
Now, [itex]\int_{-\infty}^{+\infty} q(x) dx = \sum_n \int_{n-\frac{1}{2}}^{n+\frac{1}{2}} q(x) dx = \sum_n \int_{n-\frac{1}{2}}^{n+\frac{1}{2}} g_n(x) dx = \sum_n \frac{1}{\lambda_n} < \infty[/itex]
Alright, I can accept that answer!
Here's my attempt at item 10. It uses two topologists' sine curves pasted back to back, and takes out the midpoint (0,0) from the central strut in order to connect the complement of the curve.
Consider the quadrilateral Q in ##\mathbb{R}^2## with vertices a=(-1,0),c=(1,0),b=(0,2),d=(0,-2).
Let M be the set ##\{(x,y)\ :\ x\in[-1,1]\wedge \ y=(|x|-1)\sin\frac1x\}##. This is the wiggly part of a topologists' sine curve, together with its reflection in the y axis. The factor ##(|x|-1)## scales it down away from the pathological region, to make it fit inside the corners of Q.
Let N be the set ##\{0,y)\ :\ y\in[-1,1]-\{0\}\}##. This is the 'terminal strut' of both sine curves, which becomes the 'central strut' of the pair.
Let ##A =M\cup N##.
Then I think A and its complement are both connected subsets of Q such that A contains diagonally opposite corners a and c, while ~A contains diagonally opposite corners b and d.
Applying the natural homeomorphism mapping Q to the quadrilateral (0,0)(0,1)(1,1)(1,0) (multiply vertical coordinate by 0.5, rotate anti clockwise around origin by 45 degrees, divide all coordinates by ##\sqrt 2##, then add (0.5,0.5) to all coords) gives us the desired counterexample.
Actually, I didn't give the answer, which is not [itex]q(x)[/itex] but [itex]\sqrt{q(x)}[/itex].
Why do I think my answer to 10 works? Well the argument as to why a topologists' sine curve is connected is known. The wiggly bit is clearly connected and any neighbourhood of any point on the strut must contain infinitely many points on the wiggly bit. So every point on the strut must be connected to the wiggly bit. Taking away the point (0,0) doesn't change this argument. Sticking another wiggly bit on the other side, we see that any neighbourhood of any point on the strut contains infinitely many points of both wiggly bits. So the two wiggly bits must each be in the same component as points on the strut, and hence in the same component as each other, so the set is connected.
As for the complement, consider the set X consisting of all points in Q below (having lower y coordinate than) a point on a wiggly bit, and the set Y consisting of all points in Q above (having greater y coordinate than) a point on a wiggly bit.
Define ##X'=X\cup\{(0,y)\ :\ y\in[-2,-1)\}## and ##Y'=Y\cup\{(0,y)\ :\ y\in(1,2]\}##
It is easy to see that X' and Y' are connected, and that the complement of A is ##X'\cup Y'\cup\{(0,0)\}##.
But it is easily seen that any neighbourhood of (0,0) contains infinitely many points of both X' and Y', so those three parts must all be in the same component, and hence the union, which is the complement of A, is connected.
Yeah, but to me it means that the definition of "connected" isn't quite right. An alternative definition is "path connected", which is that you can from any point to any other point through a continuous one-dimensional path.
Well that's the point of the counterexample (and the point of the topologists' sine curve): to exemplify the difference between path connectedness and mere connectedness. I think it would be straightforward to prove that the proposition is true (ie there is no counterexample) if one replaces 'connected' by 'path-connected'.
But I agree that 'path-connected' is the best match to the non-technical, everyday notion of what 'connected' means.
Here's my attempt at number 4
micromass said:
4.There is no infinitely differentiable function ##f:\mathbb{R}\rightarrow \mathbb{R}## such that ##f(x) = 0## if and only if ##x\in \{1/n~\vert~n\in \mathbb{N}\}\cup\{0\}##
The function ##f:\mathbb{R}\to\mathbb R## such that, for ##x>0##:
##f(x)=e^{-1/x^2}\sin\frac{\pi}{x}##
We set ##f(0)=0## and, for ##x<0## we set
##f(x)=\int_0^{|x|}B(t)dt## where ##B## is a Bump Function with support (0,1).
This is clearly infinitely differentiable away from 0. Examination of cases shows that it is infinitely differentiable at 0 (I'll expand on that later when I have more time). It has no negative roots, and it has positive roots at values of 1/n for natural n.
And lastly, my attempt at 9 - the only one without an attempted or confirmed solution yet.
micromass said:
9. If ##f:\mathbb{R}^2\rightarrow \mathbb{R}## is a function such that ##\lim_{(x,y)\rightarrow (0,0)} f(x,y)## exists and is finite, then both ##\lim_{x\rightarrow 0}\lim_{y\rightarrow 0} f(x,y)## and ##\lim_{y\rightarrow 0}\lim_{x\rightarrow 0} f(x,y)## exist and are finite.
Define ##f:\mathbb{R}^2\to\mathbb{R}## by
##f(x,y)=\sqrt{x^2+y^2}## if ##x,y## are both rational, and ##2\sqrt{x^2+y^2}## otherwise.
Then it's easy to show that ##\lim_{(x,y)\to(0,0)}f(x,y)=0##
But ##\lim_{x\to0}f(x,y)## and ##\lim_{y\to0}f(x,y)## do not exist except for where ##y=0## and ##x=0## respectively, because the limit of the former over the rationals is ##|y|## and its limit over the irrationals is ##2|y|##. The former failure prevents ##\lim_{y\rightarrow 0}\lim_{x\rightarrow 0} f(x,y)## from existing and the latter failure prevents ##\lim_{x\rightarrow 0}\lim_{y\rightarrow 0} f(x,y)## from existing.
A proof occurred to me. At first I thought we could use the intermediate value theorem on the two paths, until I realized that they don't necessarily map out the locus of functions from ##\mathbb R## to ##\mathbb R##. We can adapt the curves to remove 'turn-backs' so they become functions, but we lose continuity, which is necessary to use the IVT.
So instead we use the Jordan Curve Theorem. Say there's a continuous path in the unit square (0,0)(0,1)(1,1)(1,0) from (1,0) to (0,1), that does not pass through (1,1). Then combining that with the circular arc formed by the three-quarters of the unit circle that falls outside the unit square, we get a simple closed curve in the number plane that has the origin as an interior point and (1,1) as an exterior point. Jordan tells us that this curve divides the number plane into two disjoint open sets. Since the union U of those sets is not connected it is not path-connected (which is a stronger condition) either. So there can be no path from (0,0) to (1,1) that lies entirely inside U. Hence any path must cross the boundary of U at some point. If it crosses it on the circular part then that path is disqualified from consideration as it lies outside the unit square. So it must cross it on the part inside the square, which is the path between the two other diagonally-opposite vertices. So any two paths, within the square, between pairs of opposite vertices must cross.
Now say we have subsets A and B of the square, both path-connected, with each containing a different pair of diagonally-opposite vertices of the square. Then A and B each contain a path within the square between its pair of diagonally-opposite vertices. But those paths must cross. So A and B must share a point.
#2 counterexample
Let
[tex] A=\left[\begin{array}{cc}<br /> i & 1 \\<br /> 1 & -i<br /> \end{array} \right] [/tex]
where #i# is the imaginary value. Note that [itex]A^T=A[/itex] and has the characteristic equation[itex]\lambda^2=0[/itex],
thus the eigenvalue of [itex]A[/itex] is [itex]\lambda=0[/itex] with algebraic multiplicity of [itex]2[/itex]. The eigenvector of [itex]A[/itex] is
[tex] \mathbf{x}=\left[\begin{array}{c}<br /> i \\<br /> 1<br /> \end{array}<br /> \right][/tex]
with the geometric multiplicity of [itex]1[/itex] therefore [itex]A[/itex] is not diagonalizable.
Really great thread by the way Micromass! Those counterexamples were fun.
micromass said:
SOLVED BY fresh_42 If ##(a_n)_n## is a sequence such that for each positive integer ##p## holds that ##\lim_{n\rightarrow +\infty} a_{n+p} - a_n = 0##, then ##a_n## converges.
Misconception alert!
Let ##a_n## be such that for each positive integer ##p##, ##\lim_{n\rightarrow +\infty} a_{n+p} - a_n = 0##
Since the modulus operation is a norm on the real numbers, we have equivalence with ##| \; \lim_{n\rightarrow +\infty} a_{n+p} - a_n \;| = 0##. Since the modulus operation on the real numbers is a continuous function, we can write this as ##\lim_{n\rightarrow +\infty} | \; a_{n+p} - a_n \;| = 0##. Is this the same as "for all ##\epsilon >0##, there exists ##N,p## such that ##d(x_{n+p},x_n)< \epsilon## whenever ##n \geq N## "? Because if it is, then what you're asking for is when does a Cauchy sequence not converge. I'm a little confused since we know that the Harmonic series is not Cauchy but it satisfies your counter-example. What am I missing? And why do you have an extra ##n## in the subscript? I'm used to ##(a_n)##.
It is not. The order of ##\epsilon##, N and p is different, and this difference matters.
And you got the logic wrong for the Cauchy convergence.
Samy_A said:
Nice, some I know, some not.
Let me try 1:
Any open set ##G## such that ##\mathbb{Q}\subseteq G\subseteq \mathbb{R}## has either ##G=\mathbb{Q}## or ##G=\mathbb{R}##.
Set ##\mathbb{Q} = \{ q_1,q_2,q_3, ...\}##
Let's build an open set ##G## such that ##\mathbb{Q}\subseteq G## that can be written as ##G=\cup ]q_n-\epsilon_n,q_n+\epsilon_n[##.
##\mathbb{Q}\subseteq G## is trivially true. That ##G## is open is also trivial, as ##G## is the union of open sets.
Also, any open interval in ##\mathbb R## will contain irrational numbers, so that ##\mathbb{Q} \neq G##.
Now, we don't want ##G=\mathbb{R}##.
So let's build the ##\epsilon_n## such that some chosen non rational number is not in ##G##.
##\pi## is not a rational number.
Set ##\displaystyle \epsilon_n=\frac{1}{2}\min_{m \leq n} |\pi -q_m|##.
Clearly ##\epsilon_n>0##. Also ##\pi \notin ]q_n-\epsilon_n,q_n+\epsilon_n[##, since ##|\pi- q_n| \geq 2\epsilon_n \gt \epsilon_n## (and this for all ##n##).
Hence ##\pi \notin G##.
EDIT: I think my definition of the ##\epsilon_n## is too complicated.
##\displaystyle \epsilon_n=\frac{1}{2}|\pi -q_n|## would also work.
Doesn't this work? : Consider any irrational x. As singletons ( and finite sets ) are open, then consider its complement in the Real line: ## \mathbb R ##- { ##x ##}, which is open as the complement of the closed set { ## x ##}? And, since we only removed an irrational, ## \mathbb Q ## is contained in it. This gives us uncountably-many (counter) examples.
Doesn't the case for no function ## f: \mathbb R \rightarrow \mathbb R ## follow from Sard's theorem , assuming the graph is the set { ##(x,f(x)##}? Sard's says that the image of the set of critical points of a map ## f: \mathbb R^n \rightarrow \mathbb R^m ## has measure zero. If n < m, ( as, here, we are mapping the Reals into the subset ##(x,f(x) \subset \mathbb R^2 ##, then the image ##f(\mathbb R ) ## has measure zero in ## \mathbb R^2 ##? This means that differentiable functions are out, which may be somewhat obvious.
That is basically what @Samy_A constructed, just with a much shorter argument.
