Micromass' big statistics challenge
101 replies · 17K views · last reply
The answer to 2: the first one is the real random sequence.
The answer to 9: the text is a simple Caesar code of an English text. Up to you to decode it to see what it says. I think fresh_42 already did this.
And now I'm struggling with an overflow in RSA ...
An odd one, however. So my initial impression was right, and then I overthought the problem.
Yep. One more brick in my wall of discomfort when I hear someone, esp. politicians, argue with statistics.
This one (#2) surprised me too, but the probability of either sequence coming up (again) exactly the same in a random flipping of 200 coins is ## p=(1/2)^{200} ##.
Well.. yes, but that's not what the question was about.
It would appear when micromass selected a "random" coin flip sequence, the unlikely occurred. A couple of simple tests showed it wound up ## 2 \sigma ## or more from the mean. Not too unlikely, but not the most common case.
I agree that the answer to #2 is a bit odd. The standard way to test for randomness in a dataset (or at least to test whether events are independent) is the Wald-Wolfowitz run test. Dataset 1 contains 108 heads, & 91 tails, so one would expect to see 99.8 runs with a standard deviation of 6.98. The actual number of runs observed was 82, which is 2.5σ below expected, yielding a p-value ~ 0.013
Dataset 2 contains 105 heads and 94 tails, so one would expect to see 100.2 runs with a standard devation of 7.01. The actual number of observed runs is 104, just 0.5σ away from expected, yielding a p-value ~ 0.64.
(Calculations done with the runstest function in MATLAB)
micromass said:
  1. Take the following two sequences of coin tosses:
    Code:
    THHHHTTTTHHHHTHHHHHHHHTTTHHTTHHHHHTTTTTTHHTHHTHHHTTTHTTHHHHTHTTHTTTHHTTTTHHHHHHTTTHHTTHHHTHHHHHTTTTTHTTTHHTTHTTHHTTTHHTTTHHTHHTHHTTTTTHHTHHHHHHTHTHTTHTHTTHHHTTHHTHTHHHHHHHHTTHTTHHHTHHTTHTTTTTTHHHTHHH
    Code:
    THTHTTTHTTTTHTHTTTHTTHHHTHHTHTHTHTTTTHHTTHHTTHHHTHHHTTHHHTTTHHHTHHHHTTTHTHTHHHHTHTTTHHHTHHTHTTTHTHHHTHHHHTTHTHHTHHHTTTHTHHHTHHTTTHHHTTTTHHHTHTHHHHTHTTHHTTTTHTHTHTTHTHHTTHTTTHTTTTHHHHTHTHHHTTHHHHHTHHH
    One of these sequences is from an actual coin toss experiment. The other is invented by a human. Find out which of these is which.
What about the following solution:
We can assume that if a human invents a binary string, then one or both of the following things may happen:
1) the human does not (or can not) keep track of how many H's and T's he has previously generated, so he/she ends up creating a string where the observations are highly biased towards H (or T).
2) the human does not (or can not) remember the whole sequence of H's and T's he/she has generated so far, so he/she tends to generate new observations based on the (few) previous observation(s).
Based on the above assumptions I would propose a decision rule based on the result of the two following tests:
Test #1: Let's call α the probability of getting H in a coin toss. Estimate α by calculating the arithmetic average of H's in the string (this is a maximum likelihood estimator) and call this number [itex]\hat{\alpha}[/itex]. Perform a likelihood-ratio test between the probability of obtaining the given string under the two hypotheses that [itex]\alpha=\hat{\alpha}[/itex] and [itex]\alpha=\frac{1}{2}[/itex]. If the likelihood of the former hypothesis is higher, then conclude that the string was generated by a human. This test can be expressed by checking whether [itex]\hat{\alpha}[/itex] exceeds a certain threshold: [tex]\hat{\alpha} < \frac{\ln \left( 2(1-\hat{\alpha}) \right)}{\ln(\hat{\alpha}-1)}[/tex]
Test #2: Consider two consecutive observations X,Y. Estimate the joint probability distribution PX,Y by considering all the consecutive pairs of observations in the given string and by filling a 2x2 contingency table of the occurences of the four sequences HH, TH, HT, TT in the given string. Perform a [itex]\chi^2[/itex]-test of independence. If the hypothesis of independence is rejected, then we can deduce that there was probably a correlation between consecutive observations. In such case, we conclude that the string was generated by a human.The two strings provided in the original post both pass Test #1 but the first string does not pass Test #2: the corresponding p-values were 0.0164 for the first string, and 0.4944 for the second string and the threshold was set to 0.05, thus we conclude that the first string was generated by a human.
As an additional remark I can see a possible connection between this problem and the theory of data compression. Data that is intelligible (or generated) by a human often contains redundancies which are typically due to the correlation of different portions of data. Such correlations allow compression algorithms to predict the successive portions of a stream of data, given the knowledge of the previous data. This is typically not true for random noise, which is why a realization of true random noise is difficult to compress.
The random generation doesn't keep track of that by definition, a human must reproduce that in order to generate a plausible random distribution.
It will always be higher, unless we happen to have exactly as many T as H, which is unlikely for a randomly generated string.
##\hat \alpha \leq 1##, ##\ln(\hat \alpha -1)## doesn't work.
A randomly generated string will have correlations, because HH can follow after TH or HH, but not after HT or TT.
I never said "by definition".
I said "one of the following things may happen...", implying that a human may or may not keep track of the current count of H's: if he does not, he might ideally get caught by a properly designed statistical test (not mine), if he actually does, then he may still not pass Test #2.
This is probably a good point. Perhaps the test I proposed to check whether the string is produced by a biased coin flip experiment is not good (besides I have probably made a mistake in deriving the final formula). I have just noticed that some users were previously working on interesting ideas to achieve the same task. Maybe they will come up with a better solution than mine.
I think this statement, in its current form, is incorrect, but I probably understand what you meant in the context: if we have a string z1...zN we can already say something about the pair (zN, zN+1). On the other hand, I think we cannot say anything about (zN+1, zN+2). I guess that this just implies that when we populate the 2x2 contingency table we should not consider "all the consecutive pairs" of the string, as I previously said, but rather all the disjoint consecutive pairs.
Unfortunately, if I do that, then the p-values are well above the threshold for both strings, so the test does not work.
I said it.
That is wrong.
The random sequence does not keep track. Why should a human have to keep track?
We had simple hypothesis testing already: how likely is it to get a larger deviation from 50% than observed?
The probability to observe 91 or fewer T or H in 199 trials (like sequence 1) is 0.25, the probability to observe 94 or fewer T or H in 199 trials (like sequence 2) is 0.48. Not really a strong preference for one sequence here.
Well, we know 8 out of 16 things the pair cannot be.
We can do that, but that discards a lot of information.
Check the previous pages, there was already a lot of analysis in that direction.
