Microwave Oven: Why Are Grid Holes So Small?
  • Context: Undergrad
  • Thread starter Thread starter this_tim
    Microwave oven
The discussion centers around the design of the grid holes in microwave ovens, specifically addressing the size of these holes in relation to the wavelength of microwaves, which is approximately 12 cm. Participants explore the implications of hole size on microwave confinement and the behavior of electromagnetic (EM) waves in this context.
  • Some participants question why the holes in the grid are small if the wavelength of microwaves is 12 cm, wondering if larger holes would still confine the microwaves.
  • It is proposed that the grid serves as a mesh that acts like a solid wall to microwaves while allowing visibility.
  • One participant states that EM waves do not propagate through holes smaller than half a wavelength, but local fields can exist outside the holes, which are influenced by voltage and currents in the metal.
  • A participant requests further explanation about the "local fields," expressing curiosity about their origin and potential issues they may cause.
  • Another participant explains that a hole in a metal sheet functions as a slot antenna, where accelerating electrons create electric and magnetic fields, referred to as the Reactive Near Field, which can store energy and pose a radiation hazard if close to a body.
  • It is noted that making the holes small helps minimize both radiated energy and Reactive Near Fields.
  • Discussion includes the concept of a "perfectly" conducting screen, with participants questioning the feasibility of achieving such a condition and discussing energy conservation in the context of reflection and absorption.
Participants express varying levels of understanding and curiosity about the concepts discussed, but no consensus is reached regarding the implications of hole size or the feasibility of a perfectly conducting screen. Multiple viewpoints and questions remain unresolved.
Participants express uncertainty about the technical details, including the behavior of local fields and the practicalities of achieving a perfectly conducting screen. The discussion reflects a range of assumptions and interpretations regarding electromagnetic theory and microwave behavior.
this_tim
Since the wavelength microwaves used in microwave ovens have a wavelength of 12cm, why are the holes in the grid behind the glass so small? If they were 12cm would the microwaves still stay confined? If the small holes are only to "play it safe" that seems irrelevant since microwave has a "fixed" wavelength. Very confused about all of this and can't seem to find a very clear explanation anywhere.
Science news on Phys.org
The idea is to provide a mesh that is effectively a solid wall to microwaves but which can be easily seen through for convenience.
EM waves will not propagate through a hole that is smaller in diameter than half a wavelength. But there are still local fields that will exist on the outside. These are associated with the voltage across the hole and currents in the metal. By making the holes small, these fields are reduced in extent.
tech99, could you explain more about those "local fields" such as where they come from and why they would be a problem. I haven't much knowledge of physics, but am a programmer of 20+ years and though the two aren't exactly related, I "may" be able to follow along if you explain a bit more so I can better understand the size of the holes. It really does have me curious - Thanks!
A hole in a metal sheet is a slot antenna. All antennas radiate by accelerating electrons, but to do this they need to have an accelerating voltage across them. This does not radiate energy itself but it does create an electric field close to the antenna in which electrical energy is stored. There is a similar magnetic field, which arises because, after being accelerated, the electrons have velocity. These fields are sometimes called the Reactive Near Field, and they often store much more energy than the antenna radiates each cycle.
Very small antennas do not radiate very much energy but can have strong Reactive Near Fields.
For the case of a hole or slot in a sheet of metal, field lines can bend through the hole and be observed on the outside, even when radiation is very small. In principle, these fields could supply energy to the body, for instance, to the eye, if placed very close, and thereby constitute a radiation hazard. By making the holes small, both the radiated and Reactive Near Fields are kept very small.
tech99, Oh wow - finally something that makes a whole lot more sense, and a breakaway from the typical thinking in regard to just the waves themselves. Thanks so much for taking the time to provide the explanation. Of course I don't yet understand the complete details of what you wrote, but can picture it in my mind, and have a lot I can look further into as a result of the information you provided.
. . . . and, for a (perfectly) conducting screen, the Energy is reflected (conservation has to apply). This is the same as for a continuous sheet.
Am I correct in guessing that a "perfectly" conducting screen is very difficult, if not impossible to achieve? And please say more about your "conservation has to apply" statement.
Pretty low resistance is ‘good enough’ and Conservation just means the Energy has to go somewhere. It has to be reflected if it’s not absorbed.
Makes sense. Thanks!
  • · Replies 30 ·
14K
31K
  • · Replies 19 ·
