Calculating Velocity in the Millikan Oil Drop Experiment
The forum discussion focuses on calculating the velocity of an oil drop in the Millikan oil drop experiment using differential equations. The primary equation discussed is F=ma, leading to the expression for velocity as a function of time, v(t). Participants emphasize the importance of correctly manipulating the differential equation and integrating both sides to derive the solution. The final solution is identified as v(t) = (2a^2(p-p')g)/(9n)(1-e^(-t/(2a^2(p-p')/9n))).
  • Understanding of Newton's second law (F=ma)
  • Knowledge of differential equations, specifically separable variables
  • Familiarity with the concepts of terminal velocity and forces acting on a droplet
  • Basic calculus skills for integration and manipulation of equations
  • Study the method of solving ordinary differential equations using separable variables
  • Learn about terminal velocity and its significance in fluid dynamics
  • Explore the derivation of the velocity function in the context of the Millikan oil drop experiment
  • Review integration techniques, particularly for exponential functions and logarithmic expressions
Students and educators in physics, particularly those studying fluid dynamics and experimental physics, as well as anyone interested in the mathematical modeling of physical phenomena.
happyparticle
Find Millikan oil drop velocity
##m\frac{dv}{dt} = \frac{4\pi a^3(\rho - \rho_1)g}{3} - 6\pi n a v##
Hi,
I try to find the velocity for a oil drop.
I found the forces.
##F=ma => m\frac{dv}{dt} = \frac{4\pi a^3(\rho - \rho_1)g}{3} - 6\pi n a v##
with v on the right side, I don't see how to get the solution.
I found the solution on few websites, but without the path to find the solution from the equation above.
This is basically, the Millikan oil drop experiment without the electric field.
Did you mean the terminal velocity? The solution is a function of time.
I need to find v(t). Probably the velocity at any moment.
What do you know about differential equations?
I know I have to integrate both side.
##dv = \frac{4\pi a^3(\rho - \rho_1)g}{3m} - \frac{6\pi n a v}{m} dt##
##v = \int (\frac{4\pi a^3(\rho - \rho_1)g}{3m} - \frac{6\pi n a v}{m}) dt##
##v = (\frac{4\pi a^3(\rho - \rho_1)g}{3m}t + C_1 - \frac{6\pi n a v}{m}t + C_2) ##
However, this is not the solution.
It isn't the right Solution. The second term of the RHS has the variable ##v##. However, you considered it as a constant.
Not immediately, because you have dv/dt on the left and a v on the right. What will you integrate with respect to?
You first need to get it into the form (function of v only, or constant)dv=(function of t only, or constant)dt.
Search the web for "ordinary differential equations of separable variables". Basically to solve it you do what it is being said at the last line of post #7 and then you integrate both sides and then some minor algebraic manipulation to find the solution.
I tried different algebraic manipulations, but I can't find the right solution which is ##v(t) = (\frac{2a^2(p-p')g}{9n})(1-e^(\frac{-t}{2a^2p/9n}))##
My steps are
##\int \frac{dv}{4a^2/18n\cdot (p-p')g - v} = \int \frac{9n}{2a^2(p-p')} dt##
##-ln|\frac{2a^2g(p-p')g -9v}{9}| + C_1 = \frac{9nt}{2a^2(p-p')} + C_2##
I can't find a way to have the same solution as above.
You are very close to the solution. Use one integration constant ##C=C_1-C_2## and perhaps the solution you typed in post #9 has a typo? Shouldnt the exponential be ##e^{-\frac{t}{2a^2(p-p')/9n}}##?
When you know the solution you are supposed to get for a differential equation, the cheat way is to work backwards, differentiating the solution. It is usually easier to get to exactly the DE. Then reverse the steps.
I don't think I can use reverse the steps since I found the solution on wikipedia.
## V(t) = \frac{2a^2g(p-p')g}{9n} - e^{\frac{-t}{2a^2p/9n}} + C ##
It's still not exactly the same solution. Even if C = 1 for a=v=t =0
Let me simplify a bit:
Let ##A=\frac{4\pi a^3(\rho-\rho_1)g}{3m}## and ##B=6\pi\eta a##
Thus ##\frac{dv}{dt}=A-Bv##. Now, make the substitution ##u=A-Bv##
The substitution suggested by @Gordianus is a good one. I would also suggest that when the time comes to integrate, use definite integrals with upper and lower limits. In posting #5 I would have written $$\int_{v_0}^{v(t)} \frac{dv}{4a^2/18\eta\cdot (p-p')g - v} = \int_0^t \frac{9\eta}{2a^2(p-p')} dt$$ This says that at ##t=0## the velocity is ##v_0## and at ##t=t## the velocity is ##v(t)##. Evaluating the definite integrals automatically takes care of the integration constants. Once you integrate, all you have to do is solve for ##v(t)##.
Definite integrals also eliminate the annoying (to me) absolute value in the argument of the natural log. If the algebra is correct, the logarithm cannot have a negative argument because it describes a physical situation, not an abstract mathematical possibility. Don't forget that the difference of two logarithms is the logarithm of the ratio of arguments.
Almost got it, but I think my problem is algebraic.##\frac{4\pi a^3(p-p_1)g}{3m} + \frac{6 \pi n av}{m} + c = e^\frac{t\pi n a}{m}##
Where ##m = \frac{4 \pi a^3(p-p_1)}{3}##
##v(t) = \frac{m}{6 \pi n a}(g - e^\frac{t\pi n a}{m})##
Even if ##v_0 \neq v(t)## ?
Yes your problem is algebraic. In your final expression you are adding the exponential, which is dimensionless, to g which has dimensions of acceleration.
Even then.$$\int_{v_0}^{v(t)}\frac{dv}{v}=\ln\left[\frac{v(t)}{v_0}\right]$$There is nothing wrong with that.
We're so close...
Gordianus said:
We're so close...
It sometimes is not easy to see the forest for the trees. Two semesters of calculus didn't do it for me but a formal course in differential equations did.
Millikan only used the terminal velocity in his experiments. Are we not sending the OP on a goose chase here?? To the OP: The terminal velocity is easy to obtain by looking for a solution where ##\frac {dv} {dt} =0## . Of course it is good to be able to solve the full diff eq but the asymptote was all that Millikan used because that's all he could really see by eye.
In posting #2 I did ask OP exactly for that reason whether he/she meant terminal velocity and the answer was no. Besides, shouldn't one have the external force of the electric field also in the equation if that were the case?
I think this is the way I should find the solution. I just can't get it right.
I really don't see where I made a mistake.
##\frac{4\pi a^3(p-p_1)g}{3m} -\frac{6 \pi n av}{m} + c = e^\frac{t\pi n a}{m}##
##g - \frac{6 \pi n av}{m} + c = e^\frac{t\pi n a}{m}##
Is this right?
I know you did.
But Millikan turned off the field and measured the terminal velocity to find the mass of each of the droplets. Otherwise he could only report the charge to mass ratio.
With the field on I think he tried for perfect balance and no velocity by changing E.
I loved doing this experiment as an undergrad. Transcendental experience.
Note: the links in the above are all screwed up...apparently completely... apologies.
EpselonZero said:
Is this right?
Several reasons why it is not right.
You have a constant ##c##. What is its value?
Your expression is dimensionally incorrect.
It is not in the form where ##v## is on side of the equation and everything else on the other.
If you showed your work in some detail, we could perhaps point out where you went wrong.
hutchphd said:
I know you did.
I also remember doing the experiment as an undergraduate, but the details are lost in the recesses of my memory. That was in the days when one could not buy a turnkey experiment from PASCO. I do remember, however, two things: trying to stop the drop with the field and having a devil of a time trying to sort out the data. I also remember that we didn't see any quarks ##\dots##
I mean at this point is it correct? Because I don't really see where is my error. Is it before that?
whatever I do I still get the same answer.
If I'm not mistaken, post 13 should have ##B=6 \pi \eta a/m ##.
Meanwhile ## \frac{dv}{dt}+Bv=A ## has a straightforward solution to the differential equation that the OP should recognize:
##v_p=\frac{A}{B} ## and ##v_h=Ce^{-Bt} ##.
It is simple matter for ##v(0)=0 ## to solve for ##C ##.
(##v_p ## is the particular solution, and ## v_h ## is the homogeneous solution. The complete solution is the sum of these, with the constant ## C ## determined by the initial conditions).
Note: I don't get the exponents mentioned in posts 9 and 10. I believe those are in error.
Edit: See post 41. Post 9 is correct.
I'm wondering what I did wrong. I mean I'm confuse and for the moment I want to stick with one way to find the solution. I already tried few way, but I can't find the solution. I'm close, but I don't find my error. I just did the whole thing few times and I can't see what I did wrong.
What you have in post 12 from Wikipedia I believe is incorrect. That's why it didn't work. Wikipedia has an error. See post 28 for the solution. (Edit: See post 41. Wikipedia has correct solution).
In post 15, you introduce a definition for ##m ##, where ## m ## is already in the problem. You need to use some other letter.
