Minimal property of Spacelike geodesics in GR/curved spacetime?
The discussion revolves around the properties of spacelike geodesics in general relativity and curved spacetime, particularly focusing on whether they represent minima, maxima, or saddle points in the context of variational principles. Participants explore the implications of these properties in both special and general relativity, as well as the mathematical underpinnings of geodesics.
  • Some participants note that spacelike geodesics in special relativity can be seen as saddle points, as variations can yield both longer and shorter intervals depending on the path taken.
  • Others argue that the premise regarding the extremal properties of spacelike geodesics is incorrect, emphasizing that it is insufficient to demonstrate minimality by merely finding longer paths.
  • A participant references the lack of extremal properties for spacelike geodesics in curved spacetime, suggesting that they correspond to saddle points.
  • There is a discussion about the maximality of timelike geodesics, with some asserting that they are maximal among timelike paths, while others point out that this is not universally true due to the presence of conjugate points.
  • Some participants question the validity of defining a path as a geodesic without proper context, particularly in relation to different dimensionalities of spacetime.
  • References to literature, such as O'Neill's work and Bliss's monograph, are made to support various claims regarding the properties of geodesics.
Participants express disagreement regarding the extremal properties of spacelike and timelike geodesics, with some asserting that spacelike geodesics do not have extremal properties while others maintain that timelike geodesics can be maximal under certain conditions. The discussion remains unresolved regarding the generalization of these properties in curved spacetime.
Participants highlight the complexity of the topic, noting that the properties of geodesics can depend on the dimensionality of the spacetime and the specific metrics used. There are also references to specific mathematical theorems and texts that may provide further insights into the nature of geodesics.
  • #61
JimWhoKnew said:
The specific example says that there is a saddle for ##\Delta\phi >\pi##. It doesn't prove the impossibility of saddles for all ##\Delta\phi\leq\pi##, since only variations in the ##\theta## direction were considered.
True. Unlike in the case of the sphere in 3-space, in this case we have the flexibility to vary the radius as well. I might play around with that. I would be surprised if only "major arcs" were saddle points of proper time, but nor "minor arcs".
  • #62
Kostik said:
Doing the work, I get $$\frac{d^2 \tau}{d\eta^2}(0) = \frac{1}{\sqrt{K-1}}\int_0^{a\pi} \left[ f(\phi)^2 - f'(\phi)^2 \right] d\phi $$ where $$K = (1-2m/R)(dt/d\phi)^2.$$
I got a different proportionality factor. Note that your ##K## and "1" don't have the same dimensions.
Kostik said:
Since ##dt/d\phi## is the inverse of the angular velocity ##\omega##, we have $$K = (1-2m/R)(R^3/m) = R^3/m - 2R^2.$$
The relativistic expression for ##\omega## in Schwarzschild coordinates should be used. Are you sure it is ##\sqrt{m/R^3}## ? (my memory is not to be trusted)
Kostik said:
this condition may restrict the minimum orbit radius
It is well known that the geodesics of circular orbits at ##r=3m## are null, so we should expect a restriction.
Kostik said:
Note that the two ##f(\phi)## used by @Orodruin in his major arc example to demonstrate that the geodesic is a saddle point of the proper length now reverse roles to show that the circular orbit is a saddle point of the proper time.
Come on, give me some credit :smile:
  • #63
I pose a question I don’t have an answer to at this time. In calculus of variations, the normal reason a geodesic may fail to be a local extremum is the occurrence of conjugate points. If you consider a geodesic starting from a point, it will be an extremum to an end point before its first conjugate point. In GR, a common case of a non-extremal geodesic is when two geodesics intersect at two points. Between the points of intersection, only one of the geodesics will be extremal. So my question is whether there is any relation between intersecting geodesics and conjugate points? At this moment, I don’t have time to think about it, so want to ask it before I forget the idea (I am of that age where that is too common).
  • #64
By passing from the 2 dimensions of the sphere's surface to 4 dimensional spacetime we added 2 dimensions. so in principle there should be 3 "independent directions" in which variations are allowed.
  • #65
In a intuitive non rigorous way conjugate points are the points where nearby geodesics intersect. To precise statements is the existence of a Jacobi field that vanishes at the endpoint.
  • #66
Thank you, I lost the ##r^2## factors in the metric for the angular coordinates. Re-doing it, I find the same formula holds but with $$K=\frac{R}{m}-2 \, .$$ Thus, the condition ##K>1## is equivalent to ##R>3m##. (This is much nicer than the cubic equation for ##R## I had before.)
I think it's OK to use $$\omega^2 = \left( \frac{d\phi}{dt} \right)^2 = \frac{m}{r^3} \, .$$ After all, the circular orbit is the same in GR as in Newtonian mechanics.
And thank you for your help on this!
  • #67
When I wrote "give me some credit" I intended to hint that I obviously needed no help in noting the reversal on my own. But "likes" are nice too.
  • #68
There is still a missing ##R## in the numerator. ##\frac{d^2 \tau}{d\eta^2}## should have dimensions of time.
I can't look it up right now (yes, I'm aware I have access to the internet), but as I remember, circular orbits can be either stable, unstable or semi-stable. Do they all obey the Kepler form? Can you provide a reference?
You're welcome
  • #69
Yes, I forgot there is an ##R## in front of the integral sign (which affects nothing)!
  • #70
You're welcome
I also recall that circular orbits are unstable if ##r < 6m## (?). But does this affect the constant ##K##?
  • #71
The instability may suggest that even a short orbital segment is a saddle point rather than extremal for such an orbit.
  • #72
I carried out the calculation, aided by chapter 25 in MTW, and got that Kepler's Law $$\omega^2 = \left( \frac{d\phi}{dt} \right)^2 = \frac{m}{r^3}$$ is indeed the general result for circular orbits also in Schwarzschild coordinates.
  • #73
Actually, using ##v^2 = m/(r-2m)## I am getting $$\omega^2 = \frac{m}{r^2(r-2m)} .$$
  • #74
No, that's not correct, because in Schwarzschild spacetime, the implicit substitution ##v = \omega r## that you are using is not correct. The correct relationship is
v = \frac{\omega r}{\sqrt{1 - 2m / r}}
  • #75
Damn, thank you!
  • #76
It does not. In a sufficiently small neighbourhood, spacetime will be approximately Minkowski - sufficiently so to ensure geodesics between timelike separated events in such neighbourhoods are local maxima of proper time.
  • #77
In case you'd like some online sources for this in the future, here is a link: (for the circular orbit case) https://sites.science.oregonstate.edu/physics/coursewikis/GGR/book/ggr/ocircle.html
For general quick discussion on orbits: https://sites.science.oregonstate.edu/physics/coursewikis/GGR/book/ggr/orbits.html
  • · Replies 28 ·
  • · Replies 16 ·
