Minimize expected value of the absolute difference
8 replies · 16K views
cielo
Let X be a continuous random variable with median m.
Minimize E[|X - b|] as a function of b. Hint: Show that E[|X - b|] = E[|X - m|] + 2 [tex]\int[/tex] (x - b) f(x) dx , where the integral is from b to m.
I wanted to try a solution but I even don't know how to determine whether it is minimum or not. Please help.
treat is as a function of b
f(b) = E(|X-b|)
how would you find the minima of f w.r.t. b?
Can you show the expression given above? If so, what do you know about the sign of
[tex] \int_b^m (x-b) f(x) \, dx[/tex]
Finally, note that the right-side is a function of the number [itex]b[/itex]. What happens when you evaluate at that function at a (cleverly) chosen value?
I am having a hard time how to evaluate this integral because the function f(x) is not given.
Aaaaah, that's the point: if you were given a specific [tex]f(x)[/tex], any result you obtained would apply only to that particular function , not in general. This exercise is meant to give a general result.
Hint: In the integral
[tex] \int_a^m (x-b) f(x) \, dx[/tex]
the interval of integration consists of values [tex]x \ge b[/tex], so
i) What is the sign of [tex](x-b)f(x)[/tex] over the interval?
ii) What does this say about the sign of the integral of [tex](x-b)f(x)[/tex]?
iii) Using your answers to `i' and `ii'', if you want to choose [tex]b[/tex] to minimize
[tex] E(|X-m|) + 2 \int_b^m (x-b) f(x) \, dx[/tex]
as a function of [tex]b[/tex], what choice does it?
okay, let me see if I figure this out right.
i) The sign of [tex](x-b)f(x)[/tex] over the interval is positive.
ii) The sign of the integral of [tex](x-b)f(x)[/tex] is positive.
iii) Substituting b to m in the expression [tex] E(|X-m|) + 2 \int_b^m (x-b) f(x) \, dx[/tex]
results to [tex] E(|X-b|) + 2 \int_b^b (x-b) f(x) \, dx[/tex]
which becomes E(|X - b|) + 2*(0)
and finally to E(|X - b|)
...so E[|X - b|] is minimized when b = m.
I hope this time I finally got it right with your guidance.. =)
However, I'm wondering what is the use of 2 when the integral is just zero?
Stat Dad -- Thank you for your guidance on this problem -- I was terribly lost and had a very similar question!
