Minimizing Total Cost of Making Open Box with Squared Base
  • Thread starter Thread starter jetoso
    Base Box
The discussion focuses on minimizing the total cost of constructing an open box with a squared base, given a volume constraint of 6400 cm3. The total cost (TC) is defined as TC = x2 + 0.5xy, where x is the base dimension and y is the height. A participant suggests solving the volume constraint for y and substituting it into the TC function to minimize cost as a function of x, negating the need for Lagrange multipliers. This approach leads to a more straightforward solution for determining the optimal dimensions.
  • Understanding of basic calculus, specifically partial derivatives
  • Familiarity with optimization techniques in mathematics
  • Knowledge of volume and surface area calculations for geometric shapes
  • Experience with cost functions in mathematical modeling
  • Study optimization techniques without Lagrange multipliers
  • Learn about cost minimization in geometric problems
  • Explore the application of partial derivatives in real-world scenarios
  • Investigate volume and surface area relationships for various geometric shapes
Students in mathematics or engineering fields, particularly those focusing on optimization problems, cost analysis, and geometric modeling.
jetoso
We want to make an open box with squared base. Let x be the dimension of one side of the base and y the height of the box. We pay a cost of $1.00 /cm^2 for the base and $0.50/cm^2 for each side.
The box must have a volume V = 6400 cm^3. Determine the dimensions x and y which will minimize the total cost of making the box.
V = yx^2, TC = x^2 + 0.5xy
I tried to solve the problem taking the partial derivatives with respect to x and y, which will give me the minimum values, but my results are not consistent. I am thinking on using Lagrange multipliers to solve the nonlinear minimization problem subject to the equality constraint of volume.
Any suggestions?
Thank you.
In your TC function, remember that the box has four sides. Solve the volume constraint for, say, y. Then substitute that into TC. Now total cost is a function of only x. Minimize it. You certainly don't need lagrange multipliers.
Thank you, I think this works.
  • · Replies 17 ·
