What is the minimum height of the bag needed for glucose infusion?
  • Thread starter Thread starter DrMcDreamy
    Height Minimum
To determine the minimum height of a bag needed for glucose infusion, the average gauge pressure in the vein is 15,000 Pa, and the specific gravity of the glucose solution is 1.04. Using the equation P = ρgh, the density of the solution is calculated as 1,040 kg/m³. The height is then calculated to be approximately 1.47 meters. It is emphasized that specific gravity is a unit-less ratio of densities, typically compared to water.
DrMcDreamy
A collapsible plastic bag contains a glucose solution. If the average gauge pressure in the vein is 15000 Pa, what must be the minimum height of the bag in order to infuse glucose into the vein? Assume that the specific gravity of the solution is 1.04. The acceleration of gravity is 9.8 m/s2. Answer in units of m.
P=\rhogh
I don't know what the units of the specific gravity so I assumed its 1.04 g/c,3. So it becomes 1040 kg/m3.
So would it be:
P=\rhogh
15000 Pa = (1040 kg/m3)(9.80 kg m/s2)h
\frac{15000 Pa}{1040*9.80} = h
1.47 = h
Is that right? TIA
It looks correct.
But do tell your teacher that NO value should be given without its units. (i'm obviously referring to the "1.04" for the specific gravity.)R.
Its correct! So what would be the usual units for specific gravity? TIA
I would have guessed g/cm^3 as you did.
But purely because the value was close to 1.
(The density of water is 1g/cm^3).
Specific gravity is unit-less. It's a ratio of densities. That's what makes it "specific".
In most cases it's a ratio of the density of the given substance to the density of water.
Oh, of course.
Thanks for that, gneill.
Thank you gneill!
  • · Replies 26 ·
  • · Replies 19 ·
