Minimum number of cycles in a short pulse laser
The discussion centers on the feasibility of emitting a laser pulse with a duration shorter than its wavelength. It is established that a pulse length must be an integer multiple of one wavelength due to the requirement that the integral of the electric field of the full pulse must equal zero, in accordance with Maxwell's laws. The concept of half-cycle pulses is introduced, which are asymmetric but still adhere to this principle. Ultimately, a single cycle is determined to be the shortest pulse achievable in this context.
  • Understanding of Maxwell's laws of electromagnetism
  • Familiarity with laser physics and pulse generation
  • Knowledge of wave propagation and electromagnetic fields
  • Concept of Fourier analysis in waveforms
  • Research the properties and applications of half-cycle pulses in laser technology
  • Explore the implications of Maxwell's laws on pulse shaping and laser design
  • Investigate advanced techniques in pulse generation, such as using mechanical choppers
  • Learn about the Fourier transform and its role in analyzing waveforms
Physicists, laser engineers, and researchers in electromagnetism who are interested in pulse generation and the fundamental limits imposed by physical laws.
Uchida
Hello to all,
In a short pulse laser emission setup, can a pulse be emmited with beam length shorter than one wavelength? (can a pulse have a duration shorter than its period?)
Lets say a laser emmiter shoots a quarter cycle pulse, what would happen to this short beam?
(lets supose the existence of a very fast chopper, and a very agile laser emmiter on the setup)EDIT:
I've found another thread within this subject (couldn't find it before):
https://www.physicsforums.com/threads/how-short-can-a-pulse-be.251777/
The integral of the electric field of the full pulse must be zero, otherwise it would violate Maxwell's laws (the Fourier component of frequency 0 must be zero if no charges are present). In that sense, a single cycle is the shortest one can get.
Note that there are things called half-cycle pulses, which are in fact highly asymmetric, with a strong positive half-wave followed by a long and weaker negative tail. But even then, the total field integrates to zero.
So, a pulse length must be integers multiples of one wavelength?
What would happen if a mechanical chopper choped a linearly polarized laser pulse with length of 1.125 cycle?
(consider propagation from right to left)This would be feaseble with a mechanichal chopper. And it gives a non zero area EM fields.
What would happen to the wave form far from the source?
No, this is not feasible. You have to include all the physics of the blade moving across the beam front. Shutting off the light instantly is simply not possible.
How do I square the above fact with the image below where it looks like we have a propagating E&M pulse of just one half pulse? I apologize if this is obvious.
Thank you.
That picture was intended only to show qualitatively how accelerating an electric charge produces radiation. It’s not precisely and quantitatively accurate so you cannot rely on it for anything else.
When we work through all the physics of the accelerated charge, we find that the pulse in that picture is a superposition of full cycles of waves of much shorter wavelength.
  • · Replies 33 ·
  • · Replies 17 ·
