Optimizing Periodic Motion in an Elliptical Orbit
The discussion focuses on determining the minimum period of a particle moving in an elliptical orbit defined by the equation x²/a² + y²/b² = 1, with the constraint that the velocity components cannot exceed a maximum value, v. Participants explore dividing the ellipse into sectors to analyze the time taken for the particle to traverse these sections while considering the relationship between the x and y components of velocity. Key points include the realization that at a 45-degree angle, the velocity components are equal, and the need to identify where the slope of the ellipse reaches this angle. The conversation emphasizes the importance of understanding how velocity varies around the ellipse to minimize cycle time effectively. Ultimately, the participants arrive at a clearer approach to solving the problem by considering the constraints of velocity and the geometry of the ellipse.
Jenny Physics
A particle moves periodically around an ellipse of equation ##\frac{x^{2}}{a^{2}}+\frac{y^{2}}{b^{2}}=1##. You can assume ##a>b##. The ##x## and ##y## components of the particle's velocity can never exceed ##v## at any point. What is the minimum possible period of the periodic motion of the particle?
Motion in an ellipse. Kinematics.
It seems I could divide the ellipse into sectors and come up with constraints for the time the particle takes to travel in those sectors. I am not sure though how?
On a given portion of the path, what attribute determines which constraint limits the overall speed?
Likes Jenny Physics
In the limit both components of the velocity would be ##v## for a speed of ##\sqrt{2}v##.
Right, but where on the path does that happen?
Likes Jenny Physics
The two components would be equal to each other when a line connecting the particle to the origin is ##45^{\circ}## with the x-axis?
Yes.
Does this allow you to make progress?
Edit: blunder by me... fortunately picked up by gneill.
Likes Jenny Physics
haruspex said:
Yes.
Is it always true that the components of the velocity are equal at 45 degrees? Or only for an ellipse/circle? (I am a bit confused about the basics here, I intuitively said that at 45 degrees the components are equal but not sure why)
If the speed is v and the direction is at 45 degrees to the axes, what are the x and y components?
Likes Jenny Physics
Ok got it. So I think you are suggesting that I divide the ellipse into 2 regions using lines at 45 degrees. If the angle is smaller than 45 then the y component of the velocity is always bigger than the x component. So I can assume that at its maximum the y component is ##v## in all the range were the angle is smaller than 45 degrees. I need to relate this to time and arc length somehow.
You need to find where the slope of the ellipse is 45°. For an ellipse this will not be at the same location as where a 45° line passing through the origin intercepts the ellipse.
Likes haruspex and Jenny Physics
Good point, I was missing this.
haruspex said:
Yes.
For the region where the angle is less than 45, do I assume the vertical velocity is a constant equal to the maximum of ##v##, find the vertical distance the particle moved and find the time by dividing that distance by v?
It depends what angle you mean.
Where the magnitude of the slope exceeds 1 the limiting constraint is the y component.
Likes Jenny Physics and gneill
Yes, sounds like a good plan. At the critical point where the velocities are equal, you "hand off" the maximum velocity to the x-component.
Edit: I just realized (thanks for the heads-up @haruspex) that by the angle you were referring to the slope of the ellipse. It will be greater than 45° w.r.t. the horizontal until the hand off point. Vertical (so infinite) at the major axis ends, horizontal (so zero) at the minor axis ends.
Likes Jenny Physics
You do not say how the velocity varies as you go around the ellipse. Your subsequent workings seem to be assuming that at any point, either ##|v_x| = v## or ##|v_y|= v##, or both. Of course, it is intuitive that such a velocity profile will be needed to minimize the cycle time, but you should at least state that explicitly. It never hurts to point out such things so that the person marking the question can see that you have thought about it.
Likes Jenny Physics and Delta2
I see that you've marked the question as solved. I hope that you appreciate the mathematical elegance of the final solution :smile:
Likes Jenny Physics
  • · Replies 26 ·
  • · Replies 31 ·
