Minimum power for a man-powered helicopter
154 replies · 25K views
Are the towns connected vertically[at a small angle to the axis of rotation ] on the Earth's's surface or otherwise or does it matter .
i think this can be corellated with electrical equipotential surface ,since the work done to move a charge on an equipotential surface is zero ,
if the Earth is a gravitational equipotential surface then the work done to move a body with certain mass, on it from one point to another would be zero .but we do this everyday with considerable loss of energy ,bah ! so there's some loophole in the question which i 'm unable to exploit .
this is just a wild stab in the dark ,i don't think my concepts in the gravitation are clear enough ,but hey i don't want to regret not sharing my brainwave .
i'll go look it up .
Stefan Udrea said:
jdavel, this is too simplistic.Where do you draw the line of zero potential energy ?
The customary location to define zero potential is at infinity. But I don't see what difference it makes. As long as the PEs at the beginnning and end of the tunnel are the same, no energy is used getting from one to the other. What am I missing?
The work done on getting the train from A to B may be zero, but that doesn't mean no locomotive is needed. There might be a potential barrier in between which the train cannot cross.
IF THE TUNNEL IS DUG THROUGH THE CENTRE OF THE EARTH THEN ,THINGS GET A LOT MORE EASIER .
ASSUMING THAT THE TUNNEL IS DUG THROUGH THE CENTRE :
let the train of mass m be at a distance r from the centre of the Earth ,
the portion outside this radius will not exert any net gravitational force on the train .
let the mass inside this radius be Me ,this can be treated as the mass of a particle lying at the centre of the Earth ,
let F be the force b/w the train and Me
F = GmMe/r^2......[eqn 1]
now volume of the sphere of radius r IS[ 4/3 pie r^3]
let P be the density of this sphere of radius r ,
Me=P[4/3pie r^3] ,substituting this in eqn 1
F=4/3{pie}GmPr
4/3{pie}GmP is a constant ,which we take as K
THEREFORE
F=-Kr ,[minus sign indicates that F{vector} and r{vector} have opposite directions]
this is the form of hooke's law ,hence the TRAIN WILL OSCILLATE LIKE A BLOCK ON A SPRING ,
BUT ALL OF THIS HAPPENS UNDER HIGHLY IDEALIZED CONDITIONS ,LIKE DENSITY P BEING A CONSTANT WHICH IS NOT TRUE ,AND THE TUNNEL IS DUG THROUGH THE CENTRE OF EARTH .
ok, extreme_machinations, could you give it a try with the assumption that the tunnel doesn't go through the center of the Earth ?
The question specified that the tunnel was "straight". How can there be a barrier if the tunnel is straight? In the first half aren't you always going down hill and in the second half up hill?
i remember doing a similar tunnel problem on a problem set which asked for the trip time, which i believe is something like 42 minutes regardless of the location of the cities. use gauss's law to derive a periodic equation of motion; the location-dependent quantities should cancel out. if no one's done it by the time I'm done with finals, i'll write up a solution.
Because you were the closest to find the solution, you get to ask the next question.
What was the solution you were looking for?
:smile : don't call me "sir" , I'm just a college student.
jdavel,
In the drawing,
AB is the tunnel , the two cities are in A and B.
T is a random position of the train in the tunnel, at the distance r from the center of the Earth ; r<R
Because the volume of the Earth between r and R has no gravitational influence on the train, we have the gravitational attraction on the train F=kmM/r^2 , where M is the mass of the sphere of radius r.
[tex]M_0[/tex]is the total mass of the Earth
[tex]M=M_0 \frac{r^3}{R^3}[/tex]
The movement of the train is given by the component [tex]F_e[/tex] ,parallel with the tunnel.
Then,
[tex]F_e=K \frac {m M_0}{R^3} y =ky[/tex]
[tex]\vec{F_e}=-k \vec{y}[/tex]
So the movement in the tunnel is a harmonic oscillation given by :
[tex]y= \sqrt {R^2-d^2}sin(\omega t+\frac{\pi}{2} )[/tex]
[tex]y=w \sqrt{R^3-d^2}cos(\omega t+\frac{pi}{2})[/tex]
[tex]T_0=2 \pi R \sqrt{\frac{R}{KM_0}}[/tex]
This wasn't my idea ; I found the problem and the solution in a book.
jdavel,
In the drawing,
Then,
Well...that's a lot more than is necessary to "Show that the train ,which circulates through the tunnel between the two towns ,doesn't need a ... locomotive." The fact that the path never goes above the starting point is sufficient to show what you asked for.
You gave an intuitive answer.I didn't mean it as a "yes/no" question , I wrote "Show".
now who really gets to ask the next question ,
me or u again stefan ?
OK here's the question ,not worth the wait i guess but anyway .
A THIN SUPERCONDUCTING RING OF RADIUS [tex]r_0[/tex] AND INDUCTANCE{zero resistance } IS HELD ABOVE A VERTICAL CYLINDRICAL MAGNETIC ROD . THE AXIS OF SYMMETRY OF THE ROD AND THE RING ARE SAME .THE CYLINDRICALLY SYMMETRICAL MAGNETIC FEILD AROUND THE RING CAN BE DESCRIBED IN TERMS OF ITS VERTICAL AND RADIAL COMPONENTS AS [tex]B_z=B_0(1-aZ)[/tex] AND [tex]B_r=B_0br_0[/tex] ,WHERE [tex]B_0[/tex] ,a ,b are all constants .THE CURRENT IN THE LOOP IS ZERO WHEN IT'S RELEASED FROM ORIGIN z=0 and r=0 .
DETERMINE HOW THE RING MOVES SUBSEQUENTLY.
[ps i don't know how to attach the fig ,so imagine a vertical cylinder and ring kinda levitating on top with magnetic field looking like a fountain coming out of the top part of the cylinder . The vertical and radial components of magnetic field are perpendicular to each other .]duh!
Should we assume the ring initially accelerates under the influence of Earth gravity?
yes as the ring is placed in the magnetic field , two forces will act on it along the
z- axis one of them being gravity [mg] and the other one is lorentz force ,
you'll have to figure out the directions yourself
is this too tough or too damn stupid to be tried ,
it seems I've killed yer game gokul .
I was going to give it a shot just since no one else does, but I have to ask, in your magnetic field equations are the variables that the mag field decreases by Z and R respectively?
I worked out the problem but I haven't had the time to post it online, and since
my internet at home is out for a little while I probably won't for week or so. Also, is that [tex]B_r=B_0br_0[/tex] or [tex]B_r=B_0br[/tex] ?
PS I'm not asking anybody to not post a sol'n, btw. Just saying the game is not yet over.
Total flux enclosed is [tex]\int B.ds + Li[/tex] - I
[tex]= [Bo(1-az)k + (B_0 b r_0)(r)].(\pi r_0^2)k + Li[/tex] (k is unit vector in z direction and r is the unit vector in the radial direction)
[tex]= B_0(1-az)\pi r_0^2 + Li[/tex]
Now this value of flux (as written from I) can be taken as constant as
|E|=(d(Flux)/dt)=iR
as R=0, d(Flux)/dt=0.
Therefore Flux enclosed is constant - II
when z=0,i=0.Therefore Flux = (pi)(r0)^2(B0)
From II
(pi)(r0)^2(B0)= [tex]= B_0(1-az)\pi r_0^2 + Li[/tex]
From that we find the current to be
[tex]i= \frac {B_0a\pi r_0^2 z}{L}[/tex]
The force acting on the wire in the z direction is F= B(r)(i)(L)
[tex]= - \frac{B_0^2 b r_0 a \pi r_0^2 z}{L}(2\pi r_0)[/tex]
=-kz (Opposite to direction of displacement of ring)
therefore ma=F-mg
and a=-kz/m - g
this means that the ring undergoes SHM about the mean position zo=-mg/k
So z(t) - zo = Acoswt
and at t=0, z=0, A=-z0
z(t) = -zo(Coswt - 1)
from this it is seen that the z - coordinate is never positve and therefore the magnetic force is always upwards.
P.S: Extreme_machinations, you took this question from the Y.G File right? I knew i did this question sometime ago. :smile:
EEEEEEEEEEEEEYYYYUUUPPPP! THAT'S RIGHT .
SIDHARTH ,that ws .."BRILLIANT"........{mabe not} ,HEHEHEHEHEHEHE
SRY BOTEMP early bird takes the worm {[tex]B_r=B_0br_0[/tex], is correct,
[tex]r_0[/tex] is constant }
SO I SUPPOSE NEXT ONE'S ALL YOURS SIDHARTH .
I REALLY WISH SOMEONE WOULD POST A THEORETICAL QUESTION INVOLVING MORE PHYSICS AND LESS MATH .
Here is a simple one.
Three balls, each of Mass 'M' ,are connected by means of massless, rigid rods of length 'L' as shown in the diagram so as to form an equilateral triangle. This triangle is placed on a frictionless, horizontal table. A fourth ball of mass 'm', traveling parallel to the base of the Triangle, with velocity v1, collides with the other ball and gets stuck to it.
Find the velocities of each ball after collision and describe the subsequent motion of all four balls.
Here goes my answer based on very little physics background:
Assuming that mass ‘m’ is lesser or equal to ‘M,’ I would imagine that in the collision, it would transfer it’s velocity to the ‘triangle of balls’ which would then move with a velocity of m/3M * V1 along a line parallel to that which the initial ball struck (Each ball in the triangle would be traveling at this velocity of m/3M * V1 ).
Since the surface is frictionless, there would be no forces to cause the triangle to turn.
Having transferred all of its kinetic energy to the ‘triangle’ of balls, the ball of mass ‘m’ would remain in the position where it had struck the triangle of balls.
siddharth,
The physics may be "simple" but unless there's a trick I'm missing, the math looks like a mess!
How about making the top mass of the triangle and the incoming mass both equal to M/2? :rolleyes:
Ok Fine. Take the top mass of the triangle and the incoming mass to be equal to M/2. The bottom two masses are still M.
Let me restate the question
Three balls, two of Mass 'M' , and the top one of mass 'M/2' are connected by means of massless, rigid rods of length 'L' as shown in the diagram so as to form an equilateral triangle. This triangle is placed on a frictionless, horizontal table. A fourth ball of mass 'M/2', traveling parallel to the base of the Triangle, with velocity v1, collides with the other ball and gets stuck to it.
Doc G. The ball after collision with the top of the triangle, gets embedded to it.
