Minimum work and work-energy theorem
The discussion centers on the minimum mechanical work required to lift a 5-kg hammer to a height of 3 meters, emphasizing the work-energy theorem. The minimum work is calculated as the weight of the hammer multiplied by the height, which is straightforward, but confusion arises regarding the role of gravity and the net work done. It is clarified that if the lifting force equals the hammer's weight, the hammer can be lifted without gaining additional kinetic energy, resulting in a final velocity of zero at the height. The key point is that the minimum work corresponds to just overcoming gravitational force without imparting extra energy. This understanding resolves the apparent contradiction between displacement and velocity.
dapias09
Hi guys,
I've got a doubt concerning to the minimum mechanical work and the work-energy theorem. Consider the following Tippens' problem (8.4):
A 5-kg hammer is lifted to a height of 3 m. What is the minimum required work?
The answer looks very simple and inocent, W = weight times distance. However, deeping inside we can calculate the negative work done by the gravity, it would be: W = -weight times distance. So, the total work is equal to zero and if we assume that the hammer starts from rest then its final velocity have to be equal to zero too (work-energy theorem).
It's very confusing for me how this could be possible, how a displacement could be obtained if at any time the velocity is equal to zero. Also is confusing how being the total force equal to zero (weight - weight = 0) the motion is possible.
Thanks in advance for your help.
I believe the question is supposed to be:
What is the minimum work you would need to lift a hammer 3m?
...and not the net value of the work due to gravity plus your own lifting.
The minimum amount of work you need to lift the hammer is equal to the minimum amount of force you need to lift the hammer times the change of height.
If the force you apply is larger than the weight of the hammer, the hammer will accelerate upwards faster and faster, so that when it reaches 3m, it is still moving, and has extra kinetic energy on top of the needed gravitational potential energy.
The minimum amount of work will be when the amount of force approaches the weight of the hammer, so that when the hammer reaches a height of 3 meters, there will be no extra kinetic energy.
Likes 1 person
Thanks for answering jfizzix. That's what I wanted to discuss.
Best Regards!
  • · Replies 24 ·
  • · Replies 34 ·
  • · Replies 33 ·
  • · Replies 24 ·
